01-04-2019, 11:11 PM | #1 |
56
Rep 150
Drives: 2018, F48 28i
hi, I have 11/2017 built 2018 f48. I tried coding to show tire pressure and temperature using Bimmercode. but only blank digit shows beside the four wheels on the display. the wheels are showing green colour before and after coding. Any help and thoughts abt how it can be done? I am not even sure if it can be coded.
01-05-2019, 01:21 AM | #2 | |
142
Rep 491
X1604M55.50 |
02-01-2019, 03:06 PM | #4 | |
678
Rep 910
Check and see if your tyre valves are metal or rubber. If they are metal then you have tpms sensors fitted (option 2vb on your car build list - you can do a vin build check online). With metal valves and tpms sensors you can adjust your coding via bimmercode to get pressure and temperature. If you have rubber valves you do not have tpms, instead your car measures rolling diameter of the tyre to give a pressure estimate and no temp reading is possible. Be aware that if you do have tpms then after coding it will tell you to start driving, only after driving will it give you pressure and temp readings. Until you start driving (needs about mile) it will only show blank digits, the same as when you reinflate your tyres and reset the readings in the idrive menu. Last edited by MJE60; 03-10-2019 at 11:24 AM.. |
X1604M55.50 |
02-01-2019, 07:06 PM | #5 |
35
Rep 239
My X1 has been in for service this week, and i think they did a sw update for the car. Because it now shows tire temp, different info for auto parking and when below 3 degrees celcius it shows a icey road under the car when you have the screen set to car info
X1604M55.50 |
02-01-2019, 09:56 PM | #6 |
56
Rep 150
thanks for all the replies. I found out that mine has rubber stem. that's why I don't see any pressure and temperature info on the display. Cheers.
02-03-2019, 09:26 AM | #7 |
678
Rep 910
Nice!, I like display. Thank you for sharing.
02-11-2020, 09:40 PM | #8 |
56
Rep 150
I found out that Canadian f48 are installed with the required hardware on DSC unit. But if the TPMS are installed on the wheels all the car needed is to code the option 2VB. But the question is how to code? I saw a post coded by Esys. Any one has and idea or know coding with Bimmercode? I appreciate any input from you all.
I installed TPMS on my wheels and made sure they are working. Following is the post I found. https://www.bimmerfest.com/forums/sh...d.php?t=909092 |
02-20-2020, 09:12 PM | #9 | |
142
Rep 491
02-20-2020, 10:24 PM | #10 | ||
56
Rep 150
02-21-2020, 01:56 AM | #11 | |
142
Rep 491
