BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) X1 F48 Front windscreen washers - is there a check valve?
      01-25-2024, 01:37 AM   #1
johndpar
Drives: BMW X1 F48 XDrive 20i M Sport
Hi
Our '21 model year X1 seems to have a problem with the front washers.
On first use after standing for a while, you have to hold the washer on for a few seconds before the fluid comes out. When it does come out all three jets operate normally.
The rear screen washer is working correctly.
Do these care have a separate check valve or is it built into the jets or the pump?
Many thanks
John
      01-26-2024, 08:24 AM   #2
johndpar
Further investigation shows the check valves are built into the 3 jets
I've now take an close look at the jets and I can see and hear that the left hand jet is to blame.
Trouble is that it seems to be part of a single assembly, combining the fluid pipe and the wiring for the heaters.
Any suggestions?
Thanks
John
