TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      08-23-2023, 05:10 PM   #89
JellyStyle
Builder of Special Cars
JellyStyle's Avatar
202
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
Originally Posted by NoVA_X5M_98M3 View Post
Please PM me too!
sent
      08-23-2023, 08:57 PM   #90
TTV8M
TTV8M's Avatar
123
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
Looks great. Need that for my 2011 x6m
'10 X6M
'08 Cooper S
      08-24-2023, 01:07 PM   #91
Juniinhosk8
Drives: BMW X5M E70
2010 BMW X5M  [0.00]
Greetings everyone, first of all, this text is being generated by the GPT chat, so occasional spelling errors may occur, and I apologize for that.
Here we go, I'm setting up a system in my car, an S63. I'm going to install the junction between the valve cover outlet and the 3-way component, while also maintaining the connection between the benches.
My system will have only 1 input and 1 output. I'm using the vacuum control valve recommended by Sophisticated Redneck, and I've added this series of adapters to see how I will assemble the final piece.
In my case, it's a 3/4 inch outlet or 12AN.
I've attached photos of the adapters. Basically, it looks a bit messy, but I'm going to create a single CNC-machined piece to achieve a cleaner and more functional look.
      08-24-2023, 01:19 PM   #92
JellyStyle
JellyStyle's Avatar
202
Not sure why you are doing all this; Troy has about 100 hours in designing and building a system that will look 1000x better, and cost a fraction of what the time to buy all those brass parts. the two port setup will have its issues, if you go through why this is, look and read the entire thread, it covers why without all 3 ports, you will have issues or CELs.
I guess if you want to make your own version, that's cool, but we literally did this to help the community out, not to get rich on, our pictures are better than anything out there, and to eliminate needing to use plastic OEM parts that will crack and break over time.
Joe
Appreciate 2
TTV8M122.50
      08-24-2023, 01:22 PM   #93
Juniinhosk8
Drives: BMW X5M E70
2010 BMW X5M  [0.00]
Simplifying and showcasing all my Paint skills I'm going to place the reservoir with this connection.
      08-24-2023, 01:29 PM   #94
Juniinhosk8
Drives: BMW X5M E70
2010 BMW X5M  [0.00]
Joe
Certainly, the connector you've made seems to be very well-designed and solves the issue of plastic connectors' fragility once and for all. My question is regarding the need for two reservoir inputs.
As far as I've observed, the system releases vapor through the valve cover and suctions through the intake, before the turbines, and later through the intake manifold.
Please send me a private message as I don't have this function enabled yet due to my low number of posts.
I'm using this video as a guide for locating and connecting the system.
      08-24-2023, 10:14 PM   #95
JellyStyle
JellyStyle's Avatar
202
We're going for an OEM look with the ideal use of 3 port like the OEM setup, and isolated sides so that both sides work solo, when you connect that crossover pipe, it will unbalance the two, and the drivers side will only catch oil, you will see.. Its been talked about a ton on the S63.
      08-31-2023, 05:20 PM   #96
JellyStyle
JellyStyle's Avatar
202
Here is the drivers side CCV, not finished, going to shorten the back port with a 90 degree so its a shorter run to the valve. Troy is a master as you can see of this M7 motor. ha
Appreciate 2
      09-01-2023, 08:16 AM   #97
Juniinhosk8
Drives: BMW X5M E70
2010 BMW X5M  [0.00]
It looks impressive!! Very clean visual.
      09-03-2023, 03:14 PM   #98
JellyStyle
JellyStyle's Avatar
202
Small improvements to the driver's side, better angles and hoses are shorter.
AS you can see, the leanest, nicest CCV setup ever; even the valve is hidden on the bottom side unlike other setups.
Those interested PM me, i got pricing from Troy to make them, not bad at all.
Appreciate 3
      09-04-2023, 11:41 AM   #99
JellyStyle
JellyStyle's Avatar
202
Pics of the full install attached on my M7 N/S63 Kit come with everything: hoses, vacuum valve, connections, etc.
Kit also comes with a pre-set vacuum valve (it's hidden down below at the engine case connection, unlike those that put the ugly brass valve at the top.
Those interested, PM me; if you cannot PM, post here, and I'll PM you. Only doing this to help Troy, so he can recoup some of his hard costs; he is offering this at a great price, and certainly well worth the money.
He's going to expand to all new current model cars now too.
Thanks
Joe
Appreciate 4
      09-07-2023, 08:45 AM   #100
punisher12b
32
Drives: 2011 135i
Few questions. What car is this on?
Are you now Troy's sales rep?
Can we see full pictures of how it connects at all points? I.E without that engine cover ( which troy himself states we should be removing on the E70s even in this very thread)
I am assuming now that it has gone to business there will no longer be any informational updates on those who prefer to DIY?
Does this mean intakes are coming? and projected timeline?
Can certain pieces be purchased. and if so what is the projected eta for delivery of them?
TTV8M122.50
      09-07-2023, 10:27 AM   #101
JellyStyle
JellyStyle's Avatar
202
This is a F02 750 that i made into a M7, with a N63 and many cool things.
Adding more pics so you can see all the connections.
I am not a sales rep, i helped on the building of these functions.
I cant speak for Troy and DYI, but his parts are low cost that you'd likely spend more doing a DIY then use his kit, or a close even. Im sure he will help anyone that wants the ugly setup if that is their goal, I'm sure he wont care.
Im sure he can sell certain pieces, but that's his call, he's still busy machining and looking to make it cool.
He made a custom pressure valve (not annodied in this pic, but it will be) so we didnt have to use the ugly big brass one off the catchcan. We also made connections that make this clean and right, as you can see from the final install pics.
I would give him a week or two on all of this, he's still putting things back together and sourcing more aluminum for the additional kits, but I'm sure he will take things on a case-by-case basis for those that want things.
Just give us a week or so, so he can get more pics of each connection, when in final version form, a lot of these have scratches from all the removals and take offs, to get the lines and connections right.
As for intakes, yes, I know he is aiming to get that going too, he just mastered the 3D CNC mill, so that is what took the time to get these made right.
Joe
Appreciate 3
      10-21-2023, 10:04 PM   #102
TTV8M
TTV8M's Avatar
123
2010 BMW X6M  [0.00]
Originally Posted by Sophisticated Redneck View Post
....... say transmission fluid does not need to be changed and lasts a lifetime....
In the bmw engineers defense, they didn't declare what lifetime of the trans is......lol. Is it 10 yr/100k? I'd much rather follow ZFs service intervals or just change the fluid, filter, and whatever other maintenance is recommended at 25k miles
Dirty fluid only gets dirtier. Change the fluid more often than not.
'10 X6M
'08 Cooper S
      10-21-2023, 10:20 PM   #103
TTV8M
TTV8M's Avatar
123
2010 BMW X6M  [0.00]
Intakes are completely different on S63 & N63 however connections to the Catch cans are basically the same, the main difference is the cross connections from intake to intake the S63 has with the CCV lines. You can eliminate these and duplicate what I have done on the N63. I can post more pics if you need.
You will need a vacuum gauge to know where you are at with vacuum and to make sure everything is working right. you dont have to permanently install it. Just tap the oil filter cap like i did and run the line into the cabin through the door jam. (I can post pics on this too if you like) What you are looking for is to pull around negative 8-10 psi at idle, and to make sure that there is no boost leak back into the crank case so under acceleration with the turbos engaged it should read -1 or 0.
After this is set you can remove the vacuum gauge and put a small rubber cap on the tap you added to the oil cap.
I will say you may want to hold off on this a bit, I am going to take this to the next level and add an header evacuation system to this and route the CCV tubes that normally run to the intake to the exhaust. (Basically the tubes you see running to your intake will instead running to a pair of Bernoulli tubes welded to the lower exhaust collectors).
This is a very old-school way of having negative vacuum in the crank case without having to route the crankcase fumes back into the intake. It would also greatly simplify the CCV system
It should improve performance throughout the engine band and no more combustion gases being recycled back in to the intakes.
I do not know how this will effect the tuning (if at all), will know more this weekend, going to baseline the truck tonight and then do a before and after test. Will post results back then.
Any updates on running to a pair of Bernoulli tubes welded to the lower exhaust collectors?
I really do not want anything fed back into my intakes , besides methanol (WMI)
'10 X6M
'08 Cooper S
      11-02-2023, 05:26 PM   #104
kimmarc723
Drives: 2013 X5 50i M Sport
PM sent
      12-13-2023, 08:19 PM   #105
aligoodn
38
Drives: 2011 X5M
You guys have done a lot of development since I did my original setup.
If you want to complete delete the plastic lines that connect to the manifolds, you can buy fittings here: https://www.schellen-shop.de/search?...24&cf=271&f=11. The connections to the manifolds on the S63 are Normaquick NW15 45 degree fittings. Any removal of plastic tubing is a win for reliability.
      12-13-2023, 08:34 PM   #106
JellyStyle
JellyStyle's Avatar
202
Not sure I follow. We eliminated all plastic other than the flaps. Those you can buy 10AN but they are expensive and you still have to tap into the intake side.
      12-15-2023, 08:59 PM   #107
aligoodn
38
Drives: 2011 X5M
Parts 1 and 2 in this diagram are plastic: https://www.realoem.com/bmw/images/diag_472j.jpg
The normaquick fitting would replace the connection at the bottom of part 1 and 2 where they attach to the intake manifolds themselves.
      12-15-2023, 11:54 PM   #108
JellyStyle
JellyStyle's Avatar
202
We cut the plastic and use these fittings that come on the car already, so you do not need to buy these. We just take them to 10AN and make it work, but once we have the S63 kit released, it will make more sense to make it cost effective for all.
My x5M is going under the knife to get this in a few weeks, then we will post pics of that setup.
      01-17-2024, 04:43 PM   #109
Hustle2
Drives: E70 X5M
Any updates on this? Exactly what I am looking for if it turns out good on yours. PM me for pricing as well if you can.
Cheers
      01-19-2024, 05:23 PM   #110
OscarX6M
OscarX6M's Avatar
Drives: BMW X6M
2012 BMW X6M  [10.00]
I sent a pm regarding the s63 kit
OV
