      10-31-2013, 04:54 PM   #1
TwinTurboed
Turbo Power
TwinTurboed's Avatar
51
Drives: 135i
Amount of fluids?
I want to change my transmission and differential fluids. How much quantity do I need for each of these? (Like 1 or 2 Liters?) Please help - Thanks!
BSM 135i - CDV Delete | Bilstein | Eibach | M3 FSB | Whiteline
      10-31-2013, 04:56 PM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
N54 or N55 ?
6MT or Auto or DCT ?
      10-31-2013, 04:57 PM   #3
TwinTurboed
Turbo Power
51
Drives: 135i
2010 N54 - 6MT ofcourse!
      10-31-2013, 05:08 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Engine holds 6.5 liters or 6.9 quarts of oil when changing the oil filter. BMW specs: any motor oil that has a LL-1 (Long Life 1) rating on it. 0w30, 0w40, 5w30, 5w40 motor oil.
Manual trans holds 2.1 liters of trans oil. You basically just keep adding fluid until it starts to spill out of the "fill hole" on the side of the trans. BMW specs: MTF-LT-3
Rear diff holds 1.2 liters of fluid. BMW specs: Castrol SAF-XJ
For the manual trans I use Redline ATF-D4 and for the trans I use Castrol SAF-XJ. Here are some links that might be of interest to you...
DIY: manual transmission and diff fluid change
http://www.1addicts.com/forums/showthread.php?t=409293
CORRECT 1M Fluids List [Engine, Transmission, Differential]
http://www.1addicts.com/forums/showthread.php?t=620282
      10-31-2013, 07:01 PM   #5
SayHack
SayHack's Avatar
37
Drives: 2008 BMW 128i
2008 BMW  [0.00]
I would suggest Redline MTL 75W80....been using it for 5 years now, both on my e82 as well as e36 M3....good quality stuff. (Use it both in diff and manual trany)
      10-31-2013, 07:49 PM   #6
TwinTurboed
Turbo Power
51
Drives: 135i
Thanks Dack! What do you say about using this fluid for the differential?
http://www.redlineoil.com/product.aspx?pid=133&pcid=4
And yea I want to use the D4-ATF for the transmission.
      10-31-2013, 07:53 PM   #7
TwinTurboed
Turbo Power
51
Drives: 135i
And I thought Castrol SAF-XJ was for M car differentials because they have an LSD.
      10-31-2013, 08:31 PM   #8
TwinTurboed
Turbo Power
51
Drives: 135i
You think I would be fine using that in the diff as well? Because everyone seems to run the 75W90 or 75W140 GL-5 gear oil?
      11-01-2013, 04:45 PM   #9
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
^^I think RedLine's 75W90 GL-5 Gear Oil - is a good oil for the diff. But I am using Castrol SAF-XJ at the moment. What did RedLine say?
I am using this RedLine 75W90 GL-5 Gear Oil in my "other" BMW. In my old e39 535i V8. I have put almost 100K kms on the car using this RL diff oil(of course I have changed it a few times every 40K kms or so).
Dack
      11-01-2013, 04:50 PM   #10
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
^^That's correct. SAF-XJ is backwards compatible for non M cars. It is also spec'd for M LSD use. Also for the US market BMW recommends Castrol SAF-XJ +FM(plus friction modifier) for use in M diffs(LSD's) to quiet the diff on low speed(parking) turns.
Name:  Castrol SAF-XJ diff oil  IMG_0381.jpg
Name:  Castrol SAF-XJ diff oil IMG_0378-1 (1).jpg
There is another Castrol gear oil that can be used in our cars(non M models), I think it is SAF-XO (?) but I am not 100% on this. I know there is another oil.
But frankly the Redline oils are very good oils - and I would loose no sleep running any of them in my car.
      11-01-2013, 08:14 PM   #11
SayHack
SayHack's Avatar
37
2008 BMW  [0.00]
I have only positive experience.
      11-01-2013, 08:55 PM   #12
TwinTurboed
Turbo Power
51
Drives: 135i
Thanks man. I think I am going with MTL 75w80 for the trans and 75w140 for the diff as it's similar to the Castrol SAF-XJ.
      11-01-2013, 09:06 PM   #13
TwinTurboed
Turbo Power
51
Drives: 135i
Dack
Thanks a lot for the help dack! I'll go with redline 75w140 for the diff as it's similar to the Castrol recommended by BMW.
One final question. I don't really live in cold weather, would I be better off getting the D4-ATF or MTL 75w80 for the trans? The Redline MTL seems similar in spec to the BMW MTF-LT-3
      11-02-2013, 02:13 AM   #14
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
I prefer the D4-ATF over MTL. I have been using the D4 for years in my (various)BMW's so thats why I run it.
      11-04-2013, 03:01 AM   #15
Alf_flash
Drives: 128i
Hello, are the engine oil amounts for a n52 or for n55 ?
How many liters does a n52 hold with a filter change ?
Thank you
      11-04-2013, 04:17 AM   #16
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Thank you
Yes, I believe they are the same. ...holds 6.5 liters or 6.9 quarts of oil when changing the oil filter. Look in your owner's manual to be sure though.
Checkout @JimD 's excellent DIY oil change thread...
First Oil Change on my 128i Convertible
http://www.1addicts.com/forums/showthread.php?t=301440
      11-09-2013, 02:21 PM   #17
siegester
siegester's Avatar
346
Drives: '20 M340i
2020 BMW M340i  [0.00]
Has anyone used the Mobil1 Synthetic Gear Lubricant LS 75W-140 for the diff? 2 quarts should cover it correct?
I am looking to change all the fluids in my 6MT n54 given I'm around 60k miles and read on some other sites that people like the M1. Given it's available locally and have had great experience with Mobil1 engine oils/filters, I was thinking of giving it a go.
Thanks.
      01-05-2024, 01:04 PM   #18
franciscold
Drives: 120i E87 N46B20
Hi guys,
Can anyone let me know the amount of fluids for FULL service (and which) go in a E87 120i LCI N46B20 AT?
The only thing I know at the moment is engine oil: CASTROL EDGE 5W30 LONGLIFE (my choice) - 4.25Lts
Thank you!
1addicts
