Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Rockies / Midwest > Need some coding help
      10-26-2021, 07:38 PM   #1
dieselboy12
Drives: 330xi
I bought a 2006 330Xi, my first Beemer. I need some coding work done. I have some outdated daten files, my tach, gas gauge, and mpg gauge do not work.
I also have a bunch of airbag codes that I believe are coding-related. I will try and post the codes later. I am in the southeast corner of Nebraska but I can drive to the front range as needed.
I need some advice on garages or individuals that would be willing to help me out. I considered buying the software but it seems pretty complicated. Thanks
EDIT: the following codes are present relating to the airbag and seat belts;
1. 93AB MRS: Passenger Airbag, Stage I
2. 93AC MRS: Side Airbag, Left
3. 93AD MRS: Side Airbag' Right
4. 93B0 MRS: Head Airbag, Left
5. 93B1 MRS: Head Airbag, Right
6. 93B3 MRS: Passenger Airbag, Stage 2
7. 93CF MRS: Airbag Sensor, Door Front Right
8. 93D2 MRS: Telltale Lamp For Front Passenger Airbag Deactivation
9. 93C3 MRS: Seat-Occupancy Detector, Passenger
10. 93D6 MRS: Control Unit is Not Locked
11. 93BA MRS: Seatbelt-Catch Contact, Driver
12. 93BB MRS: Seatbelt-Catch Contact, Passenger
13. 93C8 MRS: Airbag Front Sensor Left
14. 93C9 MRS: Airbag Front Sensor, Right
15. 93CE MRS: Airbag Sensor, Door Front Left
Code related to the instrument cluster not working;
9317 KOMBI: Internal coding-Data Fault
2E7C BSD Data Bus Communication Fault
another issue is the infamous oil level gauge not working, I disconnected the alternator, IBS by the battery, the oil sensor, and the water pump wire and neither of them made it go away. Possibly a bad DME?
I appreciate any help in locating someone who could help me code.
