BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
EXXEL Distributions
      03-27-2024, 12:36 PM   #1
sahanMpower
19
Drives: E92 M3 S/C STAGE 2
Weird DCT downshift! Help!
Hey guys, I’m having this weird downshift that happen sometimes and what cause of it?
Mine is on SC and SSP clutch.
Here the video;
https://youtube.com/shorts/cnj07rC7A...5ZJFW-iEpjuYGm
      03-28-2024, 04:26 PM   #2
sahanMpower
19
bump
      03-29-2024, 03:35 PM   #3
M3SQRD
M3SQRD's Avatar
2468
Drives: E92 M3,G20 330ix,F22 240iX,F82
You’re basically running the motor at the lowest possible rpm in each gear to match road speed at 1k rpm between gears as you come to a stop. It seems the required throttle blips barely, if at all, raises the rpm to engage the next lower gear. It’s almost like it initially applied too little throttle and has to blip the throttle a second time to better match rpm-speed between gears. Is there a reason why you’re inching along at such slow speeds requiring repeated downshifts at 1k rpm?
Does it do this if you repeatedly pull the downshift paddle at, say, 2k rpm as you come to a normal stop? Not sure if this is a real problem or if it’s the DCT TCU having trouble matching speed and rpm between downshifts at 1k rpm?
m3post
