09-05-2022, 03:43 PM | #925 | |
General
10515
Rep 41,048
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-12-2022, 01:53 PM | #927 |
Rep 9
Is CarPlay Available?
Hello shawnsheridan, could you please check if my car supports CarPlay? The vin is 5N44161. My pms are still disabled so it would be great if you could reply in this post. Thanks in advance.
09-12-2022, 03:03 PM | #928 |
General
10515
Rep 41,048
I can't say based on your VIN. Need to verify if WLAN Port is present.
09-12-2022, 07:36 PM | #929 |
Rep 9
09-12-2022, 08:49 PM | #930 |
General
10515
Rep 41,048
Either remove Head Unit from Dash and check Label for Wifi Logo or back for WLAN Port, or read with E-Sys and post ENTRYNAV2 HWEL name.
09-15-2022, 04:37 AM | #931 |
Rep 2
Hello shawnsheridan
(sent this same message on another forum but I see you seem to be more active here) I've got a BMW X1 2017 ID4 6PIN with satnav - 6.5" non-touch screen - VIN ...5F46180 - any chance for an easy Carplay implementation/what would you recommend in my case please? Thank you. |
09-15-2022, 09:37 AM | #932 | |
General
10515
Rep 41,048
09-22-2022, 01:35 AM | #933 |
14
Rep 51
Hi Shawn. My mate has got a X2 F30 2018 car and we are trying to see if we can activate carplay on it. We tried looking if it is entrynav or nbt but we can't figure out. The version number in maps doesn't say any of these names. E1732C1R that's the only thing we can see. VIN is EB18956. Is there an option of adding carplay?
09-22-2022, 09:25 AM | #934 |
Rep 4
Bimmer Remote coding highly recommended
Recently received my BMW X1 2018. Been doing quite a lot research around the internet and was told by most people that it was either “impossible” to activate carplay or was offered an over $600 aftermarket solution… then I decided to go with Bimmer remote coding and kubax86 's team and it worked like a charm!! Absolutely amazing experience. Recommended 100%. Super helpful and responsive!!
09-22-2022, 09:30 AM | #935 | |
General
10515
Rep 41,048
09-30-2022, 04:44 AM | #936 |
Rep 3
Currently in the process of buying a 2018 X1.
According to mdecoder, the car has S6NW (Telephony With Wireless Charging), S6WD (WLAN Hotspot) and S6UP (Navigation Plus). The car does not have S6CP (Preparation Apple CarPlay) and CarPlay is not available in the connected drive store. Nav version: Road Map EUROPE Way 2018-1 J1846D1R Is it possible to add Carplay? Last 7 digits of VIN (is that what you need?): [...]EG27524 Is it true that the MyBMW app will no longer work after adding CarPlay? Or at least some features like GeoLocation? Something about Donor VINs? Is there a way to activate CarPlay "properly" for my VIN without sacrificing other features? New account so not sure if PM is working... Getting a response to know if it's possible or not is enough for now, can work out the details once my PMs are working I guess. Last edited by alexc_ch; 09-30-2022 at 06:06 AM.. |
09-30-2022, 06:50 AM | #937 | |
General
10515
Rep 41,048
alexc_ch0.00 |
09-30-2022, 08:12 AM | #938 | |
Rep 3
Apparently both bimmer-remote and flashxcode claim that MyBMW will not be working properly after using their service. I guess that means they use Telematic Provisioning then? Is an FSC Code something that you could provide? Are there any downsides to this, or why aren't the other services (e.g. bimmer-remote) using this method? Sorry if these are stupid questions, but this will be my first BMW and the learning curve seems pretty steep. Also, I need to up my post count to unlock PMs Last edited by alexc_ch; 09-30-2022 at 08:35 AM.. |
09-30-2022, 08:40 AM | #939 | |
General
10515
Rep 41,048
alexc_ch0.00 |
09-30-2022, 09:04 AM | #940 | |
Rep 3
So using that method I'll get CarPlay while keeping the full features of MyBMW, Connected Drive, .... Just as if the car came with it from the factory (but with slightly less WiFi range as you mentioned in your previous post). For fullscreen I'd probably still need a firmware upgrade first though. |
09-30-2022, 09:51 AM | #941 | |
General
10515
Rep 41,048
alexc_ch0.00 |
10-06-2022, 08:54 AM | #942 |
Rep 1
change language
Hi
I've bmw f48 usa version HU_Entrynav2 (version witout navigation:kokarda i'd like to change languagr to my national language. Anyone could help me Thx friends |
10-06-2022, 03:04 PM | #943 |
Rep 23
Hello shawnsheridan, if carplay is installed with fsc
OEM like the one from (bimmer) and then the car is called by some campaign to bmw and they have to update it to a newer version the carplay fsc is lost or with re-encoding carplay it would work again, I understand that the fsc will still be active there ,No? Thank you |
10-06-2022, 03:25 PM | #944 | |
General
10515
Rep 41,048
10-06-2022, 03:46 PM | #945 | |
1798
Rep 3,066
Send me vin to my PM
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
10-08-2022, 02:43 PM | #946 |
Rep 2
Hello!
I have a 2018 BMW X1 and I want to see if CarPlay is available. I am waiting for the PM function to be available. Thanks for the help, this is super confusing. |
