02-03-2024, 07:18 PM | #1 |
Rep 6
low-gas chime gone after AvinUSA headuit retrofit
I did the AvinUSA headunit retrofit on my 2016 F48, after watching install videos by BMW DIY Guy and a few others.
On the whole it's good: A bit of jankiness where sometimes CarPlay comes on automatically (which I want), but it's not 100% reliable, sometimes takes a few keypresses to get from Android OS screen to CarPlay. Here's my problem: It took me a while to notice, but it seems like I've busted some communication in the car when I installed the headunit. Things I've noticed:
Any thoughts on what might be going on? The only programming I did was change displays size and resolution. I had a really hard time squeezing the new headunit control box in with all the wires on the install... worried I've broken a connection somewhere. Figured I'd check in with folks here before I dis-assemble everything, has anybody else experienced anything like this? Is there a certain cable I should keep an eye on when I do try and un-assemble and re-assemble everything? thx! |
02-03-2024, 07:21 PM | #2 | |
3075
Rep 3,022
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
GaramondBold3.00 |
02-03-2024, 07:33 PM | #3 |
Rep 6
Re: Green optical cable -- ah, is that the one to check? I'm 99% sure that I transferred it, but maybe it wasn't seated properly? (Hope I didn't bust it as I was trying to jam everything it... it was a crazy-tight mess of wires as I tried to squeeze the 2nd box behind the console.)
While I have you -- Any tips/experience on getting CarPlay to boot up more reliably when the Avin headunit first boots? I've figured out the workaround of manually launching Z-link app if it doesn't boot at first, but wish it was more reliable/consistent. thanks for the fast reply. |
02-04-2024, 07:56 PM | #4 |
56
Rep 151
Drives: 2018, F48 28i
I had the same issue with my after market android screen. I did try all the possible means to boot up faster with no success.
At last I had my firmware update plus Carplay activation remotely coded. It's well worth it. But of course your head unit must have wifi built in. I don't know where you live. Most f48 in North America have head unit with built in wifi. Kubex86 from Bimmer remote coding did the work on mine. Now car play connection is very fast. I disable all the apps on the android screen. |
GaramondBold3.00 |
