BMW 3-Series (E90 E92) Forum
Steering fluid: ATF or CHF 11S?
05-01-2020, 02:12 PM | #1 |
807
Rep 1,191
I'm wondering if the previous owner of my car changed the steering fluid reservoir already and now filled it with ATF. Does your 335d also have "ATF Only" printed on the reservoir? Mine is a 2011.
I just changed the fluid and it was murky brown. So it was hard to tell if it was ATF or a mix between ATF and CHF. In any case, would anyone recommend changing to CHF? I hear that ATF is rough on the seals and at least in my car it is always leaking out of the reservoir. But I also read that CHF and ATF shouldn't be mixed, so a good flush would be required at least. |
05-01-2020, 03:06 PM | #2 |
3060
Rep 3,914
Ask the dealer, is the only way I know for sure...
From my own research, I think the seals should be fine with either ATF or chf, but I could be way wrong there. Still wouldn't recommend mixing fluids, of course. Mine is a UK 2007 330d without active steering etc, and wants ATF according to BMW. |
05-01-2020, 07:46 PM | #3 |
1231
Rep 1,101
If I'm not mistaken, progressive steering equipped cars were ATF only. Everything else used CHF. I was also led to believe its not a good idea to mix the two.
05-02-2020, 09:27 AM | #4 | |
807
Rep 1,191
Can you guys with the US 335d please take a look at your steering fluid reservoir and report back? I know mixing the two fluids isn't a good idea. My question was if ATF could be flushed out by feeding CHF into the pump while letting it drain out the return line until fresh fluid is visible. Obviously, this would have to be done while turning the steering wheel lock to lock. Would the remaining mix still be detrimental? |
05-02-2020, 10:34 AM | #6 | |
1231
Rep 1,101
05-02-2020, 02:52 PM | #7 | |
3060
Rep 3,914
Mine has had a weak concentration of CHF in it for over a year, as I got the wrong fluid initially...I think no detrimental effects so far, though my PAS pump is tired (was before I changed the fluid too). |
05-12-2020, 04:30 AM | #10 |
Sleepy
75
Rep 367
Well I dunno what's wrong with my car. I pulled some old fluid out of my 335d, took it to the dealer, they said it was chf11 not atf. I never saw any red fluid and nothing in the cap. Flushed out all the fluid into a bucket it was dark but not red. What's the deal?
05-12-2020, 06:25 AM | #11 |
3060
Rep 3,914
Does it have active steering? If so, probably CHF11S. If it's just running HPAS, it's ATF...probably. Just ask the dealer for the spec for your car; ignore the fluid that's in it.
05-12-2020, 06:34 AM | #12 |
277
Rep 1,577
05-26-2020, 03:11 PM | #14 |
160
Rep 803
Edit: supposedly cannot mix BMW ps chf with atf. But there is nothing conclusive.
Even in other cars the power steering specific fluids like chf are a higher quality than atf and can replace atf. If you're in doubt just use chf. There are model years where it went from atf to chf with no changes in part numbers etc. Chf is probably a synthetic that lasts longer so they did this for their "lifetime" warranty claim, like they did with the transmission. Last edited by robnitro; 05-27-2020 at 03:41 PM.. Reason: wrong information |
05-26-2020, 07:06 PM | #15 | |
807
Rep 1,191
05-27-2020, 03:41 PM | #16 | |
160
Rep 803
odels that you can swap both oils without any problem include: Ford GM models Models that it is unsafe to swap power steering fluid and transmission fluid includes: Mercedes Benz BMW Honda Audi |
Mik325tds806.50 |
06-01-2020, 09:31 PM | #17 |
27
Rep 189
My 2010 says ATF on the cap. Also, don't forget the PS reservoir has a built in filter (kind of like the trans pan). Might be good to replace that when refreshing your fluid.
06-12-2020, 08:07 PM | #19 |
Who reads these?
234
Rep 107
My '09 335d E91 without active steering takes CHF 11S.
The reservoir says it, and has a green sticker. When I check RealOEM it also says CHF 11S. Maybe colder climates use CHF instead of ATF? I live in Norway and the car was sold new here.
Instagram: daniel.35d
Mik325tds806.50 |
