BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Sunroof Track Lubrication
      08-03-2020, 01:52 PM   #1
adi555
Drives: F48
Hi, I've cleaned the tracks but can someone help me where to put the grease. Attached photo for reference.
Thanks
      08-03-2020, 02:29 PM   #2
adi555
Drives: F48
Tried to get a better photo. Could someone guide me which is responsible moving of the roof. Green or Red?
      08-03-2020, 02:35 PM   #3
Skyline2.0
Drives: 2018 BMW X1 xDrive
I apply the lubricant in the U shaped track that exists under the exterior weather stripping, which looks like the green circled area in your 2nd photo. Also, I spray the metal spring that extends/retracts the wind deflector.
You can also probably lubricate the red circled piece without any issues.
See attached photo. My pen points to the track that I'm referencing.
      08-03-2020, 02:44 PM   #4
adi555
Drives: F48
Thanks! What lubrication do you use? Also will lubricating fix shuddering problem?
      08-03-2020, 03:06 PM   #5
Skyline2.0
I use white lithium grease from a spray can. An appropriate silicone based lubricant should be fine. Don't use anything petroleum based as it'll deteriorate the rubber seals. BMW also sells sunroof lubricant (BMW Part # 83192157321) if you want to be sure you're using the correct product.
I don't know if it'll fix your problem. Apply the lubricant and see since it's cheap enough and a good maintenance item anyway.
      11-15-2020, 01:55 PM   #6
Sphinx144
18
Drives: 2016 X1
Did you get this done?
I have the same issue where the panoramic sunroof makes noise and moves slower than usual.
