02-01-2024, 10:24 AM | #1 |
Rep 6
Maintenance Schedule Costs
Hi All - I have a 2018 X1 (F48) and located in Calgary, Canada.
I've been trying to find maintenance schedules and costs but haven't been able to find the costs yet. I found some schedules below, but does anyone know how much these would cost. I'm not sure what the going rate is for these. • Every 10,000 miles, or yearly: replace engine oil, oil filter, and coolant • Every 20,000 miles, or every two years: inspect and replace fuel filters • Every 30,000 miles, or every three years: • Replace brake fluid (after the first replacement, every 60,000 miles) • Replace transmission fluid on manual-transmission BMWs • Every 60,000 miles, or every six years: • Replace engine air filter and spark plugs • Inspect and replace brake pads and brake rotors, as necessary • Replace transmission fluid on automatic-transmission BMWs • Every 90,000 miles, or every nine years: replace timing belts and hoses BMW X1 Maintenance Schedule Mileage Recommended Maintenance 15,000 Cabin Replace Air Filter, Change Oil and Filter 30,000 Service Battery/cables, Lubricate Trunk, Transfer Case Fluid Replacement, Cabin Replace Air Filter, Change Oil and Filter 45,000 Cabin Replace Air Filter, Change Oil and Filter 60,000 Replace Air Filter, Service Battery/cables, Lubricate Trunk, Transfer Case Fluid Replacement, Cabin Replace Air Filter, Change Oil and Filter 75,000 Cabin Replace Air Filter, Change Oil and Filter 90,000 Service Battery/cables, Lubricate Trunk, Transfer Case Fluid Replacement, Cabin Replace Air Filter, Change Oil and Filter 100,000 Transmission Fluid Service, Spark Plugs Replacement 105,000 Cabin Replace Air Filter, Change Oil and Filter 120,000 Replace Air Filter, Service Battery/cables, Lubricate Trunk, Transfer Case Fluid Replacement, Cabin Replace Air Filter, Change Oil and Filter, Oxygen Sensor Replacement 135,000 Cabin Replace Air Filter, Change Oil and Filter 150,000 Service Battery/cables, Lubricate Trunk, Transfer Case Fluid Replacement, Cabin Replace Air Filter, Change Oil and Filter |
02-01-2024, 07:44 PM | #2 |
Rep 5
Hey there! My own experiences might not match up to you, I live in Virginia so costs for labor on a BMW might be wildly different.
Whenever I have maintenance performed at my local shop I always buy the parts / fluids myself beforehand from FCP Euro. If you haven’t been there before check it out online, it’ll give you an idea of what the materials will cost. As for labor, kind of just depends on what job they’re performing. An oil change for me is only $25 since I supply the oil and filter. Cabin air filter change was $40 plus materials on FCP Euro. Spark plugs and coil packs, maybe $150-200 plus parts. |
akyyc0.00 |
02-01-2024, 07:53 PM | #3 |
Rep 5
Oh yeah one more thing, my battery died at almost exactly 60000 miles. Since it has to be installed / synced to the car or whatever I just had the dealership do it, it was like $730 all-in (parts and labor).
02-04-2024, 08:13 PM | #4 | |
56
Rep 152
Drives: 2018, F48 28i
If you are good with DIY projects. That will be the cheapest. But the price still depends on how you source your parts. There are many parts company you can buy on line. I find Rockautos in the State and Parts Avatar in Canada have lowest prices. If you bring your parts and let the local shop do, the jobs will be in the second place. The expense will be in the middle. Dealership will be the most expensive. |
akyyc0.00 |
02-06-2024, 08:02 AM | #5 | |
4443
Rep 7,486
The Bimmerlink & Bimmercode apps along with the OBD II BT Veepeak adapter probably came to approx $100. That's still comes in less than $730. But if one can't swap the battery themselves due to not having any tools or software...then the cost is more to have someone else do it.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-06-2024 at 08:29 AM.. |
02-07-2024, 03:06 PM | #6 |
16
Rep 1
BMW is running a promotion (idk till how long) and I got my battery replaced for 490 US$ all inclusive. https://bmwusaservice.com/batteries
I am fairly handy, but considering my time and total cost otherwise, it was a fair price. |
02-08-2024, 07:46 AM | #7 |
Rep 44
Drives: BMW x1
In the uk my personal experience is that a main dealer cannot/will not retail anything that doesn't have a full main dealer service history and a low mileage, sending what should/could be a perfectly good part exchanged car, goes direct to the auctions
