BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Wiper blades F48
      10-08-2021, 01:58 PM   #1
pinco000
pinco000's Avatar
165
Drives: F48
Wiper blades F48
Hi guys, do you know the manufacturer of the OEM wiper blades? Mine need replacing, especially the squeky rear one Thanks
      10-08-2021, 02:27 PM   #2
Skyline2.0
Drives: 2018 BMW X1 xDrive
I believe my OEM ones were Bosch. Been using the Bosch A332H 13 inch rear blades with good success.
Also, Bosch Aerotwin A945S will fit on the front.
pinco000164.50
      10-08-2021, 03:41 PM   #3
Semi Retired
13
Drives: X1 2.0d Xline xdrive White
Hi I had my rear one dealer replaced, but it was expensive, so when I had a new front screen fitted I decided to replace the fronts with the Bosch OEM part perfect fit no adapters required, and in my opinion better than the originals £23.50 for the pair, I wouldn't use anything else
pinco000164.50
      10-09-2021, 06:10 AM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Join the following forum link below. You will see that the main sponsor of the site is a BMW dealership and offers discounts on everything. Cotswold BMW
https://www.bmwland.org.uk/
2012 BMW 320d Sport (F31).
      10-09-2021, 09:45 AM   #5
Wadadli Cooler
Drives: BMW X1 xdrive25d Msport F48
Bosch ones are very good. Front and rear were less than £30 on Amazon, and took less than 2 minutes to install all of them. You need to put the wipers in service mode first:
1. Switch the ignition on and off again.
2. With icy conditions make sure that blades
are not frozen to the windshield.
3. Press the wiper lever up beyond the point
of resistance and hold it for approx. 3 seconds,
until the wiper remains in a nearly vertical position.
After the wipers are folded back down, the
wiper system must be reactivated.
1. Switch on the ignition.
2. Push wiper lever down. Wipers move to
their resting position
      10-09-2021, 08:31 PM   #6
pinco000
pinco000's Avatar
165
Drives: F48
I was gonna avoid Bosch ones and go OEM. Reason is that on my previous car E92 LCI the Bosch vipers did not cover the same area as OEM. So Im a bit sceptical this time.
On the bottom of the windshield there was a little patch not covered by the vipers.
I need to replace mainly the rear blade as its very noisy, its probaly the one from factory (12/2016)
      10-09-2021, 09:12 PM   #7
jrveron
jrveron's Avatar
Argentina
272
Drives: 2023 X3 m40i
That's weird. Didn't BMW change them as part of the 3 years service/warranty? They changed my wipers once a year for free. They said it was included.
2023 X3 m40i Brooklyn Grey
      10-10-2021, 05:26 AM   #8
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Yes. But you need to go to BMWLand UK and join and speak to the main site sponsor who is called Cotswold BMW. They give discounts to all members on BMW and Mini OEM parts and you can pay by credit card and PayPal. They post to anywhere in the UK.
https://www.bmwland.org.uk/index.php
Do not underestimate the above site.
pinco000164.50
      10-10-2021, 06:02 AM   #9
pinco000
pinco000's Avatar
165
Drives: F48
I know about the Cotswold BMW. I purchased from them in the past. They have a thread on this forum, in the e92 section.
I found the bosch equivalent on fleebay for £8.93, but will see what bmw will offer
      10-10-2021, 09:55 AM   #10
BrianJ
25
Drives: BMW F48 X1 xDrive20i Sport B48
Rear ones tend to get deformed and squeaky/juddery by being parked and not used much, especially in summer. I've had some success just by removing it and turning it round.
      10-10-2021, 10:54 AM   #11
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Also, the judder problem is exacerbated by a build-up of grease/traffic grime. A good degreasing agent or Window cleaner can help. Also over a period of time, the rubber goes hard with age and this does necessitate replacement.
      10-10-2021, 04:48 PM   #12
pinco000
pinco000's Avatar
165
Drives: F48
Thanks for the advice guys. Im planning a deep clean and polish of the front and rear glass, the vipers too. It might help. If not I'll turn around the rear blade as a last resort before I buy a new rear blade.
      10-10-2021, 11:42 PM   #13
jrveron
jrveron's Avatar
Argentina
272
Hey pinco000,
I used this product before with great results: https://www.chemicalguys.com/heavy-d...t-remover.html Around here, the rain (and pretty much all the water) contains a lot of minerals, so it's easy to have marks on the glasses. Use it after a clay bar treatment in the most difficult areas.
Please, be aware it's really strong. Follow instructions carefully. Apply on a ventilated space, use gloves and facemask because it has a strong chemical smell.
After you're done, you need to wash the glasses or apply a quick detailer to stop the chemical reaction: https://www.chemicalguys.com/speed-w...-detailer.html.
Finally, you need to apply a sealant like this one: https://www.chemicalguys.com/jetseal...l-sealant.html.
      10-11-2021, 12:52 AM   #14
///Makis
///Makis's Avatar
55
Drives: BMW 128i
Bosch is probably oem for some model bmws, you mean OE.
If you bought standard Bosch ones from an auto store, did you get the right size?
I've used Michelin wipers and change them every summer on my e82, they "updated" the wipers this past year as the plastic connectors/adaptors (they're universal blades for many cars) were clearly different and this time although I bought the same size, the blade seems to be a few mm short on the bottom and I can tell from the almost permanent streak the previous ones left.
I'd say go with what works best, and last the longest but I've found the rubber plasticizes after about a year in my climate and the wipers start to make noise and leave streaks.
      02-03-2022, 04:39 PM   #15
pinco000
pinco000's Avatar
165
Drives: F48
yep, in the US. In the UK they are Bosch Aerotwin A350S for the fronts
      03-27-2022, 10:21 AM   #16
spitpilot
64
Drives: 2023 230iX, 2017 X1 M sp X
Wiper Blade Set Part #
Here's Bosch OEM wiper set part #
Bosch Windshield Wiper Blade Set; Front | 61612407288
Autohaus AZ sells it for $18 or so...
Reefy38.00
      03-27-2022, 04:03 PM   #17
pinco000
pinco000's Avatar
165
Drives: F48
thanks bud, I got one pair already
      05-11-2022, 11:55 PM   #18
tin96
Drives: 2018 X1 sDrive28i & 2008 Yaris
I used Rain-X wipers but the little square universal adapter thing will pop up over the hood line.
      05-12-2022, 12:23 AM   #19
Jorix
73
The OEM wipers are crap. They squeal and leave dirty spots. I replaced mine with some cheap gas station brand and they perform much better
      05-12-2022, 03:55 AM   #20
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
There is nothing wrong with OEM ones. Cleaning the screen completely and properly is the solution.
      05-12-2022, 06:18 AM   #21
Jorix
73
This does not explain why swapping them with non-oem fixes the issues And that has been valid with previous BMWs I've owned as well
      05-12-2022, 06:48 AM   #22
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
I have owned cars since 1963, and it has always been the case that degreasing the complete screen solves most of the problems unless the rubber has age hardened and they need replacing anyway.
The spots are normally grease/traffic film/oil and rubber residue.
