11-24-2017, 10:47 PM | #1 |
82
Rep 92
Drives: 2023 BMW 330e Xdrive
Hey guys, so I have BMS spacers installed on my car. 12mm in front and 15 in back. Every time I make a right turn and then straighten the wheel I hear a single knock noise from the right rear of the car. The reason I think it might be the spacers is because it never made this noise while they weren't installed. Any advice/info? Thanks in advance!
Update: I removed all four spacers and it still makes that noise, probably going to just bring it into service and see what they say. Edit: I finally got around to bringing the car to service and apparently the front right axle boot was leaking. Got it replaced under warranty and I thought that would solve it. Nope, no change whatsoever. Still makes the same noise when straightening the car after making a right turn. I'm really pissed and am gonna give it to my service advisor when I see him monday. Anyone have any advice? |
11-24-2017, 11:01 PM | #2 |
5702
Rep 3,226
I can’t imagine how they could make any noise, providing of course they are installed correctly.
There is nowhere for them to move, the sit flush between the hub and the back face of the wheel. |
11-24-2017, 11:03 PM | #3 |
82
Rep 92
I'm thinking the same thing, the only possibility is that maybe when I got my new tires put on the spacers were reinstalled incorrectly? Haven't been able to check for myself yet.
11-24-2017, 11:16 PM | #4 |
Cheapskate
4455
Rep 4,995
make sure your lugs are torqued down
AlpineAl2782.00 |
11-29-2017, 10:07 PM | #5 |
82
Rep 92
Alright so update: I made sure all the lugs are tightened down yet it's still making that noise. Honestly I don't care if it's just a small creak as long as the car is still safe to drive/mod.
11-30-2017, 07:05 AM | #6 |
981
Rep 1,560
How about taking the spacer off and see if you can still hear the noise. That would eliminate the spacer from the equation or not.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
jnecr114.00 |
11-30-2017, 07:54 AM | #7 |
114
Rep 243
This guy sciences.
12-06-2017, 10:31 AM | #9 |
82
Rep 92
12-10-2017, 02:59 PM | #11 |
Rep 32
I'm assuming you got longer lug bolts for all four wheels. Did you make sure they are of the right spec and that the thread on them looks fine? I hope you are not using the stock lug bolts with 12 mm and 15 mm spacers.
12-10-2017, 05:51 PM | #12 | |
981
Rep 1,560
03-19-2018, 10:44 PM | #13 |
82
Rep 92
Still making the same noise, brought it into service and they couldn't replicate the noise and even looked under the car and said everything was fine
03-19-2018, 11:00 PM | #14 | |
1062
Rep 1,876
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport |
03-20-2018, 09:23 AM | #16 | ||
82
Rep 92
03-20-2018, 02:16 PM | #17 |
238
Rep 878
Steering rack? Is known to make a noise like this, I had mine changed as it was making a knocking sound.
03-20-2018, 02:20 PM | #18 |
82
Rep 92
Actually the steering rack was replaced a few thousand miles ago paid for by insurance so that may be the issue. Although it seems like the noise is coming from the back of the car, not the front.
