2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Audio Upgrade Suggestion and problem
      01-24-2013, 06:14 PM   #1
Stormbitch
330
Drives: G11
I had Western Car Audio, Bristol come up with an idea to replace my front mid range, add two tweeters and power the under seat subs and the result is stunning. Using Focal components.
Same sort of sound as the Alpine Upgrade that was available before. Or better. Same sort of money too.
Now though, my parking sensors, and my BMW gong! is far too loud through the system, sometimes I jump out of my skin.
Surely there is a solution to only amplify the music. Any ideas?
      01-25-2013, 03:40 AM   #2
JD-IRL
Ireland
Drives: F11
There is a setting in the iDrive to turn the volume of these down. I'm not near my car at the moment but I think its in Main Menu , then settings and then tone. PDC and Gong are in there ( I think)
      01-25-2013, 04:00 AM   #3
xenon
xenon's Avatar
1397
Drives: 2021 G21 330i M-Sport
Indeed ^
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      01-25-2013, 04:52 AM   #4
Stormbitch
330
Drives: G11
They are on the minimum already !!!!!!
I think what has happened is the amp has been fitted to amp everything via the I Drive. Perhaps they weren't sure on how to wire the existing sounds to the head unit amp and leave the other output for music - maybe there is no way to fix it.
      01-30-2013, 05:51 AM   #5
JD-IRL
Ireland
Drives: F11
Yeah I'd talk to the chaps at WCA and see what can be done - I can only imagine the volume of the bings and warnings
Any chance you could PM the cost of your upgrade. I have the business audio upgrade and I think its pretty poor in terms of sound. Was thinking I might get an upgrade to improve the setup.
Cheers
JD
      01-30-2013, 12:14 PM   #6
Stormbitch
330
Drives: G11
Yep the Focal Speakers were £250 ish and I had an amp already
But if you said to them - WCA - could you do me a £550 upgrade same as the old BMW alpine , they might be able to help - I call this stage one.
I think I paid £450 but then note I already had the AMP - Ebay has millions of unwanted amps being sold by total anoraks who want the latest.
It is so much worth it - Definately worth spending £500 - £600 to start with and under a £1000 will prob add mental bass under the seats. Which I might add.
ALWAYS keep bass INSIDE a car... or it unbalances the sound. In the f10 you want to keep it "hi fi" BMW ish
BTW they fixed my issue... FREE!!!!!!!! OMG!!!!!! It was a setting.. nice quiet gongs now.
      01-31-2013, 05:50 AM   #7
JD-IRL
Ireland
Drives: F11
Cheers Stormbitch - thanks for the info. Defo food for thought.
Also glad you got the issue sorted
JD
      02-13-2013, 07:22 AM   #8
330cdsport
Right Responsible
330cdsport's Avatar
58
Drives: AW F21 M135i
When I did my full upgrade I also had the bongs and reverse beeper etc too loud. I just had to turn the levels down on the amp to balance the system better.
See post #3 from this thread for my upgrade details:
http://f10.5post.com/forums/showthread.php?t=609603
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      06-09-2013, 10:03 AM   #9
BeeQuu
Drives: F20 525D 2011
SB: Could not answer ur PM so have to put it here:
I am planning to replace the standard speakers in front doors and the speakers in the rear parcel shelf. Found some Top HiFi speakers with separate Top HiFi tweeters. Planning to buy these and see what difference this makes.
If not good enough, i can install a amp and / or replace the subs.
5post
