01-25-2024, 01:02 PM | #111 | |
1889
Rep 5,506
I don't mind paying a bit more to get it from a US vendor but the wait time is just insane.
Auto Detailing Enthusiast!
01-31-2024, 11:12 AM | #113 |
63
Rep 196
Z K Arrived today; only took two weeks. On the fronts, there aren't the tabs that the stock brakes have. Not sure what their purpose are (maybe vibration/noise purposes), but I assume I can just install the PMU fronts without prying the tabs off my old pads?
randomserious54.50 |
02-08-2024, 01:30 AM | #114 |
55
Rep 75
i don't have any insights but the shop that installed mine didn't move the tabs and it's been fine for 5k+ miles with lots of track and autox.
02-08-2024, 01:37 AM | #115 |
1889
Rep 5,506
The stock block things are for noise reduction. You can try moving them over although I don’t know how. I haven’t had them with my pads and it’s been fine.
02-26-2024, 11:28 AM | #116 | |
Rep 13
02-26-2024, 11:33 AM | #117 | |
1889
Rep 5,506
Yes, those are for the cars with the optional brakes. The M performance upgrade brakes or ZTK package cars.
legolego7.00 |
03-29-2024, 08:11 PM | #118 |
63
Rep 196
Z K Do you notice your front insides wearing slightly more than the front outsides? Maybe a mm or two more? After my first HPDE weekend (with STOCK pads) I changed pads and noticed this. Both insides were about equal, and both outsides were about equal. First pad change, so I doubt there's any pistons sticking. I suspect it has to do with overheating brakes, particularly on the inside of the rotor, which doesn't get effective cooling. Thoughts? Hopefully the PMU pads hold up better.
03-29-2024, 08:16 PM | #119 | |
204
Rep 464
03-29-2024, 08:28 PM | #120 | |
1889
Rep 5,506
Did you change the brake fluid with high temp track brake fluid?
03-31-2024, 11:18 AM | #121 | |
63
Rep 196
For this particular weekend, no. It was Motul 5.1 with stock pads. I'm switching in Endless RF-650 so we'll see how it goes. The difference on one rotor was <1mm and the other was closer to 1.5mm, so it's not much. I was also thinking it could be the reasoning you're stating.
04-24-2024, 07:54 PM | #122 |
13
Rep 34
For those that are curious on ordering some Project Mu pads: I ordered the PS pads from mhdjapan on 4/11-I got notification the shipped on 4/22, and they arrived today- 4/24.
Total was ~$364 I'll update on my impressions once I install and get some miles on them. |
04-24-2024, 09:23 PM | #123 |
144
Rep 111
Drives: 2021 bmw m340i xdrive
I’m looking for front and rear pads by project mu , I have the M performance 18”bbk , it’s the ZTK package, dimple front and rear rotors. Can anyone help me with the part numbers for front and rear?
2021 m340i xdrive ZTK package. And where would it be best to order them from? That won’t take 1/2 a year to get here ? |
04-25-2024, 09:06 AM | #124 | |
63
Rep 196
Order direct from Japan (RHDJapan for example) and they should arrive within a month or less via airplane, assuming they're available. Seems like the US vendors get from a distributor who wait for a shipping container to fill. You also take advantage of the favorable Yen to Dollar exhange rate if you buy direct. |
04-25-2024, 05:42 PM | #125 | |
144
Rep 111
