Does anyone else rarely uses 5th gear?
01-06-2011, 07:56 PM | #23 |
Very Important
20
Rep 450
Drives: 335xi (e92)
Garage List 2008 BMW 335xi (e92) [9.00]
2008 Pontiac G8 GT [4.00] 2002 Pontiac Grand ... [0.00] 2001 Cadillac, Eldo ... [0.00] |
Yeah, I actually use 5th all the time. It just fits the roads around here in Western PA pretty well. Most back roads are posted at 45 and there's a lot of hills/bends. So, 5th is a good gear for cruising. 3rd gets used in those diving turns when playing...
01-06-2011, 08:08 PM | #24 |
214
Rep 1,071
Both 5th and 6th gears on the 335i's ZF manual transmission are basically unusable on American highways. I rarely use either of them. I've found that the 335i cruises along very nicely at 80mph in 4th gear.
01-06-2011, 08:14 PM | #25 |
Rep 239
The throw from 4th to 5th is a little long and quirky for me. I might have to try 4th to 6th. I had my car for a couple of months and have never used 6th gear yet.
01-07-2011, 10:47 AM | #28 | |
36
Rep 1,467
This is bad because it maintains clutch contact, but allows for slippage. This wears out the clutch pack (friction). If you have your pedal not pressed, there is no slippage. If you have your pedal fully pressed, there is no contact. OP << I skipped 5th all the time. I'd usually go : 1, 2, 3, <wait for rpm to fall> 6. -scheherazade Last edited by scheherazade; 01-07-2011 at 11:08 AM.. |
01-07-2011, 11:55 AM | #29 |
17
Rep 592
01-07-2011, 01:29 PM | #30 |
Rep 79
01-07-2011, 02:14 PM | #32 |
73
Rep 1,388
I find 5th very useful on 55mph highways around Philly because I rarely (never) do 55 but I rarely want to stay at 80+ for very long. Fifth has a good sweet spot where it lets me ride anywhere from 65 to 80 without cranking too many RPMs and when I let off the gas it'll still decelerate pretty rapidly (unlike in 6th, which is too tall to drop you from 80 something to 70 something very quickly just by letting up). If I decide I'm done burning traffic I'll put it in 6 and maintain whatever speed I think is appropriate, but 5th is pretty money with the high speed/high volume/55mph speed limit highways around here...
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
01-07-2011, 03:52 PM | #33 |
214
Rep 1,071
I really don't know. Probably low 20 MPGs at around 4,000 RPM.
01-07-2011, 04:22 PM | #34 |
124
Rep 5,627
01-07-2011, 04:54 PM | #36 |
14
Rep 468
If I'm not accelerating quickly I'll always go into 5th out of habit before 6th. Generally on freeways between 60-70 mph I'm in 5th.
01-07-2011, 05:24 PM | #37 |
214
Rep 1,071
Both torque AND horsepower must be considered when reviewing an engine's performance. The N54 produces 85 hp @ 1,500 rpm, 115 hp @ 2,000 rpm, 170 hp @ 3,000 rpm, 230 hp @ 4,000 rpm, and 300 hp @ 5,252 rpm. IMO, if you’re routinely operating the N54 at 3,000 RPM or below, then you’ve wasted money on performance you’re not using and don’t need (you’re also missing out on some fun too).
01-07-2011, 06:08 PM | #38 | |
14
Rep 468
01-07-2011, 06:41 PM | #39 |
1053
Rep 5,660
I almost never use sixth gear. Typical driving shift pattern is 1, 2, 3, 4, 6.
On rare occasions around town, I may need to use fifth. I have wondered why a 6 speed manual is necessary. I suppose it has something to do with fuel economy.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
01-07-2011, 07:29 PM | #40 | |
124
Rep 5,627
And an E90 needs how many HP to cruise comfortably at 80? Perhaps 60~70hp? So if we're considering necessary hp, your gearing in 6th is too low - perhaps you should dump the 6 speed and transplant the new 8 speed auto from the 5 series, or at least opt for something like a 2.5 final drive ratio. You'll still have plenty of hp to cruise at 80 in top gear! Somehow, I doubt that cruising at over 75% of the HP peak rpm when you can shift up is beneficial to either engine life or overall expense. But like I said, it's your money. Tom |
01-07-2011, 07:38 PM | #41 |
107
Rep 1,428
the only time i use 5th is when im trying to go as fast as i can, and in that case i dont use 6th because the limiter kicks in before you get to the end of 5th gear.
01-12-2011, 02:23 AM | #43 |
Rep 291
Whoops.
Ah, crap. I forgot to mention that I use a STEPTRONIC, and use the M_ feature. For using N, it's when I'm alone coasting down Pali highway (downhill, the car is self-propelled and is almost perfectly balanced between gravity pulling the car and air drag slowing it down, so I don't have to use any braking) Just to clarify!
