2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: Black Door Handle Strips & Front Fender Marker
      01-14-2014, 01:04 AM   #1
CaliE90
CaliE90's Avatar
354
Drives: BMW
2021 M550xi  [0.00]
Hi everyone,
Just got into my F10 recently so I'm taking things slowly with the car. In anticipation of the black BBS CH-Rs I am currently waiting on, I have decided to remove the chrome pieces present on the door handles and fender piece on the side of of cars.
For the door handles, I couldn't justify paying hundreds for a new set of door handles so I simply vinyl-ed them with gloss black vinyl.
Here's the vinyl I used:
http://shadowlinetrim.com/
For the LCI, the fender trim is simply a plastic piece so I just ordered a new set from BMW and had it painted at a local shop in Jet Black for $20.
Here are the part #s:
Finisher, side panel, front left 51137336645
Finisher, side panel, front right 51137336646
Cut a piece of gloss black vinyl roughly the length of the door handle and apply the vinyl and make sure there are no bubbles. A heat gun is helpful here.
Using a sharp cutting tool such as an x-acto knife and cut along the outside edge of the door handle chrome insert
Use your finger nails and push the vinyl edges into the door handle insert
Remove excess vinyl
End result
For the fender trim, I simply had them painted and swap them out
I don't have pictures of me removing the fender trim but it is very straightforward, here are the steps:
Use a flat/thin nylon pry tool to push in a clip from the front of the trim.
While holding that clip down, use another tool of about the same size and undo two clips on top and bottom of the fender trim.
These two clips are roughly positioned in the middle of the trim piece and as long as you hold the front they will release as soon as you press down(for top piece)/up(for bottom piece) on it.
The fender trim piece is composed of chrome plastic attached to a black assembly behind it. You want to remove the entire assembly, and not just the chrome piece. All of the mentioned clips are found on the black assembly and are colored in black, so you shouldn't be pushing on anything on the chrome piece.
Before:
After:
Matches perfectly with the OEM M Performance High Gloss Black Grills and the black LED headlight housing
Retired- '14 F10 535i -- 3 2 1 | '08 E90 335i -- 4 3 2 1 |
John H.230.00
      01-14-2014, 06:11 PM   #2
twelve535i
twelve535i's Avatar
478
Drives: 2015 X5 35i M Sport
Looks good. I think black wheels would finish the job well
      01-17-2014, 02:54 PM   #3
BeeEmmDubleYuu
25
Drives: BMW
Very nice
      02-16-2014, 08:27 PM   #4
Cquilichini
Drives: 2012 F10 535i M Sport
What size Wheels are those BBS CH? ALso do you have suspension on the car?
Looks nice!!!
      02-17-2014, 03:04 PM   #5
CaliE90
CaliE90's Avatar
354
Drives: BMW
2021 M550xi  [0.00]
Looks nice!!!
The wheels are 20 inch BBS CH-R. Car is lowered on H&R Sport springs
      02-24-2014, 05:50 PM   #6
Rajg7
Rajg7's Avatar
Drives: F82 M4 Zcp
Space grey/ Black is always a win... I wish Bmw kept the turn signal in the trim piece
      02-24-2014, 10:20 PM   #7
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Where did you get the vinyl?
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      01-03-2015, 07:05 AM   #8
Alcenos
Field Marshal 🔱
Alcenos's Avatar
144
Drives: 2019 M5 Competition (F90)
Has anyone found any other solution to painting the chrome side markers?
      01-25-2015, 07:54 PM   #9
Alcenos
Field Marshal 🔱
Alcenos's Avatar
144
What's the part number for the trim pieces?
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired)
2008 E60 528i - Space Grey (retired)
2002 E46 325i - Space Grey (retired)
1999 E46 328i - Orient Blue (retired)
      03-02-2015, 02:14 PM   #10
lsturbointeg
lsturbointeg's Avatar
9159
Drives: 2011 535i Jet Black
Wonder if any vinyl will work or it has to be a specific type?
      03-05-2015, 05:16 PM   #11
Don N.
182
Drives: BMW
They can be vinyl wrapped. I have considered purchasing a couple of stock pieces, wrapping them, and then selling/exchanging them for cores.
-Don
      03-05-2015, 08:17 PM   #12
NewM3driver
1110
Drives: 2017 M3 ZCP
I'm seriously considering getting a set of 20 inch rims for my new Jet black/Amaro brown 535. I love the older style BBS RX-R in brilliant silver but they are cast and weigh about 30 pounds. Is that too heavy or should I say heavier than the stock 19s that come on the M-sport?
I will be getting rid of the chrome on the door handles as well. Any thoughts on the clear bra for the parts of the car that get killed by the pebbles? Jet black is tough but looks awesome if kept up.
      03-06-2015, 11:23 AM   #13
CaliE90
CaliE90's Avatar
354
Drives: BMW
2021 M550xi  [0.00]
-Don
Here are the part #s for the trim pieces to help you guys get started
      04-07-2015, 01:07 AM   #14
Slickrick2
Slickrick2's Avatar
211
Drives: 2018-X5M-BLK Sapphire Edition
GREAT JOB!
      06-22-2015, 02:06 PM   #15
CaliE90
CaliE90's Avatar
354
Drives: BMW
2021 M550xi  [0.00]
Quite a few people have pm'ed me about this so I thought I'd post the source of the vinyl I used.
      07-05-2015, 12:46 PM   #16
macastel
Drives: BMW 550i
I just did my fender and door trims with gloss vinyl. For those of is who don't have a light in the fenders, you should push the black (no chrome) brackets on top, bottom and front in order to remove them. Heat gun helps a lot when installing the vinyl.
Also, I vinyl both front amber reflectors.
My car is a 550i gray space.
This forum inspired me so I am adding the info I couldn't find when I was starting..
      07-15-2015, 02:50 PM   #17
David Webb NH
Drives: 2011 550i XDrive M-Sport
I've almost completed the de-chroming... used a carbon fiber look vinyl wrap... http://www.ecstuning.com/ES2515494/
5post
