BIMMERPOST Universal Forums General BMW News and Cars Discussion BMW wants to remind you how the wonderful xDrive system works
      12-26-2016, 05:23 AM   #23
HighlandPete
6659
Drives: BMW F11 535i Touring
Originally Posted by bailyhill View Post
Highlanadpete
That is my point. The differential cannot generate torque, it can only divide it between the wheels. I think this can be done with braking or it can be done with some sort of clutch arrangement that engages one side and disengages the other. I know what torque vectoring does, my question is how does it actually do that?
Bailyhill
Sorry, misunderstood your question.
There's a clever, but quite complex, double sun and planet gear drive with a clutch pack, one a side for each drive shaft. The closed clutch is (from memory) a 1.1:1 ratio.
So driving with a bit of purpose, sensors (including the steering sensor) feeding back data you are entering or in a bend, closes the clutch on the outside wheel, increasing the speed of the drive shaft on that side of the vehicle, (up to 1.1:1). Clutch slip compensates for the exact wheel rotational differences side to side, or one wheel would have to slip or spin. We understand that slip, as it's similar to the transfer box clutch pack in the xDrive, which moves torque rear to front.
That extra (geared up) wheel speed translates as extra torque to the outer wheel. Helps for a more neutral turn in, using the outer rear wheel to help reduce the tendency to understeer.
Shame it is so complex, or we'd likely see it available for less expensive models. The concept makes so much sense for press on driving.
      12-26-2016, 03:44 PM   #24
bailyhill
70
Drives: '20 X3 30e
Torque Vectoring
High Pete
Yea I climbed under my X3 with x drive, and I don't see any clutch housings on the axles, unless its built into the diff hub. So x drive must use the brakes. Perhaps the Go1 will upgrade to this.
Bailyhill
Current: "17 i3 REX; X3 30e
History: '67 911S, '72 MB 280 SE 4.5; '74 2002, E21 ('78 320i, E28 ('85 535i) , E36 ('90 325i), 6 Volvos; '14 ForTwo eDrive; '15 i3 REX, F31--'15 328 D Sportwagen; F25 LCI '16 X3 D
      12-26-2016, 04:52 PM   #25
HighlandPete
6659
High Pete
Bailyhill
For the X3...
Performance Control.
The Performance Control distributes engine and braking control to the individual wheels when turning.
Because the outer wheels have to move a longer distance than the inner wheels when turning, the BMW Performance Control intervenes by means of engine output and controlled braking: The outer wheels get more power while the inner wheels get less, maximising traction on each of the wheels. This means that the vehicle practically turns itself, thus increasing driving safety and comfort.
Dynamic Performance Control (as in the X5 M), uses the torque vectoring diff.
      12-27-2016, 11:53 AM   #26
Cortexiphan
Cortexiphan's Avatar
2088
Drives: 24' BMW iX
Originally Posted by rallybull View Post
The M5 will be AWD too
No it won't be. It will have an xDrive 'option'
11’ E92 ///M3
15’ F82 ///M4
18’ G30 540i ///Msport
21’ G20 ///M340i
24' i20 iX xDrive50
      12-27-2016, 01:27 PM   #27
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
That's nice. AWD is still fairly irrelevant for majority of folks in the non-snowing Western states.
re
      12-28-2016, 06:22 AM   #28
fecurtis
3262
Drives: 2014 BMW 335i M-Sport
Originally Posted by stvding View Post
Better make it awd and rwd switchable
Reportedly it will be,
http://www.roadandtrack.com/new-cars...r-wheel-drive/
      12-28-2016, 11:25 AM   #29
rallybull
rallybull's Avatar
179
Drives: F30 335i w/PPK
Good to know. So the question is that if the M5 can come with a RWD setup, why can't the 550i that has lesser torque.
