01-19-2024, 07:11 PM | #1 |
Rep 1
Have these 3 codes P00BC, P0171, P0174
I have a 2007 e90, i had a notification saying "engine oil level low add 1 quart" so i did that then i turned the car on and it started shaking then gave me a check engine light (P0304) misire #4 i knew it would be the coil because i changed all the spark plugs a couple months back but anyways i replaced the coil then turned the car on it started shaking then i turned it off to scanned it again then got those codes. Does anyone know what i could do to fix it?? Been stressing over this😅 dont know if i fucked it up by adding the engine oil and not do an oil change, would that fix it if i did it now? Lmk
