09-23-2022, 06:41 AM | #1 |
Retired from BMWNA
198
Rep 184
Battery dead-no warning?
Due to being away from my home unexpectedly, I came home after a couple months and my battery was completely dead in my x2. Is there nowhere in the instrumentation on the dash that would show you with the voltage? Moreover, all the while my Bmw app told me everything was OK every time I looked at it when I was away… Shouldn’t that app give me a warning that I was down to a unsafe level of the battery?
Glen
Ft Lauderdale '23 228i GC |
09-23-2022, 08:52 AM | #2 | |
66
Rep 214
As an aside, a lot of modern cars, including the X2 that are connected to the cloud at all times, have a continuing commensurate drain on electrical. With my experience with my X2 over the last about year now, I wouldn't expect the battery to have enough juice to start the car after 2 months of it sitting. If I had to store the car for more than say, 3-weeks, I'd have a battery tender on it or failing that, disconnect the battery while I was gone. Good luck!
‘22 X2 S-Drive. Running 13mm Wheel Spacers & 255-wide 'go-flat' tires.
Former Owner '11 X5 35d w/Sport Package Former Owner '86 528 |
09-23-2022, 10:41 AM | #3 |
298
Rep 1,079
Yeah I'd say the app wouldn't have a spot to warn you, and I agree that 2 + months is not great, although if it was in FL where it is hot where you live I would have thought it would get more like 3 months. My 5 series wouldn't like more than a month and a half (when I too traveled and didn't use the car) It didn't have the connected app, but it would go through a new battery every 3-4 years. (they have a history of using a lot of power for all the features).
09-23-2022, 11:12 AM | #4 |
Retired from BMWNA
198
Rep 184
my biggest gripe is the app….with the batt totally dead it was still reading “ALL GOOD”….what a crock…the app should ding you when the batt goes below 12.0 or so……
Glen
09-23-2022, 11:23 AM | #5 |
298
Rep 1,079
I agree the app really sucks, there's not much info there. I have compared it to other friends with Kia, Subaru and Honda and I believe the BMW app has the least amount of info. I turn it on once in a blue moon when I think I might have left the door unlocked or something. One time I realized I left a window open but I am not able to close it anyways from the app so it was just painful.
09-23-2022, 11:40 AM | #6 |
148
Rep 277
Drives: 2019 X2 M35
if you look at the app check the last update time, it doesn't continually refresh (I guess unless there is a break in or other event battery obviously excluded)
sorry to hear this, good luck |
09-25-2022, 08:31 AM | #7 |
4446
Rep 7,488
Battery voltage is usually one of the things that can be retrieved from the instrument cluster if you are familiar with how to unlock it to access some of the hidden features that are designed for service techs. Unlocking the cluster is a similar procedure to the one that allows you to reset the service intervals for brake/oil/statutory services/vehicle check. In fact, many owners get confused when trying to unlock the cluster or do a Service reset…and end up doing the other one instead if not familiar with the slightly nuanced differences.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
09-25-2022, 08:52 AM | #8 |
66
Rep 214
Seems like what the app shows are largely status' that were true when the car was last shut off. Agree BMW should be doing a lot better with it, especially when these cars use electricity 24/7
09-25-2022, 12:01 PM | #9 | |
129
Rep 421
These cars run the batteries on the hairy edge though. In everyday operation mine will typically be charged to 70% or so. They use AGM cells for this reason, they tolerate deep discharge. I guess it saves fuel to turn off the alternator until the system uses recovered coasting energy to drive it, but really?? |
Rich80766.00 |
