06-02-2009, 11:54 PM | #1 | ||
1112
Rep 12,442
2009 BMW Z4 sDrive35i Full Test and Video
BMW's Roadster Finally Hits Its Stride Dan Edmunds 06-02-2009 Quote:
And the result seemed like an über-Miata, too — except the super-suit didn't fit well. BMW must have felt the same way, because the redesigned car received significant changes and a new name: Z4. Attempts to tailor the suit included a wheelbase stretched by nearly 2 inches, a stiffer chassis and a much improved rear suspension. But the magic still wasn't there and the Bangle-administration styling was polarizing, if not confrontational. Doubters like Dan remained unconvinced. "I remained unconvinced," says Dan. So the recent arrival of the new 2009 BMW Z4 sDrive35i roadster at our offices was met with considerable suspicion. Some approached it carrying a grudge, in fact, because its new power-retractable hardtop signals the end of dedicated fixed-roof versions like the M coupe, considered by some to be the best thing about previous Z roadsters. Heart Transplant What the Z4 really needed was a major infusion of horsepower. After all, the competing 2009 Mercedes-Benz SLK350 and 2009 Porsche Boxster S both meet or exceed the 300-horsepower barrier. The outgoing Z4 whimpers in the corner with but 255 horses. The 2009 BMW Z4 sDrive35i has that problem handled, because it's now propelled by the same 300-hp 3.0-liter twin-turbo inline-6 that we covet in the 335i and 135i. And this impressive power plant goes the competition one better because it also delivers 300 pound-feet of torque — about 35 lb-ft more than either of its BMW siblings. Press the go pedal on your favorite on-ramp and the Z4 sDrive35i exhibits effortless strength and delivers a sustained midrange punch that comes from a torque peak that arrives at just 1,300 rpm and stays put up to 5,000 rpm. This prodigious grunt also reduces the need to stir the six-speed gearbox as often — a handy trait because we're still not keen on the long-throw clutch action found on many BMWs, including this Z4. Unleashed at the track, this adds up to a 5.2-second run to 60 mph from a standstill (4.9 seconds with 1 foot of rollout like on a drag strip) in the face of a slight headwind on the way to a 13.4-second quarter-mile run at 103.7 mph. That's about a tenth of a second quicker to 60 mph than the last Boxster S we tested, though the '09 Boxster might squeak ahead again once we test it with its new 310-hp engine. (It'll be close.) Longer, Lower, Wider, Heavier The new Z4 might have gone quicker still if it hadn't gained about 360 pounds. Some of the extra weight comes from the new hardtop, but the new Z4 is also 5 inches longer. The wheelbase is essentially unchanged at 98.3 inches, so the extra length resides in the front and rear overhangs. This mass may have dulled the reflexes of the new Z4 through our slalom maneuver somewhat, and it posts a speed of 68.9 mph. We've put a 2007 Boxster S (a car that weighs about 400 pounds less) through the same cones, and it goes nearly 3 mph faster. On real roads, however, the 2009 BMW Z4 delivers crisp turn-in, reliable grip and lots of confidence. There's an unflappable sophistication to the way the Z4 responds to driver commands. It feels more planted and less frenetic than before, and that makes it easy to build up speed and really push. But the Z4 pushes back at the limit with mild but sometimes persistent understeer that doesn't readily respond to lift-throttle attitude adjustments. It's not particularly off-putting, but the similarity to the BMW 135i is worth noting. Brakewise, our Z4 has garden-variety single-piston sliding calipers that really work. Stops from 60 mph eat up only 106 feet of our test track, and pedal feel remains firm and steady time after time. It makes us wonder why the 135i bothers with huge (and expensive) six-piston fixed front calipers. As Ever, a Sport Package Our 2009 BMW Z4 test car has $2,300 of Sport package, which means it sits 0.4 inch lower and comes with Adaptive M Sport suspension, consisting of computer-controlled adjustable dampers that constantly vary their firmness based on road surface inputs, steering angle and lateral acceleration data. The limits of adjustment are constrained by three driver-selectable maps (Normal, Sport, Sport+) accessed through the Dynamic Drive Control switch. The Normal position turns out to work best 95 percent of the time, especially on winding back roads that have a less-than-pristine surface. And the normal setting settles the car nicely on city streets and freeways alike, making the new Z4 a composed daily driver. The Sport and Sport+ settings prove most suitable for glass-smooth pavement, track use and those times when the stability control overlord might get in the way. Life Begins at the Top The new top is a big step forward for the 2009 BMW Z4, and not just because it looks stunning while it adds top-up serenity and security. The big get is the elimination of the claustrophobia and poor visibility associated with previous Z roadsters. Its thinner metal roof sections have no bows, which contributes to a 1.8-inch increase in top-up headroom despite a 0.3-inch reduction in vehicle height. And there's nearly a full inch of additional shoulder room because this top's folding junk goes in the trunk instead of a space-robbing slot wrapped around the seats. Both are truly useful increases that don't escape the notice of our tallest testers. There's more glass area, too. The rear window grows larger because it no longer needs to be shuffled into a folding fabric sandwich, and the top mechanism has no scissor hinge to hide, so slender C-pillars and small rear side windows adjoining the pillarless door glass can be used. Late Appointments The Z4's enhanced interior space has been made even more hospitable with upgraded equipment offerings and a striking design. Handsome brushed aluminum panels add interest to the interior, but their matte sheen doesn't reflect sun back in our eyes. Likewise the interior leather surfaces utilize pigments that reduce heat buildup. Amazingly, top-down direct sunlight doesn't wash out the 8.8-inch fold-up screen that's part of the $2,100 navigation system. It's controlled with the first-ever appearance of iDrive in a Z roadster, and the timing is perfect because the new generation of iDrive software finally works. The interior is sprinkled with thoughtful storage compartments ranging from fold-down door pockets to a cockpit-width shelf behind the seats to an available pass-through to the trunk. This new Z4 roadster has more spread-out room than you'd think. Summing Up And that's just it. The improved top and the interior changes instantly make the 2009 BMW Z4 Roadster a credible choice for any extended cross-country journey we care to make. Add in the twin-turbo engine and the refined ride and handling and it's quite tempting. The $52,475 base price for an sDrive35i represents a jump over last year, and at first we thought the $64,020 as-tested price of our test car was out of whack. But the sum total of the improvements to this car is substantial and transformative. The 2009 BMW Z4 sDrive35i is now more than able to rub shoulders with the Mercedes-Benz SLK roadster and the Porsche Boxster S, and on that basis the price is not out of line. The new 2009 BMW Z4 sDrive35i made believers out of a lot of fence-sitters. No longer is this a two-seat BMW roadster with an identity crisis. "Perhaps they should have renamed it Z5," says Dan. Article source and video here: http://www.edmunds.com/insideline/do...topanel..1.*#2
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
06-03-2009, 12:28 AM | #3 |
PuffPuffPass
52
Rep 1,096
SOOOO SEXY.. I saw a spy car of this few month ago with black tape covering all the badges. Shit was really nice.. Price is too high tho..$60k without navi lol. Weights too much too. If this had the wieght of a s2k..,,,,,GG
My right foot weighs more than my left for sure. |
06-03-2009, 12:29 AM | #4 |
PuffPuffPass
52
Rep 1,096
Looks alot like the asian style buttons on Lexus's and Infinitis.. Finally BMW getting nice interiors.
06-03-2009, 01:21 AM | #5 |
1072
Rep 8,008
Drives: i4M50
It's as clear as day as to what market BMW are now pitching the Z4 to, and it ain't the performance market. But after saying all that this is probably the best compromised design choice after the M3, in this I mean that BMW has decided not to try and compete with the Boxster/Cayman, instead they have compromised outright ability (like in the M3) for style and practicality and in so doing have a brilliant car on their hands.
I bet any money that even with these troubled times the new Z4 will out sell the old one by quite a margin. P.S. The reference to the M3 means that instead of stripping out the interior and lightening everything down BMW decided to compromise it's ability slight in the pursuit of a much better overall package, which they succeeded brilliantly. |
06-03-2009, 03:08 AM | #6 | |
86
Rep 847
06-03-2009, 07:58 AM | #7 |
53
Rep 689
Not my cup of tea. Why BMW is trying to do SLK completely blows my mind. If I wanted an SLK I would buy and SLK. At least you can get an AMG SLK...
2007 M Coupe w/NAV/Premium/Extended Leather, Clearbra, DICE, 4.10 BMW Motorsport Polished LSD, Active Autowerke Gen IV Headers, Supersprint Race Exhaust and X-Pipe, ESS Tuned DME, KWV3 Coilovers, Volk RE30, OEM Strut Tower Brace, Short Antenna, JL AMP, JL 10W7, Valentine V1.
06-03-2009, 09:09 AM | #10 |
Black Forest Bimmerphile
Rep 137
When I drove the previous Z4 coupe and cab I really liked the improvement in handling over the Z3. Edmonds hit it on the head when they called it an ubermiata. With more shoulder room and power the Z4 now has everything I need except storage, which actually isn't too bad. That 60 large number is a stopper though.
Too bad. I do wonder if the engine can be modified, say with a Vishnu tune? Last edited by ZBMW; 06-03-2009 at 09:13 AM.. Reason: Added sentence |
06-03-2009, 09:30 AM | #11 |
1279
Rep 6,303
what's with the old Z4 bashing.. now it's all identity crisis and stuff. That's just funny. You can knock the old Z4 for low interior quality but not all was bad, it was a snappy, tail happy and fun car. This is more of a budget Merc SL (no bad thing) than boxter alternative, at least for me.
F30.F11.E86.E90.E90.E36 |
06-03-2009, 02:04 PM | #12 |
Rep 49
The E85 and E86 (2006-2008) are Euro-Miata brands? Confused Identity Crisis?
This is all hype, its a new car and this always happens with every new model hitting the Market. The E85 & E 86 (updated styling ones) are true light weight roadsters with great handling and dynamics capability, they are SUPERIOR TO THE MIATA & S2000, HENCE ARE NOT IN THE SAME CLASS. They are unique in their own right with the Flame-Surfacing style, really stand out when compared to other roadsters on the road, have all the options one would ask for and cost well below $50K including the 3.0si. This guy doesnt know what he is talking about except for the part that the new roadster is a good one no doubt. |
06-03-2009, 06:03 PM | #13 |
516
Rep 7,787
wow, jeee let me guess 64.000$ z4 with 300hp or 64.000$ m3 with 414 + an m goodies ??? what a hard choice to make............... seriously what was bmw thinking giving it such a huge price tag ?
06-04-2009, 12:45 AM | #15 |
87
Rep 2,464
Well the guy has no idea what he's talking about. He refers this new z4 as a true sports car and refers the old one as just being cute He also thinks new z4 is the real competitor of boxter s... God this was actually quite funny hahahahahaha...
