08-03-2021, 11:01 AM | #1 |
108
Rep 201
did my detailer just ruin my paint?
So after owning my car for 10 years I decided to take it to a detailer to get it paint corrected and ceramic coated. This car has been babied and the paint was still factory fresh and free of any chips, dings or scratches. I have always kept the car indoors with a cover on and washed it after every use. It has less than 30,000 miles on it but started to get some swirl marks that I couldn't get out. After checking local detailers, I decided on one with a perfect google rating (200+ reviews) who does high end cars. Last week he texted me to say the car was complete but that they had a minor issue with the paint correction and that they cut through the clear coat on the crease above the wheel on the front fender. Thinking that if it was just the clear coat, it shouldn't be too noticeable, I went to the shop to have a look. They actually cut all the way through the paint into the plastic fender. There is a black line about 1 inch by 1/8 inch in the paint. The only way to fix it is to repaint the entire fender in my opinion. I'm not paying the detailer until this is fixed to my satisfaction. The cost to repaint the fender is probably more than I owe the detailer. Getting a perfect paint match (color and texture) will be difficult so this is likely the start of what will be a lose/lose solution. So pi$$ed right now. Is BMW paint "soft" - has this happened to anyone else?
2010 M3 "Edition" model - Monte Carlo Blue/black, (1 of 13) MODS;255/35/19 and 285/30/19 Michelin PSS, Volk G25 wheels, MC V2 GTS lip, Eventuri plenum/intake/airbox lid, M Performance exhaust/spoiler/steering wheel
08-03-2021, 11:30 AM | #2 |
289
Rep 556
I have done my own paint correction for years and never ran into this problem. This can happen when you leave the polisher in one spot too long or the edge of the pad hit that spot. Most shops should be able to blend the paint correctly and won't notice it. The bad part is that the resale value of the car is not diminished.
08-03-2021, 03:49 PM | #3 |
163
Rep 183
Drives: 91 M5, 98 M3, 08 M3
sounds like the detailer was using a rotary polisher (which isn't a bad thing), but they are known to burn through paint when used improperly.
Hopefully they can blend your paint properly and color match the car. Good luck |
08-03-2021, 04:07 PM | #4 |
268
Rep 350
Have any photos? I agree with the detailer using a rotary. My guess is he probably thought it was an easy job and assigned it to one of his employees that doesn't have much expereince.
Take it to a high end body shop and see what they say. My guess is at the very least, they will need to blend into your door to make the repair nearly undetectable. ~$1100-$1500 US |
08-03-2021, 10:37 PM | #5 |
266
Rep 526
The paint had to be incredibly thin to begin with for even a rotary to burn through it all the way. They should have metered the paint out to know better. As detailers we've all made mistakes, just have to step up to the plate and fix it.
08-03-2021, 10:53 PM | #6 |
11592
Rep 12,736
lets be honest here- a dealership detail is going to be some grunt with questionable experience with a harbor freight polisher.
find a guy that doesn't eat if he doesn't get repeat business and works for that tip.
Instagram; @roastbeefmike
08-04-2021, 03:53 PM | #7 |
1542
Rep 3,332
The qualified guys might've been too busy doing the lambo's to work on your car?
Sounds like a crappy situation, unless they are willing to cover the respray you may just be better seeing if they can get some touch up paint and touching up the damage rather than trying to respray and blend the whole panel. I would say if they really botched this up it should be on them to fix, and if they detail exotic cars they should have a relationship with a qualified body shop. I'd see what they offer you.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
08-04-2021, 04:16 PM | #9 |
661
Rep 967
Such a shame. Make sure he fixes it. Paint preservation is more important than paint perfection. Color matching that is going to be a nightmare.
c.riedinger0.00 |
08-04-2021, 08:13 PM | #10 |
289
Rep 556
For what it's worth, I've detailed many cars in my time from Mercedes, VW, Audi, and many BMWs. BMWs have some of the hardest paint to work on. For them to do what you described, they had to use a total amateur for the job.
01-29-2022, 08:34 AM | #11 |
687
Rep 1,231
Bmw paint is extremely hard. Takes a total armature to burn through as stated above. 100% chance they had someone learning on your car unsupervised, unacceptable. In situations like this remain cool and just be friendly but assertive. I wouldn't worry about matching paints. When they fix it you will be satisfied.
01-29-2022, 09:08 AM | #12 | |
mTekMods
2157
Rep 2,909
maybe the fender was repainted at some point?
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
02-04-2022, 01:14 PM | #13 | |
764
Rep 449
They either didn’t know what they were doing or it has been repainted. Proper shops should be insured for exactly this situation. Keep us posted. |
03-11-2022, 03:57 AM | #14 |
308
Rep 308
Drives: 2008 BMW M3
I dread letting others work on the car, unless I know who is doing it. I'll ask who will be working on my car and if I can, I'll watch it. I've been taken advantage of when I was younger by shops like this.
03-23-2022, 09:48 PM | #15 |
108
Rep 201
Just a follow-up on this.
I talked with the shop owner about how he intended to correct the situation. He is a BMW enthusiast with a M2 Competition so he knew something about how anal some BMW owners like me are. He knew a paint specialist who was able to spray color and clear onto the burn mark. After waiting a month for the paint to set he reapplied the ceramic to the entire fender. It is now impossible to see where the repair was. Perfect paint match. Believe me, I tried to find it using a fluorescent light and magnifying glass from every angle and in sunlight. I know that there are paint magicians out there who can do unbelievable things but I am amazed at this. Happy ending.
Bimmer Barney1250.00 jun_e92140.50 |
01-26-2023, 04:58 PM | #17 | |
1889
Rep 5,506
It is a pain in the ass to keep swirl free even with pre wash foam, 2 bucket method, wool mitts and air drying. That said, it will correct easily with just a finishing polish and pad.
Auto Detailing Enthusiast!
