09-09-2023, 06:50 PM | #1 |
13
Rep 60
Camber Setting for Michelin PS4S?
Hi all,
For track and twisty canyon carving, what camber setting should I set my Michelin PS4S? I believe they have 300TW. Thanks in advance! |
09-10-2023, 10:44 AM | #2 |
3862
Rep 2,882
For a 350Z? You're just trolling us, teasing that you can set camber on it.
In general, as you get above 2 degrees you'll probably start to trade braking for handling/tire wear, but a lot depends on your suspension. On track it is a much bigger issue for tire wear, so on the street I'd keep it under 2. For track, 3 degrees is a common recc for the M2, that or 'as much as you can get'. Tire pressure will be at least as important for both handling and wear. |
09-10-2023, 03:43 PM | #3 | |
13
Rep 60
Should I try to keep toe at 0deg or close to OEM spec for both street and track? I know some folks prefer a bit of toe out on the track and toe in for streets. My main goal is to preserve tire life. |
09-11-2023, 08:14 PM | #5 | |
29
Rep 46
suggest some c&c plates |
09-14-2023, 10:35 PM | #6 | |
13
Rep 60
I got an alignment today to get it to "street spec." My alignment tech told me if i adjust camber to the max without adjusting tie rod, I will get around -3.2deg negative camber and total toe out will be around -0.55deg. We didn't actually use the alignment rack to get the actual track measurement though, it was based on his assumption. I'd imagine -0.55 total toe out would be detrimental to tire life driving on the track (or even the canyon)... |
09-15-2023, 09:49 AM | #7 |
778
Rep 607
Yeah so what you’re finding is alignments are annoying to get before and after track days and because toe moves with camber it’s not something you really want to diy in your garage.
Toe kills tires not camber. Just set camber where you need for even tire wear. With the toe you’re running the reduced tire life will be manageable and a compromise you just have to accept. |
Boba121412.50 |
