04-29-2022, 05:55 PM | #23 | |
19
Rep 184
With the x5 10 .25 Navi Monitor |
04-29-2022, 09:32 PM | #24 |
Rep 124
Thanks for the reply Fast35i.
Are there straight forward instructions for coding the cluster anywhere? I have the software but have not coded myself, but am savvy enough to figure it out if I have a guide. Fallback: who is the cost-conscious go-to for remote coding tweaks like this? Btw- there actually is a 10” screen made for the X1’s, so you don’t have to adapt from another car if you can get your hands on one of these. They were sold in parts of Asia, no where else from what I could tell. It’s touch screen and works flawlessly with the whole interface including CarPlay. I didn’t know this until stumbling across it, was planning a retrofit from another car too, originally. |
07-14-2023, 02:55 PM | #25 |
29
Rep 69
Drives: BMW X1 F48
Guys,
To perform the retrofit basic cluster to 6WA what is needed in terms of Esys code? The scenario is as follows: New or virgin cluster, MOST cable connected to ENTRYNAV headunit with navigation (S6UNA). I would like to install the new cluster and activate Navigation Plus (S6UPA). Thanks, |
07-31-2023, 04:56 PM | #26 |
29
Rep 69
Drives: BMW X1 F48
Now all that's needed is coding.
07-31-2023, 05:36 PM | #27 |
181
Rep 595
08-14-2023, 06:06 PM | #28 | |
29
Rep 69
Drives: BMW X1 F48
In ISTA shows no communication. I don't know what else to do. Most cable is connected and shows red signal in both directions, from HU to Cluster and from Cluster to HU... |
08-15-2023, 08:18 PM | #29 |
29
Rep 69
Drives: BMW X1 F48
The problem was the MOST cable.
The fibers were inverted, so after correcting it was possible to easily code. Is beautiful. I liked the analog + digital look. Now it is Ok to receive headup display 🫣 |
iceman7117.00 |
08-16-2023, 12:32 AM | #30 | |
181
Rep 595
Remember for head-up you also need to replace your windscreen. Just that got me thinking: The amount of money you are pouring into this vehicle is massive, wasn’t it better to buy a more featured car? What is the reason you choose to retrofit this much? |
wcruzeiro29.00 |
08-16-2023, 02:32 PM | #31 | |
29
Rep 69
Drives: BMW X1 F48
But you are right it is a considerable amount of money. Next year maybe I will looking for another toy. =D |
08-16-2023, 02:49 PM | #32 | |
181
Rep 595
235 Towing hitch done 5DP Parking Assistant in progress 674 Harman Kardon in Progress But some things like new cluster, newer gearstick and Comfort Access. I just dropped because too much work involved. But I agree it’s cool to learn. HUD is one the things I don’t think is worth retrofitting because you need to replace your windscreen and change the whole dashboard trim that why I bought it with the car. Comfort Acces is not worth it because you need to program the keys and install many antennas however I would have liked the feature but can live without… Just keep me updated with your progress it’s cool to see what you are doing, impressive job so far. |
wcruzeiro29.00 |
08-16-2023, 03:21 PM | #33 | |
29
Rep 69
Drives: BMW X1 F48
Yes, it is necessary to change the windshield but in my case I will solve 2 problems because it will also be possible to add Kafas. Both are on the way =D And this feature was never offered in the Brazilian market for the F48, so it will be a unique project. About the trim, from what I researched it is possible to cut and install the HUD. There are some markings of where to be cut inside. Confort Access, I have my doubts if it is necessary to change the key or if it just needs to be reprogrammed. But I agree with you, it's something I can live without. Certainly, while I'm doing the retrofits I will post here and also looking for tips. |
mrpingu180.50 |
08-17-2023, 03:45 AM | #34 | |
181
Rep 595
You made me thinking; Comfort acces can be retrofitted without too much cost, just lots of time from what I understand. Because the wires run all over the car but otherwise doable. It's just adding the antennas/aerials + change door handles and run wires to the BDC. If you are lucky you already have the correct wiring loom in the door and you only need to source/replace the handles and run wires from the door connector to the BDC. Smart trunk opener is a little bit more work but not too bad either. Going to do a pin check on BDC & door wires soon. |
wcruzeiro29.00 |
09-05-2023, 03:20 PM | #35 |
29
Rep 69
Drives: BMW X1 F48
Guys,
If you're wondering if there's a problem with the MOST Cable, it's easy to check that the unit is sending a signal at both edges. Just unplug one side and check for the red light signal. One lane sends data and the other receives, meaning only 1 will be lit on each side when you do this test. Make sure both sides are not sending or receiving a signal in the same lane or it will cause the ECU communication fail as mentioned above. Also check if the MOST cable is properly connected to the headunit. |
02-08-2024, 03:31 PM | #36 |
Rep 37
I hope for your support...
I made a mistake when re-soldering the LEDs (from orange to white) and broke my Cluster, so I bought a brand new, unused black panel Cluster. I have read sooo many threads... one says coding... the other says no coding necessary... the other with MOST cable... I have the smallest Cluster, only a small digital display in the middle, no HeadUP either. I'm sure it won't be a simple conversion and that's it? May I ask what kind of coding I need to do? FDL under the station wagon? If so, what needs to be changed to what? 6WA 6WB does not work as this is not supported by the F48. Can someone provide me with some kind of instructions? |
