11-07-2023, 04:10 AM | #1 | |
2117
Rep 1,504
Made a post about my Gal's dead Hyundai
I refuse to pay 8.5% interest on a used car I have great credit so I am just buying her a car under 7K cash easier said than done I have found an E83 X3 3.0Si M sport.
Thanks Greg |
11-07-2023, 06:44 AM | #2 |
3525
Rep 1,004
I’ve owned 2 X-drive X3 and several X5. I never had a problem with the X-drive except on my 2005 X5 where I had to replace the actuator gear (easy fix, all over the forums and YouTube). So I am a fan.
I currently own a 2006 750Li. The tech is outdated (I use a Garmin for nav and Bluetooth, for example, since the maps for the car haven’t been updated in 7 years now). If something breaks in the infotainment systems, it is hard to find replacements (or they are very expensive), or get them repaired. Some mechanical parts are on long back order and seem to be moving toward NLA, which means eBay or a breaker. So, for a 2008 I would check every switch, button, bulb and all infotainment, etc. All that work recently completed concerns me (accident, abuse, ?). Did someone just give up, is it a perfume and lipstick job pre-sale, were the owners bad about regular maintenance? Get a good PPI on the mechanicals and of course full code scan before and after a lengthy test drive (seller has probably cleared any faults so you’ll need to get them to re-occur). Look up the rims on eBay to see what replacements will cost if curbed or beat, also look at the cost of the bigger tires which you will probably eat faster than on a non-M-sport. Again, no problem with the X3 or X-drive, but this example needs to be thoroughly checked out. |
M-technik-32117.00 |
11-07-2023, 07:17 AM | #3 |
3073
Rep 1,827
Can't speak for the rest of the car, but the motor will likely outlast everything else. Keep up on basic maintenance and watch for oil leaks. Oil filter housing gaskets are easy to DIY, valve covers are in between.. AWD oil pans not very DIYable.
Random car specific parts should be available from somewhere in eastern europe from ebay or as mentioned, the breaker yards. |
tturedraider5121.00 |
11-07-2023, 07:31 AM | #4 |
966
Rep 297
They are solid cars. All of the issues are well documented on teh bimmerfest e83 subforum. My 17yr old son drives our '09 every day and it's never left him stranded. We had to replaced the transfer case actuator, it has a leaky valve cover gasket that we'll be addressing soon and other normal BMW issues.
11-07-2023, 08:14 AM | #5 |
4999
Rep 4,139
n52 has left me stranded once due to steering lock failure (column)
OFHG, valve cover, oil pan gaskets. other than thank your typical plastic britlle coolant leaks water pumps and thermostats plugs and coils starter will likely go soon other then that the n52 is running strong |
11-07-2023, 04:25 PM | #6 |
2117
Rep 1,504
N52k is simple maintenance very versused in M10/S14 M20 M/S5X variants and N52's now and learning N55 now.
Been reading about the plastic transfer gear that breaks. Not sure on full story as to why so much work over last couple of years. I did a car fax and it was clean. I want to look at underside it has spent a couple of years in VT but most of the time was Washington state |
11-07-2023, 06:05 PM | #7 | |
5121
Rep 6,328
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
11-07-2023, 06:42 PM | #8 |
2117
Rep 1,504
Yeah, I never see them in strippers and if I did most of the parts would find find their way into my E91.
11-07-2023, 09:59 PM | #9 |
5121
Rep 6,328
Post some more photos. I want to see what the interior looks like.
11-08-2023, 04:27 AM | #10 |
2117
Rep 1,504
tturedraider5121.00 floridaorange10291.50 |
11-08-2023, 09:07 AM | #11 |
5121
Rep 6,328
Have you decided to buy it?
11-09-2023, 10:32 AM | #13 |
2344
Rep 4,195
Valvetronic sensor under the valvecover goes (oil leak from a bad gasket) not a fun job but not hard. Otherwise the N52 is solid - also may need water pump and thermostat, etc.
Mods: Yes.
11-22-2023, 10:58 AM | #14 |
5121
Rep 6,328
11-22-2023, 02:16 PM | #15 |
4217
Rep 5,730
Drives: 2019 M2 Competition
vreihen1615509.50 tturedraider5121.00 |
11-23-2023, 05:57 AM | #16 |
2117
Rep 1,504
Oh sorry, picked up. she liked it and I have been driving it this week getting all the nit noid RMV/Inspection plus doing oil change and coolant change. I want to do the rear diff fluid as well. I have been on the X3 site and it's a recommended.
Very the three stage manifold and the gearing makes it quicker than my E91. And being has the 19's it rides decent. |
11-23-2023, 07:36 AM | #17 |
10225
Rep 8,659
personally... even if used, I am not buying anything prior or older than a B series motor with BMW... there have been massive strides in reliability and quality there... N series motors across the board are trash and before that gets way too old
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
11-23-2023, 01:56 PM | #19 | |
5121
Rep 6,328
The three stage induction just makes the N52. I put a fairly mild Active Autowerke ecu tune on my 2006 330i and I was pleased with the results. They weren’t dramatic, but definitely noticeable. It was fairly inexpensive when I did it. It did require me to remove the ecu from under the hood and send it to them. https://store.activeautowerke.com/pr...7f8458e1&_ss=r I spent a lot of years on the E9x forum and owned a 2006 E90 330i for 11 1/2 years and I don’t think the evidence supports that assertion.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 11-23-2023 at 02:01 PM.. |
11-23-2023, 02:19 PM | #20 |
4552
Rep 5,402
11-23-2023, 02:57 PM | #21 | |
4217
Rep 5,730
Oil leaks water pumps |
11-23-2023, 04:50 PM | #22 |
5121
Rep 6,328
That’s true. The N54 was definitely a weak point in the N5x motors.
