BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Oil opinion
      02-23-2018, 03:13 PM   #1
ejw2011
ejw2011's Avatar
53
Drives: x3 F25 35i, x1 F48 28i
Oil opinion
Does anyone here find 0w20 a bit thin for our x1? I'm wondering if BMW decided to use this grade to get better gas mileage. I normally stick to what the BMW engineers suggests, but thinking using 0w30 or 5w30 for summer. What's your our opinion?
      02-23-2018, 11:49 PM   #2
spitpilot
47
Drives: 2009 328I M sp, 2017 X1 M sp
You are indeed correct...all the "tricks"(like defaulting the driving mode to ECONO and making mode not part of the driver's profile that could be set to your preference) are aimed at improving MPG so BMW can sell higher powered gas guzzlers for high profit. If you look at the owners' manual you will find that oils up to 0W40 are approved for use in the B48 engine....I'm running that weight in warmer months, since it can get seriously hot here in the summer time.
      02-28-2018, 07:39 PM   #3
Ridin'Dirty
Ridin'Dirty's Avatar
22
Drives: '93 'Beemer' R100r, '17 X1
Does anyone here find 0w20 a bit thin for our x1? What's your our opinion?
I agree with what spitpilot says; thinner oils are just one of the many tools BMW uses to bump those mileage figures as high as possible. I live in Western PA's "snowbelt" region where it neither gets ridiculously hot or cold on a annual basis. After completing the engine run-in period, I switched from from 0W-20 to 5W-30 TwinTurbo LL-01. I want as much synthetic goodness lubricating that turbo when running and think the 30 weight end of this oils specification will help this oil film remain intact without cooking out (coking) from heat soak after engine shutdown.
      03-02-2018, 02:17 PM   #4
calvol
Drives: 2001 330i
Yep, Iím using 5w30 in San Diego.
      03-02-2018, 03:00 PM   #5
ejw2011
ejw2011's Avatar
53
So for those using 5w30, what are you getting as far as mpg?
Since I've been using factory 0w20, I'm getting roughly 27-31 mpg depending on speed and traffic.
      03-02-2018, 08:20 PM   #6
Ridin'Dirty
22
Yeah, that's about where I'm at too...as long as I can stay out of Sport Mode (but it just feels soo damn good! )
      03-04-2018, 04:15 PM   #7
spitpilot
47
Yup...Sport Mode should be the default mode!! I've never had a car with an engine over 3.5L and a good many were 2.0L or below....so I feel all my past fuel economy compared to 5.0L and up American Iron...has earned me the right to use Sport Mode and the "right pedal" any time it feels right!
Forgot there for a min that this is an "oil thread"....owners' manual says 0W-40 is OK...and that's what I'll be using...gets hot up here in the desert in the summer months!
      02-18-2020, 10:14 AM   #8
orion_squall
Drives: E92
5w30 can impact engine life?
Hi,
Question for those who actually uses BMW 5w30 longlife01. Are you guys in the US with a BMW X1 Petrol version (F48), there should only be Petrol version in N.A? If so, can you comment on any negative observation with the use of 5W-30 TwinTurbo LL-01? My problem is that in Canada, some dealer went to extra length (even after I showed them the manual and many other tech sources) to tell me that they recommends 0W20 LL14 FE+ and they stopped short on commenting whether 5W-30 TwinTurbo LL-01 can affect the warrantee.
How is your experience with 5W-30 TwinTurbo LL-01?
thanks
      02-18-2020, 11:02 AM   #9
Skyline2.0
41
Drives: 2018 BMW X1 xDrive
Originally Posted by orion_squall View Post
Hi,
thanks
I've been running Liqui Moly SpecialTec 5W30 for 19,500 miles and counting now. According to Liqui Moly, this particular oil meets BMW's LL-01 spec. I have not personally had any oil related issues so far.
I was running BMW 0W20 LL-17 FE+ for ~3k miles for better flow during the colder winter months. I know the owner's manual states LL-14 FE+, but the dealer handed me the LL-17 instead. I was annoyed as I didn't realize the difference until I got home, but saw LL-17 FE+ is compatible with the B46 engine, per newtis.info, and the Parts Dept said this is the oil used to service their X1s, so I decided to go with it.
I just swapped back to Liqui Moly 5W30 yesterday. When running 5W30, I do notice a slight drop in average MPG (~0.4 - 0.7 mpg) if the OBC is taken as accurate. The engine also seems to run ever so slightly quieter on 5W30, but that could just be all in my head. In the end, I opt to run the LL-01 spec 5W30 oil for the improved engine protection claims.
EDIT:
Originally Posted by pTron View Post
I use LM 5w30. The trick is to let it warm up for at least ~10 minutes.
I initially had the BMW OEM oil (0w30) and I saw no change in MPG. However, I will echo that the engine seems a tad quieter.
I have stayed away from BMW OEM oil and their intervals (I do it every 5K miles).
GL!
Forgot to mention - I also go by 5k OCI like pTron instead of the longer interval of 10k miles per BMW dealers.
      02-18-2020, 02:51 PM   #10
pTron
42
Drives: Doesn't matter
GL!
It doesn't matter if you win by a mile or inch, Winning is WINNING!
      02-18-2020, 04:06 PM   #11
VWAudi2BMW
VWAudi2BMW's Avatar
75
Drives: 2017 330i
I actually just went back and fourth with this in my 3 series, same engine though.
I ended up going with 0w-40 and it feels smoother for sure. I have always tried to go easy on my cars until they are warm. From here on out I'll be doing my own changes and sticking with 0w-40. I have used this weight in my VW and Audi turbo cars and they all have done very well with it all year here in so-cal
5K intervals for me, which is about once per year.
F30 | Ram 1500 Limited 4x4 Hemi
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
