08-22-2020, 11:49 AM | #25 |
King of NYC
118
Rep 176
Nice! You're welcome. Yeah, it's totally 100% automatic headlight control. Even with cornering lights. Makes the car still feel as fresh as any current year car and maybe even better.
2014 BMW M5 Competition
MCB on Silverstone |
08-30-2020, 08:30 PM | #26 |
197
Rep 218
Drives: 2020 M850xi Gran Coupe
Any chance this works on a G series?
Current Ride
2020 M850xi Gran Coupe Previous Rides 2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi |
08-30-2020, 09:09 PM | #27 |
King of NYC
118
Rep 176
No idea. But somewhere on a google search I could have sworn I saw a discussion on it. Google and see if you can find it.
10-11-2020, 04:00 AM | #28 | |
12
Rep 89
10-11-2020, 10:08 AM | #29 |
King of NYC
118
Rep 176
I don't know, I haven't personally tried it. Perhaps someone else who has from the F8X community can chime in.
I'd imagine if you took a look and tried to find the same parameters you would. Or something that looks close. If it's drastically different or certain parameters are totally missing, I wouldn't even try. But if it seems like it's fairly close to what is described here, you could give it a try and see what happens. Most of us have learned things by calculated trial and error. As with all "expert" coding, make SURE you make a BACKUP in case it does screw up and it should restore right back to how it was before. Try at your own risk though, if you don't feel comfortable about that maybe it's not worth it.
10-11-2020, 10:11 AM | #30 |
King of NYC
118
Rep 176
BTW guys, if this has worked on any other platforms, besides the ones described on this thread, pay it forward; just reply on this thread so we know. It will be helpful to other forum members who come across this thread.
10-19-2020, 10:50 PM | #31 |
Rep 1
I just did it with bimmercode but it seemed not working at all. I just drove around our town village but the high beam went off as usual when oncoming cars showup. I will try tomorrow morning but didn't notice any difference so far. Mine is f33 2018 430i with adaptive led lights.
Edited It works good early in the morning on highway. Checked nobody get bothered. It was moving quickly to repositioning. Thanks a lot. |
10-20-2020, 10:05 AM | #32 |
1158
Rep 545
Drives: 2015 M5 CP - 2022 M5 CS
Basically - when driving in town, your new features are overwhelmed by the multiple outside light interference and have no option but to turn brights off.
You won’t really appreciate the change until you get outside of town to a more consistent lighting environment. Take a country drive tonight. You’ll love it! |
10-30-2020, 04:13 PM | #33 |
129
Rep 371
Drives: '09 E90 328i 6MT, '16 F10 535i
Would anyone happen to know if this will work on a 2016 535i as well? My car has adaptive LED headlights and I recently successfully coded in VLD which works staggeringly well. I can't believe BMW actually coded this feature out by default!
I have been doing a lot of research into enabling GFHB over the last couple of months since I purchased my vehicle but I've only found conflicting reports. The general consensus appeared to be that European spec adaptive LED headlights used a completely different headlight part number with different shutters and LED emitters to successfully use GFHB. Apparently the US/Canadian spec cars shipped with the "inferior" adaptive LED headlights. If this really works on my 535i, I'll be over the moon. I've been lusting after this feature ever since I saw the video posted earlier. |
11-01-2020, 08:34 PM | #34 |
King of NYC
118
Rep 176
Yea it should work on your 535i as well being that it's an F10. But as long as you have the LED Headlights package.
Yes I've read the threads you're talking about. Hence why I said in the 1st post that some people debate this coding and whether you should even do it. The rationale makes no sense. I've even heard people imply the headlights won't work right because they're meant for Euro spec and we drive on the opposite side of the road. Ummm no. Last I checked Germans drive on the same side. Lol. Don't confuse UK with the rest of Europe. GFHB actually works, perhaps the naysayers should try it out first hand and see. Admittedly reality doesn't look as perfect as you see in the video. Namely the "tunneling" effect you get when following a car. Although the lights do move in the right directions and do tunnel, there isn't a hard cutoff as you see in the video. Still in my book it works to a fairly high degree. Its hard to tell if that video has some digital enhancement in order to accentuate the GHFB effect for demonstration purposes or indeed that is raw video showing real LED lights in action. Also I haven't been in any heavy fog yet that would clearly show the light beams and what they're doing and how well it cuts off. Are these "inferior" US spec lights? Could be. But I don't know how/why BMW would try to save a few cents on an option that they charge over $1k for. It's not as if these headlights are standard. I'd say it would make sense to them to make all LHD and RHD headlights the same from the money standpoint. I know someone said that they opened them up personally and know for sure. I won't argue with that because I haven't. So maybe. If so, I'm just saying it doesn't make much sense if they did that. If these were designed specifically for the US market then they shouldn't be codable at all. The main reason GHFB is coded out intentionally is because of DOT regulations. Audi has had killer active headlights for years now. It's even more accurate in beam cutoff than BMW. Almost like a dot matrix. However we here in the US can't enjoy those either. Some of these archaic laws have to change for the new tech out there. As if the laws are there for safety. These smart headlights are actually safer! Laser lights and headlights that even project safety information on the road surface or highlight obstacles are the wave of the future. https://www.wired.com/2017/01/bad-au...nt-allowed-us/ I guess there isn't enough pressure and incentive to make a change. Car manufacturers are still making money upcharging them as an option. Yet they have to decode them. Lol. They know 98% of people don't know the difference or care that much. Except us. I've done quite a bit of miles with this coding. Even if it's true that it doesn't work 100%, I'm happy. As you can see, everyone else who has coded these are. I haven't been high beamed even once by oncoming traffic. Yet that right side high beam stays on and let's me see far down the road. It tunnels when following cars adequately without bothering the car in front. In both modes it allows me to see street signs/possible obstacles on the right side of the road. In many ways it's a huge difference from being decided and in all a win-win situation.
11-04-2020, 08:26 AM | #35 | |
129
Rep 371
My car indeed has the Adaptive LED headlight package along with the KAFAS camera. It also has the auto high beams so I think it's well worth a try. I will go ahead and try this coding out in a few days. I can always restore from a backup in case anything goes wrong so no real loss. |
11-07-2020, 09:33 AM | #36 |
64
Rep 157
Drives: 2015 M5 F10
This is an excellent and thorough write up. Thanks for all of the detail.
I live out in the country and the additional visibility is appreciated. I've seen more deer since doing this mod then I knew existed on these roads. It's amazing to observe how the adaptive lights respond to other traffic. Excellent technology! Thanks. |
12-08-2020, 06:11 PM | #38 | |
Rep 40
Mods: Dinan Stage 3 software, Dinan I/C, O/C, Exhaust, M3 front and rear arms w/ subframe bushings, M3 Strut brace, Ohlins Road & Track w/ M3 sways, Super Sports, Quaife LSD, AR Design CDV mod, UUC Evo SSK, Z4 Si brakes, UUC brake hoses, Euro fog light switch
12-08-2020, 06:33 PM | #39 | ||
64
Rep 157
Drives: 2015 M5 F10
12-09-2020, 11:06 AM | #40 |
Rep 40
Thanks, appreciated. I'm going to try my first coding with Bimmercode on the F15 today.
12-09-2020, 10:42 PM | #41 |
69
Rep 189
Yeah my highbeams turn off if I'm behind someone or on a well lit road. When I'm on back roads or basically anywhere in Raleigh not ritzy or expensive to live (aka no street lights) its works exactly how the video touting the feature advertises. When I drive my wife's car I forget to turn her brights off (not to mention the lights on my car are way brighter).
12-10-2020, 01:14 AM | #42 |
King of NYC
118
Rep 176
Are you sure you aren't referring to regular ol' HBA? Active cornering headlights that swivel on the curves is also old news. What we're talking about is GFHB on this thread, which really is a different animal. It's easy to misunderstand all these technologies and mix them up. Reread the OP.
If you're saying that your headlights operate GFHB as default stock on a US car, I doubt it. Unless a previous owner has coded it in, it's normally deactivated by BMW.
12-10-2020, 11:09 PM | #43 | |
74
Rep 113
12-11-2020, 08:57 AM | #44 |
King of NYC
118
Rep 176
^^yea, I'd have to say that the cutoff on my car definitely isn't as sharp as it is in that video. I'm sure that it's just the nature of it being a US spec car.
This was discussed earlier, but the notion that there may be some kind of better baffles/shutters inside on the non-US lights may indeed be correct. How else can the cutoff be that sharp? At least we do have the same swivel action and correct positioning of the headlights in those same varied conditions. But there's undoubtedly a lot of difference in the way the beam cuts off. So this seems to be a hardware issue and not a software issue. Congrats BMW. You saved $5 per headlight while we paid $1k+ for the privilege. Lol. As if we expected anything else. I guess there isn't anything we can do except change to euro headlights. Not worth it to me but it may be to some. I'm happy with at least the reactivity that the software provides. It's still "anti-dazzle" which is the whole point point. Worth the minor effort to code in if you ask me. It's all good. The future is laserlight anyways. MB is on that projector light technology and Audi on Matrix tech. I look forward to a major leap on my next car. (BMW, you taking notes?)
