12-13-2020, 05:09 AM | #1 |
Rep 28
Strange headlight issue F48 lci 18i
Hi,
Just took deliver of used 2019 x1 18i lci The headlights are whatever comes with the tech pack 2...believe they are the led adaptive lights Sidelights on everything looks fine When dipped headlights on I get a really obvious pattern on the unit Its like 8 circles (4 ontop and 4 directly underneath) that looks like its being projected onto the unit itself Its actually quite hard to get a picture of but it's really obvious in person Does anyone else have this? Or any idea what's causing it It doesn't seem to affect the actual functioning of the lights but I just looks a bit odd |
12-13-2020, 10:50 AM | #2 | |
Air Vice Marshall
256
Rep 1,639
They are dirt/traffic film on the outside of the lense and these can be cleaned off with a cloth.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium Last edited by Peter_R; 12-13-2020 at 11:01 AM.. |
12-13-2020, 03:24 PM | #3 | |
Rep 28
Ive noticed quite a bit of condensation in the unit as well but i think thats also fairly normal - i'll keep an eye on that though |
12-13-2020, 05:26 PM | #4 | |
159
Rep 458
One consideration though is that because LED units run at a very much cooler temperature than other type headlights (halogen etc), during any winter snow the light units can become covered whilst it is actually snowing. I found that it also doesn’t really help if slush is thrown up from the road because there’s little, if any, melt from the heat inside the headlamp units. If I am to buy another X1, I would hope to be able to spec it with headlamp washers. I wonder if anyone has found that a product such as (in the uk) Rainex might help if applied to the outside of the light units, assuming it can be used on plastic headlights. I do use Rainex on the driver and front passenger side windows and it helps quickly shift any rain when driving although I found that on a previous car it was not good if used on the front screen. |
12-13-2020, 05:48 PM | #5 | |
Rep 28
both sides had some condensation, the fogging near bottom cleared quite quickly but the condensation along the top seems or be there almost all the time (has been very wet since I got the car though) Last edited by callum_62; 12-13-2020 at 05:56 PM.. |
12-13-2020, 06:48 PM | #6 |
159
Rep 458
I’d be heading back to the dealer with an issue such as is evident from those photos. Just be sure to take the pics along with you - presumably they’re on your mobile phone.
12-14-2020, 11:55 AM | #8 |
Rep 28
I've sent these pics to local BMW dealer.
I'm not overly fussed regarding the light misting we get but the issues towards the top of the unit look more of a problem to me |
12-14-2020, 02:49 PM | #9 | |
678
Rep 910
12-14-2020, 09:27 PM | #10 | |
Rep 28
What would lead you to believe the car was involved in an accident? |
12-14-2020, 11:20 PM | #11 |
56
Rep 152
Drives: 2018, F48 28i
Pls find the following link for your reference.
https://www.2addicts.com/forums/show....php?t=1593335 https://www.2addicts.com/forums/atta...8;d=1552829522 I had the same issue after one year on my 2018 f48. BMW dealer tried to dried out and did wet test and released the car to me saying that it's ok. But after one week I washed the car and it happened again. The dealership tested and had to replace the right headlight unit. It's best to have them checked out. |
12-15-2020, 01:11 AM | #12 | |
678
Rep 910
- the units may not be completely sealed (in the sense that they are designed to be accessed) however they are still relatively new and are designed and sealed to handle severe weather and road conditions without allowing easy water ingress, and - I am not aware the problem you are having is at all common even with cars older than yours, and - a problem with one unit could be a small manufacturing defect, problems with both make that less likely, - with the other issue I therefore suspect the units might have been badly handled, possibly removed and refitted and/or water protection compromised. An accident and repair is a possible explanation and given the car is a recent purchase and the units very expensive to replace I merely suggested you check (if not declared), especially given warranty and consumer protection. Good Luck, I hope it is easily sorted. Last edited by MJE60; 12-15-2020 at 01:27 AM.. |
12-15-2020, 02:23 AM | #13 |
Rep 28
[QUOTE=MJE60;27017423]My reasoning is;
- the units may not be completely sealed (in the sense that they are designed to be accessed) however they are still relatively new and are designed and sealed to handle severe weather and road conditions without allowing easy water ingress, and - I am not aware the problem you are having is at all common even with cars older than yours, and - a problem with one unit could be a small manufacturing defect, problems with both make that less likely, - with the other issue I therefore suspect the units might have been badly handled, possibly removed and refitted and/or water protection compromised. An accident and repair is a possible explanation and given the car is a recent purchase and the units very expensive to replace I merely suggested you check (if not declared), especially given warranty and consumer protection. Good Luck, I hope it is easily sorted.[/QUOTE Thanks, I've sent the info to local BMW. Car was purchased via BMW approved dealer so shouldn't be an issue either way Been raining here overnight and it appears no condensation in the unit this morning, see how they look after todays school run |
MJE60678.00 |
12-15-2020, 04:23 AM | #14 | |
Rep 28
As my units had no condensation this morning the dealer is claiming that's proof enough they are functioning as normal I guess that sort of makes sense but now after coming home a hour ago - both units have condensation along the top end with the LHS unit also alot of misting along the side |
12-15-2020, 09:01 AM | #15 |
56
Rep 152
The condensation was come and go. But they stayed there after parked in the rain or the car wash. Mine was big droplets were there some time. I showed them the photos.
Keep monitoring them and take photos. Weather might play a role. Hope you find a solution soon. |
12-16-2020, 03:43 AM | #17 | |
Rep 28
The default position appears it be condensation with the occasional brief clearance. That can't be right Again the morning after a 20 min school run with lights on we have mir emusting that when I left but the top of the unit seems to be holding alot of water droplets Its not allowing me to upload pics at the moment but will later |
MJE60678.00 |
12-16-2020, 06:19 AM | #18 | |
678
Rep 910
Good luck again |
12-16-2020, 02:10 PM | #20 | |
56
Rep 152
