BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos what mods can i do on a 6 cyl but not a 4 cyl
      12-18-2016, 01:13 AM   #1
cruisingdownthestreet
No_Country
123
Drives: Z4
what engine mods can i do on a 4 cylinder without you saying, "if you're gonna do that why didn't you just buy the 6 cylinder?!"
      12-18-2016, 01:54 AM   #2
The Wind Breezes
912
Drives: 135i N55 DCT
Your question makes no sense, but assuming the 6 cyl starts off with more power and has as much relative headroom as the 4 cyl does, you would do better to start with the 6 cyl cuz the engine that started off with more power will usually end up with more power for a given level of mod / $ spent. Of course, these days there are plenty of 4 cyl that make more power from the factory than a 6 cyl. Number of cylinders doesn't really have much to do with anything until you're trying to absolutely MAXIMIZE power from a given displacement. For engines like you'd find in a modern BMW this would be over 1000 HP depending on what you consider reliable. Reason more cylinders is good in THAT case is you get a higher surface area to volume ratio so the cylinders can fill / exhaust more easily.
      12-18-2016, 05:56 AM   #3
Vigilante375
116
Drives: 2012 AW 6M 135i
No matter the cylinder size. They both will deliver a lot of power, when they are modded correctly. Every engine (except rotary) will be and can be modded the exact same. Cam(s), header(s), intake manifold, head(s), pistons, crank, turbo/supercharger/nitrous oxide (forced induction), etc.
Its just finding the right platform to mount it on to maximize the output of whatever engine.
What is your question more in reference to? Decisions on buying and modded a certain car? If so, which?
      12-18-2016, 02:20 PM   #4
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
If its a question about BMW turbocharged 4 or 6 engines, the N20 is pretty weak and will need to be built before handling remotely even moderate power levels.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
