BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) F48 cold start rough idle
      06-10-2022, 02:43 AM   #23
ZEITGEIST74
Drives: BMW X1
I was having this exact issue on my 2016 X1 with 45k miles. I took it into a BMW dealership service department and told them I believed it needed a computer update from what I’ve read to fix the issue and was charged nearly $550 ($175 to diagnose) to fix the car. I’m pretty annoyed that they even charged me when it’s their software “glitch.” I’m rather shocked it wasn’t a recall as I don’t feel I should be out $550 to fix a problem that their own software causing the issue to begin with. Not happy about this at all… should I contact BMW about this or is everyone having to pay $550 or am I just a sucker. I feel like this could be a class action lawsuit. It’s also a dangerous issue since the car can jerk backwards or forwards if you’re not prepared.
      06-10-2022, 12:57 PM   #24
jrveron
jrveron's Avatar
Argentina
266
Drives: 2023 X3 m40i
Whaat!? That seems like a lot for only a software update!
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      06-22-2023, 07:56 PM   #25
crespo18
crespo18's Avatar
Drives: BMW X1 xDrive 2017
Hi, did someone finally know what was causing the rought idle at cold starting?
      07-02-2023, 06:01 AM   #26
jw9803
Drives: 2019 BMW X1 xDrive
Mine did this for a few months. It finally threw a code of 151001 - Ignition timing in idle too early after cold start. There is a service bulletin to fix the programming error in the DME. One year later after being re flashed by the dealer it has never happened again.
      01-19-2024, 09:53 PM   #27
ddiepo
Drives: Honda Fit, BMW X1
I have the same problem, it seems random but behaves exactly as described. Anyone know if this cost is typical for dealers? If so I'd be happy to try to do it myself if I can, but suspect I wouldn't be able to get my hands on the updated firmware or instructions.
      01-20-2024, 05:12 AM   #28
mrpingu
181
You could do it yourself. Need e-sys + full PSDZ data, circulating round on the interwebs and bmw forums.
Note full psdz includes all firmware files and is around 250GB
Then follow this guide:
https://www.bimmerfest.com/threads/f.../#post-8737312
      01-30-2024, 04:14 PM   #29
rice_rocket88
No_Country
298
Drives: E60 F48 F39
I've had no time to hit the dealership with the wife's car.. I just tell her to count to 30 before backing out her car. It is rather annoying though. I've done all the plugs etc etc and I'm convinced it's just the software update that's going to fix it. The dealer said the updates are free if I can point them to the TSB fixes I want.. if not it'll cost me.
IF somoene posts a better guide/link to all the files I would probably do this, but at this point I'm rather out of time to research all this and download everything and hold my breath.
      02-03-2024, 07:28 AM   #30
kvndng
Drives: 2017 bmw x1
I just had this issue and a CEL came on - it ended up being a faulty fuel vent valve
      03-29-2024, 08:10 AM   #31
wittyet
Drives: BMW X1
that sounds like my problem as well,
the fuel tank breather valve failed before the winter and I didn't replace it, and this winter this new symptom show up.
