02-14-2020, 07:40 AM | #45 |
1105
Rep 1,263
Drives: 20 BMW M2C 17 Mazda MX-5 RF
According to Alex there is a difference between GTS and Euro MDM. Others can chime in if they've tried both settings...
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 |
02-18-2020, 01:24 AM | #46 | |
280
Rep 488
My car had euro mdm from the factory, but with the gts also then configured the feel of the rear end with the lsd was much better |
AndrewC198910944.00 |
02-18-2020, 09:19 AM | #47 |
10944
Rep 4,553
Drives: 2015 328d xDrive
02-18-2020, 11:32 AM | #48 |
280
Rep 488
My guess is that the gts is looser and you feel the lsd more. However, the dsc module in the m2c is different, so you'd have to have access to m2c + gts coded og m2 to compare.
AndrewC198910944.00 Danielo5824.50 |
02-18-2020, 11:50 AM | #49 |
10944
Rep 4,553
I ask b.c a friend of mine with an OG purchased Thor flash and did the GTS EPS and GHAS but did M2C MDM because he said it felt better. Wondering if that's all in his head or if the adaptation values are actually more aggressive/suited better to the F87.
05-03-2020, 12:51 AM | #51 |
7339
Rep 7,510
I'll probably code this in later as well. Thanks for the tip!
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
05-04-2020, 10:17 PM | #52 | |
3179
Rep 2,577
In addition, did you ever use F80CS and F87comp steering for comparison in terms of "heaviness"? I've always hated heavy steering, because today at the EPS age, mostly it just makes car feel sluggish at low speed and doesn't feed back much of the road. 911 steering is way lighter, no mention of the even more brilliant 981 steering. Alfa Romeo Guilia QV also has a very light steering and it is a couple leagues better steering than M.
Lemania 2320
05-04-2020, 11:04 PM | #53 | |
7339
Rep 7,510
Summary: f87cs is indeed alot lighter than f87gts which is heavier than stock. I think f87cs might be lighter than stock eps settings. I have not had the chance to experiment with any other steering settings or other cars unfortunately. All of my friends own subarus and evos due to the climate here. So unfortunately I don't have anyone to borrow a car from, unless I go to the dealership. I agree with you 100%, heavy steering=/= good. I also feel the m2's steering wheel was so artificially heavy in an attempt to convey sportiness that all feeling was numbed out. You will definitely like f87cs if you haven't codes that in already, it is the perfect heft and has really good road feel. It also doesn't have the center seeking feel of a heavy steering wheel where it feels like the wheel keeps fighting you to go back to center. It also removed any dead spots in the center.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 05-04-2020 at 11:10 PM.. |
05-04-2020, 11:49 PM | #54 | ||
3179
Rep 2,577
Just curious is the F87cs EPS the default setting for the M2 comp? I may give a try.
Lemania 2320
05-05-2020, 12:50 AM | #55 | |
7339
Rep 7,510
I have no idea what the default EPS settings are on the m2C. But yes, give the f87cs EPS settings a try.
05-05-2020, 08:18 AM | #56 | |
280
Rep 488
I haven't been running the diff/GHAS update for long, but am thoroughly enjoying the change of feel to the car that it has made so far! I had the opportunity to get in a good country lane blast and the car was the most fun it has ever been! Yes as far I am aware |
05-05-2020, 08:20 AM | #57 |
280
Rep 488
05-05-2020, 08:43 AM | #58 | ||
280
Rep 488
[QUOTE=SeanWRT;26134466]I'm under the impression the GTS steering is already lighter than pre LCI. It's difficult to imagine F87cs is a lot lighter.
I sense the following myself: In feel order: 1. F82GTS 2. F87 (F020-19-03-530) 3. F87CS 4. F87 LCI 5. F87 OG In terms of weight (heaviest first): 1. F87 LCI 2. F82GTS 3. F87 (F020-19-03-530) 4. F87CS 5. F87 OG Quote:
SeanWRT3179.00 |
05-05-2020, 09:38 AM | #59 |
3179
Rep 2,577
Thank you widetyres for going in details with me on this topic.
I tend to agree with everything you said except for M2 OG having the lightest steering weight. I'm on original EPS version and I think it's heavier than the M4C I've been driving and a lot other Ms (I drove a lot of F8X for long time). Especially in comfort mode, I barely tell the weight difference from sport if I didn't pay attention. I did track days quite often and get to use different Ms from BMW China. IMO the best steering feel is with M4CS but it has a lot to do with the car itself (chassis, tyre and power plant). But with every single F8X, on low speed turn in, they're all numb...you know you lose front end only when it happens and it goes from understeer to oversteer quite dramatically because of the unstable rear end traction. Instead they're brilliantly at high speed turn because that's more about balance. In summary, I think M2 is much more made for street than for track (M4 albeit having less old school M feel, is a much more serious track machine), sometimes steering feedback at limit isn't really all that important. When not at limit, all variants of steering tuning is close except for the weight. Which is why I care a lot about it and simply want the lightest one possible. Those things coming from a licensed driver like me is weird I know...but it's very honest input of mine. Thanks
Lemania 2320
05-05-2020, 04:36 PM | #60 |
2835
Rep 3,714
Something SeanWRT and I have been trying to figure out in the THOR thread:
Are the F87CS settings the same as those that are the OEM settings for the M2C? |
05-06-2020, 01:29 AM | #61 | |
280
Rep 488
M2 OG & LCI = F087 M2C = F087CS M2 CS = Most likely F087GTS from other posts I have seen, although I haven't been able to verify myself due to the age of my ISTEP Last edited by widetyres; 05-06-2020 at 02:23 AM.. |
ZM22835.00 |
05-06-2020, 08:23 AM | #62 | |
2835
Rep 3,714
And, a lot of the discussion regarding the settings has been around steering feel. What about MDM & differential--how would you all rank the amount of slip and cohesiveness of the different MDM/differential settings for the OG M2? M2 (F087) < M4 GTS (F082GTS) < M2C (F087CS) < M2 CS (F087GTS)? Last edited by ZM2; 05-06-2020 at 08:38 AM.. |
05-06-2020, 01:14 PM | #63 | |
7339
Rep 7,510
I think it's F087 < f087cs (slips more consistently than gts but to a lesser degree) < f082gts
ZM22835.00 |
05-06-2020, 01:47 PM | #64 | |
2835
Rep 3,714
The new THOR DCT flash looks pretty interesting and it only costs $100 more to get easy MDM/Differential customization and flashing to go with it, but they do not have F087GTS available at the moment. So, just trying to investigate and lay all this out clearly. Would appreciate other folks input on F087GTS availability, and how the MDM and differential slip perform relative to F087CS and F082GTS. |
PLF693770.00 |
05-10-2020, 12:18 AM | #66 |
3179
Rep 2,577
I've always had the reservation for using chassis tuning made for other platforms...
I'm not assuming our stock Ms come out of factory dialed in perfectly (but surely purposefully), but BMW engineers ought to know way more and be way better equipped, and spend serious time in development. Personally I'd rule out all GHAS and DSC from F80/82, simply because different weight balance (not just static front/rear weight distribution) and of course different dimension. As for the M2 CS (F87gts file), it carries over adaptive damper from F80/82 which I believe diff and DSC will work accordingly for each c/s/s+ mode. Therefore, it does not fit M2 OG and M2C well in my opinion. However, steering should be no issue, just the preference. You can use E-SYS... I'm not a big fan of E-SYS TBH, it has the Savvy look and take time to get familiar with, but in the end it does very basic and simple things...feels like trying hard figuring out a long and boring menu and finally order something from recommendation page one and it's even not all that good.
Lemania 2320
ZM22835.00 |
