06-02-2021, 07:39 AM | #1 |
12
Rep 58
Aim Dash fuel/oil pressure
Hi guys - really struggling with this aim dash, connected to canbus but cant get
engine warning light fuel level (can get fuel warning light) oil pressure Can anyone help please? Tried the obd port but literally just get rev counter and gear position, nothing else. |
06-02-2021, 08:21 AM | #3 |
12
Rep 58
7" Strada
https://www.aim-sportline.com/en/pro...rada/index.htm Its essentially the same one they use in the m2cs racing apparently... not that - that helps at the moment. Im guessing all the stuff im missing is on a different can wire potentially?? |
06-02-2021, 10:37 AM | #4 | |
Dom
1081
Rep 1,722
Dom |
06-02-2021, 10:58 AM | #5 | |
12
Rep 58
You can buy the actual dash from BMW but it doesnt come with any ECU files loaded (i assume because bmw motorsport dont want their specific settings in public domain) Ill let you know how it goes! |
06-02-2021, 11:57 AM | #7 | |
Dom
1081
Rep 1,722
MrLizzzard Maybe there might be some additional options in Race Studio 3 software like this? |
06-02-2021, 12:42 PM | #8 | |
12
Rep 58
06-02-2021, 01:36 PM | #9 | ||
3492
Rep 9,708
Have you connected to the CAN BUS in the FEM? Blue and blu/red wires? If not how have you connected it? Provided you've done the above, you do need to configure the dash using RS3. I've had it that it didn't connect right due to not flashing the dash correctly. |
06-02-2021, 02:12 PM | #10 |
12
Rep 58
Really surprised oil pressure isnt listed there... but we arnt getting fuel - thanks for that list and ill have a check on where the guys took the wires from - is there only 1 set of CAN in the car do you know? Or is it just the ring doesnt send all signals to all the loom...
as you can tell im running out of talent! |
06-02-2021, 02:23 PM | #11 |
Dom
1081
Rep 1,722
Did you get street or race version? Also, I thought that there is an IVA version for the EU folks too. Also to my knowledge there are 4 wires in the FEM area. One question, do you still have your OEM cluster plugged in and tucked away or did you remove it completely and plan to run ONLY the AIM MXG itself?
06-02-2021, 02:28 PM | #12 | |
12
Rep 58
It does have the gps module plugged in as well. |
06-02-2021, 03:47 PM | #13 | |
Dom
1081
Rep 1,722
Dom |
06-03-2021, 08:18 AM | #14 | |
12
Rep 58
Dash is in - looks really professional rev counter speed batt volt oil temp coolant temp Shift lights all programmed GPS works (even beneath the dash in a metal unit...) indicators work high beam works MDM mode works - we programmed that whilst i was there - bit of a faff - it didnt like it being pressed on the TC button but worked via pressing the M2 button on the wheel... :S Fuel warning lamp is programmed but ECU isnt sending the data - we think cause there is more fuel in the tank for the warning lamp to come on - so this might actually work Bad news Cant access the buttons on the side of the dash - not the end of the world as you program it from a laptop - the idea will be to have a track dash and a road orientated dash i think. Cant get the damn fuel level - i can see Fuel km and fuel used but neither channel is getting any data at all... Cant find oil pressure - this isnt something that is sent to the dash anyway i suspect it will only send any data on this if falls below a value and then to the idrive unit and throw an error... Gear indicator doesnt work (think it might in an auto car tho) Next steps - the guys im using seem confident they can do this the old fashioned way on a Mv analogue sensor but are going to try and see if they can find it via a wire first ill upload some pics when i get the car back - any questions let me know Also - idrive completely fine, no affect at all |
06-03-2021, 08:41 AM | #15 |
Dom
1081
Rep 1,722
Amazing work friend. I look forward to seeing it all, hopefully you can get some kinks worked out and perhaps if someone else has some actual hands on experience, they could lend a hand. This is great though, my goal was to fully remove the oem cluster and just run this dash, happy that it does work and that iDrive is functional as well.
I wonder though, if you did have the oem cluster plugged in and tucked down in the dash, would the missing data then actually work? Might be good to try that out to see if it is the missing link between the two. Hope to get mine and put it in as well, glad someone else is doing this too. |
06-03-2021, 08:47 AM | #16 | |
12
Rep 58
However to the dash there are 2 cables - canbus/normal connector and a fibreoptic looking thing! wonder if that info is on the other side. spoke to Aim who said their list in the pdf (attached above) - is what they would expect to get from ecu/can, not what they have tested as working, so its a suggestion, not fact unfortunately... |
06-03-2021, 09:11 AM | #17 |
3492
Rep 9,708
Unfortunately I don't think AIM build a product to suit all users. No doubt they work with race teams initially that have paid for their own level of integration for motorsport use. Once done, AIM have those parameters mapped and calibrated, but nothing else.
I have an older AIM unit, if I plug it into BMW ECU CAN I get one set of parameters. If I instead plug it into OBD2 I get another set of parameters. By the way, mine reads fuel level in litres if I use OBD2, but won't using engine CAN. It's a shame the unit won't use both sources at the same time. When I asked AIM about adding the fuel, ride height sensors, oil pressure, parameters, they said they could map anything out for me……..at my cost. I basically would have had to employ their specialist to map the parameters I wanted. Prices that make your eyes water. |
ebisu81081.00 |
06-03-2021, 09:20 AM | #18 | |
12
Rep 58
i can see some of this data via the obd - like you say its so frustrating! |
06-03-2021, 09:20 AM | #19 | |
Dom
1081
Rep 1,722
I still look forward to future pics and updates. |
06-03-2021, 10:49 AM | #20 | ||
3492
Rep 9,708
06-03-2021, 01:01 PM | #21 | |
12
Rep 58
How does the ak motion display manage to get the oil pressure i wonder - thinking about using that as well if it solves one of the issues. |
