01-07-2023, 05:03 PM | #1 |
Rep 16
BMW X1 F48 Dash Cam Wiring
Has anyone in this group ever hardwired a dash cam whether it being an aftermarket or BMW branded one into their X1. If so, which pins did you tap into the BDC or fuse #'s you tapped into? Trying to hardwire one and wanting to determine the best location. Any help is appreciated!
01-08-2023, 02:30 AM | #2 | |
Rep 23
I hope it may help 👍🏻 https://f48.bimmerpost.com/forums/sh....php?t=1902851 |
01-08-2023, 06:23 AM | #3 |
12
Rep 122
Do you have a 12v power socket below the glove box. Mine is not seen unless you go down and have a look. I have had this socket in 3 cars , not one ever came with a cover.
01-09-2023, 08:39 PM | #5 |
Comfortably Numb
585
Rep 654
Drives: '18 x1/'13 X3/'06 330i
Here is another link:
I use the hidden power outlet under the glove box. Outlet powers down when the vehicle goes into sleep mode, dash cam shuts down until vehicle is powered up https://www.bimmerpost.com/forums/sh...php?p=23374627
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
08-08-2023, 11:17 AM | #6 |
Rep 2
Using a Rexing Hardwire kit, used small fuses 51 and 57. With my setup, the cam powers down when car is turned off, and on when ACC starts. Works for my needs.
08-10-2023, 03:49 PM | #7 |
Rep 44
Drives: BMW x1
Ive just wired mine in to my 2018 F48 Xdrive Xline. Bought puma piggyback fuse connector and used the most left hand fuse at the top of the internal ie glovebox fuse board which is permanently 12v live which suited my requirement. Disconnected the negative terminal of the battery, as that’s the easiest 1 to get at, left it 10 minutes to allow the airbag power to discharge and removed the footwell kick panel, Tucked the wiring behind the trim using an existing mounting stud for the earth.job done
09-26-2023, 06:16 AM | #8 |
Rep 5
Easy
I did this at weekend using the Nextbase hardwire kit, no need to remove glovebox etc. Took me less than an hour.
Below is based on fitting a Nextbase camera with plug-in rear camera module in a RHD vehicle. In a RHD car, this configuration dashcam has to go to the left of the mirror, other wise the rear camera will be obstructed when the passenger sun visor is used. Steps:
Last edited by Eff48; 09-26-2023 at 06:34 AM.. Reason: Edited for typos and clarity |
09-26-2023, 07:59 AM | #9 | |
Rep 5
In a RHD car, this configuration dashcam has to go to the left of the mirror, other wise the rear camera will be obstructed when the drivers sun visor is used. Last edited by Eff48; 09-26-2023 at 08:29 AM.. |
Tags |
dash camera, wiring |
