BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) FSC coding for CarPlay on X2 lacking 6CP
      10-18-2020, 11:31 AM   #111
shawnsheridan
shawnsheridan's Avatar
10445
Drives: 2018 Alpina B6 650ix GC
Originally Posted by starsky View Post
Hello, when flashing I can reinstall the fsc codes of my car or are they no longer valid? Thanks.
Flashing has no effect on FSC Codes.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-01-2020, 07:11 AM   #112
alexvas
Drives: bmw x1 f48
Hi, I have X1 f48 with entrynav2.
Can I use Carplay on it?
VIN last *3M45053
shawnsheridan
could you help me?
thx
      11-01-2020, 10:32 AM   #113
shawnsheridan
10445
VIN last *3M45053
shawnsheridan
could you help me?
thx
PM sent.
      11-04-2020, 03:04 PM   #114
Rich G12
Drives: bmw x2 Msport X
shawnsheridan
I Have Pro nav and wlan etc, last 7 of my vin is EA95913.
Could you PM me if its is possible please?
Thank you!
      11-04-2020, 03:35 PM   #115
shawnsheridan
10445
Originally Posted by dolphinrich@hotmail.co.uk View Post
shawnsheridan
Thank you!
PM sent.
      11-11-2020, 04:13 PM   #116
ash29ster
Drives: 2018 BMW X1 sDrive28i
shawnsheridan Can I activate/Code CarPlay on my 2018 BMW X1? VIN: 5H41144
      11-11-2020, 04:38 PM   #117
shawnsheridan
10445
PM sent.
      11-21-2020, 04:34 PM   #118
stealth1
Drives: F48 X1
Trying to understand the process to upgrade my 2017 X1 with EntryNav to a second hand EntryNav2. What I think I understand is:
1) It doesn't matter what year or model the EntryNav2 came from. But if my car is a US car, then I should look for a US EntryNav2 Unit.
2) A NBT emulator is needed. With this, all options/FSC's on the donor vehicle will be retained (Nav, Satellite Carplay if I can find one)
3) With an emulator, no coding is needed.
Can anyone confirm the above assumptions?
Questions re activating Carplay:
1) Is there any advantage if the original car had Carplay Prep?
2) Any advantage to donor car having Nav? I think I read that Nav FSC must be purchased too, if the car doesn't have it.
3) Where is the least expensive source for the Carplay FSC Code?
Thanks in advance for any help!
      11-21-2020, 06:07 PM   #119
shawnsheridan
10445
The Emulator wont prevent any needed coding. It is just to handle the VIN mismatch between car and Donor ENTRYNAV2.
Why not get better EVO Head Unit, and bypass the Emulator altogether?
      11-22-2020, 05:49 PM   #120
stealth1
Drives: F48 X1
Shawn,
Thanks for your insight. I was only considering ENTRYNAV2 because carplay is the only missing/upgrade feature that really matters to me besides Satellite, and I thought it would be a more cost effective solution than EVO HU (and I really don't like the aftermarket via aux options).
Re EVO unit upgrade, wouldn't this also require an ATM swap and new $$ wiring harness? In the case of an EVO upgrade vs ENTRYNAV2 upgrade, is the coding work essentially the same?
      11-22-2020, 07:40 PM   #121
shawnsheridan
10445
Shawn,
If car already has ATM, then no need to swap.
Coding for EVO is of course different, but same in terms of ease.
      11-23-2020, 02:57 AM   #122
kubax86
kubax86's Avatar
1790
Drives: M2
He has Entrynav so there is no ATM in his X1
      11-23-2020, 09:15 AM   #123
shawnsheridan
10445
Telematics is overrated.
      11-24-2020, 07:02 PM   #124
okankaymak
Drives: 2021 330xi M Sport
So, I finally have a 100% fullscreen carplay working on my 2018 X2. Big thanks to kubax86
We had to upgrade the firmware and then code the fullscreen carplay. Everything was done remotely. And it took about 20min total. Maybe less, but not more.
He clearly knows what he is doing. Reach out to him if you want fullscreen carplay on your X1's and X2's. It's finally available and you won't regret.
Thanks again my friend!
      11-25-2020, 04:42 PM   #125
stealth1
Drives: F48 X1
This is helpful to know, thanks for this info.
So the EVO unit requires an ATM, but EntryNav2 does not?
      11-25-2020, 04:45 PM   #126
shawnsheridan
10445
Both ENTRYNAV2 and EVO have ATM if car is equipped with Telematics.
      11-25-2020, 04:52 PM   #127
stealth1
Drives: F48 X1
And both EVO and EntryNav2 NEED an ATM retrofit? Or can I get a HU (either type) from a car that didn't have telematcs and avoid retrofitting ATM?
      11-25-2020, 04:56 PM   #128
shawnsheridan
10445
No. ATM is not a requirement. It there only if Telematics are installed / needed.
      11-25-2020, 05:08 PM   #129
stealth1
Drives: F48 X1
Very helpful, thank you Shawn.
      11-25-2020, 05:39 PM   #130
kubax86
kubax86's Avatar
1790
Drives: M2
Without ATM, if you want to use GPS functions you need headunit with Built-in GPS (blue plug).
      11-26-2020, 02:56 PM   #131
stealth1
Drives: F48 X1
One more question: Is a wiring harness/adapter required for EVO or EntryNav2, to retrofit into a 2017 EntryNav F48?
      11-26-2020, 04:55 PM   #132
kubax86
kubax86's Avatar
1790
Drives: M2
You need different USB cable or rotate it, CID cable and depends if you will get Headunit with GPS or you're going to retrofit ATM. So many variables.
