BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Introducing the BMW X2 M35i
      09-06-2018, 05:33 PM   #1
Jason
Administrator
Jason's Avatar
40841
Drives: F80 M3
BIMMERPOST NEWS
186
COMMENTS
302 hp and 332 lb-ft. BMW’s most powerful 2.0L TwinPower Turbo Engine.
xDrive with BMW’s first front axle M Sport limited slip differential and launch control.
0-60 mph in 4.9 seconds.
Start of production: November 2018 for U.S. Market.
September 6, 2018... Munich. Sportiness coupled with a polarising appearance – based on this formula, the new BMW X2 has inspired above all a young and modern target group following its premiere in March 2018. With its extroverted design, the BMW X2 interprets the character of a premium SAC (Sports Activity Coupes) in an entirely new way within the compact segment.
The top-of-the-range version of the BMW X2 is the M Performance automobile.
BMW is now presenting the new top model of the X2 series. The wide BMW double kidney grille of new BMW X2 M35i (combined fuel consumption 8.4-8.1 l/100 km; combined CO2 emissions: 191-185 g/km)*, features a surround in Cerium Grey for visual differentiation at first glance. Likewise, the surrounds of the air cooling inlets and the exterior mirror caps are finished in Cerium Grey. The rear of the X2 M35i is characterised by the standard M rear spoiler and two specially designed exhaust tailpipes, which also come in Cerium Grey.
BMW’s most powerful 2-litre TwinPower Turbo engine.
The new BMW X2 M35i featuring a 225 kW (306 hp) 4-cylinder turbocharged petrol engine definitely sets new benchmarks above the previous versions. As the letter M in the type designation clearly signalises, the new X2 M35i possesses the impressive dynamic handling qualities of an M Performance automobile. Behind this is yet again the BMW M GmbH, whose racing know-how flows into the development of all components. The 2-litre TwinPower Turbo engine concealed under an M Performance cover is the very first M Performance four-cylinder engine and at the same time BMW’s most powerful version. It delivers a fascinating maximum power output of 225 kW (306 hp). Maximum torque is an extremely powerful 450 Newton metres. To ensure that this sheer power is securely transferred to the tarmac, the X2 M35i comes as standard with intelligent four-wheel drive technology xDrive in conjunction with the 8-speed Steptronic transmission including Launch Control. The automatic transmission features specific M Performance tuning. Equipped in this way, the BMW X2 M35i is able to accelerate from 0 to 100 km/h in just 4.9 seconds*. The necessary thermal stability of the engine is now ensured by a redesigned cooling system.
Outstanding driving dynamics thanks to M-specific tuning.
Being a typical M Performance automobile, the BMW X2 M35i features, in addition to a powerful engine, also a M Sport suspension system that has been specifically tuned and adapted to match the car’s sporty character. A adaptive suspension offering two different manually adjustable modes and combining maximised sportiness and driving comfort is also optionally available. A particularly special technical highlight – and also a premiere for an M Performance automobile – is the M Sport Differential installed in the front axle gear. During highly dynamic driving manoeuvres, this locking differential most effectively reduces possible traction losses on the front wheels. In addition, the braking system has been upgraded for use on the X2 M35i. The M Sport braking system with fixed callipers in Dark Blue metallic and 18-inch steel discs at the front (17-inch at the rear) guarantees consistently short braking distances even under the highest loads. With that, however, the M know-how is still far from being exhausted. Steering and suspension have also both been adapted to match the performance of the drive system. For instance, thanks to a special setup, the M sports steering conveys to the driver an impressively direct and precise steering feel. Furthermore, the X2 M35i comes as standard with the M Sport suspension with a stiffer spring and damper setting as well as vehicle lowering. The rear axle construction has been redesigned. A suspension with an adaptive spring and damper combination offering two different manually adjustable modes is also optionally available.
Upgraded exterior design thanks to M Performance typical elements in Cerium Crey.
The sporty aspiration of the X2 M35i, which is the result of its inner qualities, is reflected in an exciting exterior design with numerous typical M Performance Automobile elements finished in Cerium Grey and based on the X2 M Sport Package. This begins at the front with full HD technology for the main headlights and fog lights and continues with the double kidney grille in Cerium Grey and the newly designed side air intakes of the same colour at the front for best possible cooling of brakes and engine. The exterior mirrors have been upgraded by special caps, likewise in Cerium Grey. At the rear, the X2 M35i boasts a distinctive M rear spoiler and demonstrates its fascinating sovereignty with an M Sport exhaust system with two tailpipes (each 100 mm in diameter). Thanks to the adapted silencer system, the exhaust system produces a particularly sporty sound spectrum. 19-inch M Sport light alloy wheels in 715M styling (optional: 20-inch M Sport light alloy wheels in 721M styling and in Cerium Grey bicolour) impressively round off the exterior design features.
For the first time Exclusive M sports seats ensure perfect seating comfort and lateral support.
An exceptionally sporty look also dominates the interior. As with the exterior design, the basis is again the M Sport Package. Moreover, the X2 M35i features as standard an M Sport leather steering wheel with shift paddles and door entry trims at the front bearing the lettering “M35i”. The optional M sports seats at the front are a novelty. They offer not only perfect lateral support for both driver and front passenger in sharp bends, but also the highest level of comfort and safety through integrated headrests. The M sports seats are available in the following three different designs: FabricTrigon/Alcantara combination in black with blue accents, Leather Dakota Magmared, perforated with black accents and Leather Dakota black perforated. Matching seatbelts in an M design are also on offer.
Trend-setting digital competence for state-of-the-art technologies.
In addition to the uncompromisingly sporty orientation of both drive system and design, the BMW X2 M35i also demonstrates BMW’s trend-setting digital competence in the areas of operation and networking. For instance, the full-colour BMW Head-Up Display is among the optionally available features. It offers a display range that is unprecedented in this vehicle segment. If desired, the latest generation of BMW ConnectedDrive and the new BMW Connected App can be fitted. Optional functions such as the wireless use of Apple CarPlay set further highlights. Driver assistant systems include, for example, camera-based technologies such as the traffic jam assistant for less tiring driving in dense stop-and-go traffic or the optional parking assistant.
Start of production is November 2018, for European markets not until March 2019.
BMW X2 M35i
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
Appreciate 6
Hedoniste3834.00
Pavit50.00
JustChris17487.50
Zuzu2816.00
      09-06-2018, 05:42 PM   #2
Hedoniste
Hedoniste's Avatar
3834
Drives: M2 CS | M135i
2020 BMW M2 CS  [10.00]
Nice!!
2020 M2 CS DCT
2021 M135i xDrive
ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe
      09-06-2018, 05:46 PM   #3
E90705
E90705's Avatar
127
Drives: E90/F25 M-sport
Wow I
      09-06-2018, 05:47 PM   #4
goj
goj's Avatar
2253
Drives: 2016 EBII 340i 6-MT
Wow. This is seriously cool
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      09-06-2018, 05:47 PM   #5
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
Yes please!!!!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      09-06-2018, 05:49 PM   #6
Kirbbz
Drives: 2014 BMW M235i
this is so disappointing to me. I wanted to get an X1 with the 3.0l n55 but they only offered that car with the 6 speed auto, I wanted the 8 speed zf, my hope was the x2 35i would have the 3.0l with a zf8 and they downsized it to a 2.0l
hoyasaxa702.00
      09-06-2018, 05:49 PM   #7
KikeBMW
KikeBMW's Avatar
41
Drives: F36 440i ZTR
Those seats though
      09-06-2018, 05:51 PM   #8
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
25083
Drives: A Car
Love the red seats! They look like the ones from the Z4. Hopefully BMW starts doing this in new cars like the upcoming M340i.
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
      09-06-2018, 05:52 PM   #9
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
I want
      09-06-2018, 05:53 PM   #10
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
You get an ///M Model!
And you get an ///M Model!
Everyone gets an ///M Model!!!
Appreciate 19
      09-06-2018, 05:54 PM   #11
DG20
DG20's Avatar
967
Drives: M340i
Looks awesome!
Instagram: @dg_g20
      09-06-2018, 05:54 PM   #12
psuibmw
psuibmw's Avatar
3483
Drives: G06/G20/F30/F15/F10/E90
2018 BMW 320xi  [10.00]
2023 BMW M340  [9.75]
2022 BMW  [10.00]
The seats are really cool nothing else
      09-06-2018, 05:54 PM   #13
werdn
werdn's Avatar
656
Drives: 997.1 GT3 Shark, ex E92 M3 ZCP
If it is going to be running on the N55, then its time JB4 another car ��
      09-06-2018, 05:57 PM   #14
arciga18
arciga18's Avatar
1729
Who has the ordering guide
      09-06-2018, 05:57 PM   #15
clbmw
633
Drives: 320d M135i
I'm intrigued about the LSD but I suspect this, being a FWD-dominant transverse engine setup, will feel very different to every other M performance car to date.
hoyasaxa702.00
      09-06-2018, 05:57 PM   #16
ghaffari46
1120
Drives: bmw m3 e90
Now we are talking!
      09-06-2018, 06:03 PM   #17
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3509
Drives: 2024 iX 50 | 2020 X3 M40i
Well they couldn't fit a 3.0liter in it anyway because it's a transverse engine.
ZHPsedan135.50
      09-06-2018, 06:05 PM   #18
JayPichardo
BMW Client Advisor
3452
Drives: 2020 M340i
Not published yet I went and looked
arciga181728.50
Ikester192124.00
      09-06-2018, 06:05 PM   #19
tambat
Do it for a living.
tambat's Avatar
60
Drives: F80 MG M3 m/t
its the 2.0 b48
Blubaron791434.50
      09-06-2018, 06:06 PM   #20
cwulffy
150
Drives: F30
That interior!
      09-06-2018, 06:09 PM   #21
arciga18
arciga18's Avatar
1729
Thank you. I am really close to ordering a 30i x4 this will change the plan a bit.
      09-06-2018, 06:10 PM   #22
Red Bread
4463
Drives: Smog machines
Loved our X1 35i. Have owned a few cars with the 8s and the 6s wasn't really any worse.
Have to say that this drivetrain is actually kind of appealing compared to a one wheel drive non M rwd setup or regular X Drive. My DD GTI with a mechanical LSD is actually surprisingly fun, add some power xfer to the rear and it could be quite good. The Golf R foolishly doesn't keep the mechanical front LSD.
