225/40/18 all round ?
01-12-2017, 01:25 PM | #1 |
16
Rep 90
Hi all,
Is it safe / sensible to fit 225/40/18 all round on standard staggered mv3 wheels? Looking at fitting winters and not only does it bring the price down a little the choice in tyres is also greater. Many thanks, Joel
01-12-2017, 02:44 PM | #2 |
Rep 83
225 would go on an 8.5 rim not sure if it is a good idea or not. I just run the standard size tyres for my winters I know people say don't get the wider wheels but I don't want the car to look rubbish.
They worked well on the way home tonight although it's not exactly perilous....
___________________________
2006 330i E90 2001 330ci E46 |
BionicYeti15.50 |
01-12-2017, 03:53 PM | #3 |
342
Rep 1,826
Drives: Alpina G21 D3S
You can fit 225 section on the rear. I have a pair of Falken Eurowinters in 225/40/18 if you want to make me an offer on them. They have 6/7mm or so across the whole width.
BionicYeti15.50 |
01-13-2017, 05:02 AM | #4 |
Photographer
413
Rep 2,643
Rears will look a tiny weeny bit stretched but you'll be fine. I'd have no problem with it. I actually run that size on an 8.5 front coupled with a 9.5 rear.
BionicYeti15.50 |
01-13-2017, 01:21 PM | #6 |
2371
Rep 3,560
I am running that tire set up on stock Style 189 rims 8" and 8.5"
Been running that for the past 4years. Still on the same winter tires. |
BionicYeti15.50 |
01-20-2017, 01:16 PM | #7 |
16
Rep 90
Just to update.
Tyres fitted with no problems at all. Tyres have a "rim protector" making the tyre look almost standard fitment. Nice little saving on the tyres and the cars a little safer in the colder conditions
03-10-2017, 06:33 PM | #8 |
42
Rep 492
This 'square' set up is a common approach taken on 130i which have 7.5 or 8" front, and 8.5" rear. Worked well for me and made the car even more eager to change direction.
F10 M5 CP.
Previous: F31 340i, E90 335i SE, E87 130i, F10 550i, E92 335i, E61 550i, E90 335iM, E87 130i, E87 118d, Z4M, Z4 3.0i SMG, E46 330D, Z3M, Z3 3.0i, Z3 3.0i (USDM) |
02-27-2020, 05:26 PM | #9 |
Rep 3
I have a 2009 328i xdrive coupe. I changed my wheels to 18x8 with 255/35r18 in the rear and 215/40r18 in the front. My steering wheel would wobble so I changed the front to 225/45r18 and the problem remains the same. Will changing the front wheels to 225/40r18 solve the problem? Thanks
03-01-2020, 01:56 AM | #10 |
1078
Rep 1,959
Drives: E90 M3 LCI Jerez Black
Your wheels could wobble for a number of reasons. Worn bushes, wheels not balanced, buckled alloy, bad alignment.
02-26-2024, 10:24 AM | #12 |
Rep 5
Hi guys ! I have a 2008 335i e93 with 225/40r/18 all around.
Obviously, the rear should be on 255 but I had a deal on some 225. Although the car drive perfectly it look silly ! Can I put 25-30mm spacer on the rear ? Will it help ? Thanks for you help. |
02-26-2024, 10:52 AM | #13 |
Rep 6
Drives: BMW 335i N55 2011, BMW 330E
Hi,
I have 225/40r18 on my 335i e90 with winter tyres during winter season with no issues at all. |
