02-19-2021, 07:56 AM | #1 |
Rep 18
BMW Style. 570M Wheels specification request please
Information required please - I have a set of four 570M 18" rims with tyres, TPMS & centre caps. These were removed from a X1 2.5D 2016 model.
Just had a potential buyer call but sadly he said the wheels wouldn't fit his X2 which is a 2018 model 1.5l He states his existing wheel stud spacing is 120mm whereas he states mine are 112mm The measurements for mine are - Hub centre hole max 7.3cm min 6.5cm (conical shaped) Stud centre to centre - adjacent holes - 6.6cm Stud centre to centre - non adjacent holes- 10.6cm Hub diameter 15.2cm Measurements taken with a rule as I cannot get a micrometer in place - too long Not sure from above where the 112mm stud spacing is measured? Any guidance welcome as I want to update the eBay listing to make sure it's 100% accurate . Departing comment from the chap was - "you are underselling - these wheels are in pristine condition- you should be asking more money" They are currently on eBay at £675. Thanks |
02-19-2021, 08:25 AM | #2 | |
Rep 910
I think he is wrong, they should be 112m in 5 bolt pattern exactly same as yours. Stud spacing is measurement from centre of bolt hole to centre of opposite bolt hole (in 5 bolt pattern use nearest opposite I.e next but one). As far as I am aware all X1/x2 (f48&f39) has same wheel bolt pattern regardless of manufacture date. |
03-02-2021, 10:52 PM | #3 |
266
Rep 648
I'm with MJE60.
As far as I know, all X1 / X2 have the same bolt pattern: 5x112. You can show your potential buyer these links: * https://www.wheel-size.com/size/bmw/x2/2018/ * https://www.wheel-size.com/size/bmw/x1/2016/
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD Last edited by jrveron; 03-02-2021 at 10:52 PM.. Reason: more information added |
