01-27-2017, 06:30 PM | #243 | ||
126
Rep 243
01-27-2017, 09:43 PM | #244 |
2374
Rep 8,364
01-28-2017, 12:11 AM | #245 | |
967
Rep 1,771
Instagram: @dg_g20
01-29-2017, 05:09 AM | #246 | ||
126
Rep 243
AW, try to search for those parameters and see what comes up. Hopefully close or similar, if not im gonna do some coding later this week again and ill take a look. Keep us updated. |
01-29-2017, 12:53 PM | #247 |
23
Rep 92
Drives: F31 320d Xdrive Msport Touring
Hello wanting to code a X1 for a friend, Dont suppose anyone knows if its possible to code to start in Eco Pro each time?
I know for a F30 its:- ICM 3000 ICMKOD_B_InitEco verbaut Does the X1 have this? |
01-29-2017, 01:48 PM | #248 | |
2374
Rep 8,364
Yes, it is possible, but changes are done in BDC_Body for default startup mode and ICMQL for enabling driving modes as well as remembering last setting. |
Whyte90122.50 |
01-29-2017, 03:11 PM | #249 |
126
Rep 243
01-30-2017, 01:15 AM | #250 | |
21
Rep 61
3221 Fesinitmaster_fesinitmode to Werte 07(ECO PRO) Regards, Marcel |
Whyte90122.50 |
01-30-2017, 09:04 AM | #251 | |
Rep 39
Drives: X1 F48 25i
Thanks JP
01-30-2017, 11:05 AM | #252 |
Rep 6
First post here.
Just got a 2017 X1 in Canada, all the tech packages including HUD. I have the cable and latest software installed. A bit nervous but I'm going to try one at a time. I have read this and other threads, cheat cheats and even downloaded a Windows app to try to reconcile difference I see. Here's what I've got so far as valid codes for NEW F48. My understanding is that since it was manufactured in November 2016 I can't change the flashing to 5. THESE ARE NOT TESTED. Just looking to see if they make sense to anyone, and hopefully to help new people. I've also coded some tips I've picked up for newbies. Please feel free to add: TIPS FOR NEWBIES 1. Use F048 to connect with E-Sys Launcher 2. Select F056 as target when starting connection to car in E-sys. 3. Make sure under E-Sys => Options => Settings => Program tab => Memory Requirement => RAM is set to 1024 or you will likely be unable to read BDC. Do NOT use anything larger than 1024, or E-Sys will be unable to Open, and you will have to reinstall it. 4.In order to avoid any VCM update errors (this does not affect your coding), go to the top of ESYS and click Options > Settings > Options tab. UNCHECK BOTH "Update VCM after TAL execution" and "Update MSM after TAL execution." 5. Don’t EVER code a module folder. That is VO coding and is permanent and can mess things up. Do only FDL coding for now. 6. Do not ever press CODE DEFAULT VALUE. BDC_BODY Module: Radio turns off when car goes off 3020>TCM_LOGIC_R_OFF_DOOR set to: aktiv Horn Doesnt Sound When Locking From Keyfob With Car On 3040>VAM_HORN_AT_SECURE set to: nicht_aktiv Lights Flash At Unlock And Lock 3040>VAM_REQUIRE_LCE_FLASHING_AT_UNLOCKING_SECURIN G set to: aktiv Soft Blink = 5 Times 3069>PIA_DEFAULT_TIPPBLINKEN = tippblinken_fuenfmal werte set to: 02 Close Mirrors/Windows/SunRoof from FOB or CA – set all to: aktiv 3056>KOMFORTSCHLIESSUNG_FB 3056>KOMFORTSCHLIESSUNG_PA 3110>ASP_BEIKLAPPEN 3110>ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN 3110>ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN Set Mirror Fold Delay Time to Instant upon locking 3056>KOMFORT_SCHLIESSEN set to: 00 Enable Illumination of Exterior Door Handle LEDs when in Reverse 3070>OVT_BEI_REUCKFAHRLICHT set to: aktiv HU_ENTRYNAV Module: Remove Legal Disclaimers 3001>LEGAL_DISCLAIMER_TIME set to: kein_ld 3001>MACRO_CAM_LEGALDISCLAIMER set to: kein_ld 3001>MACRO_NIVICAM_LDISCLAIMER set to: kein_ld HKFM Module: Close/Open Rear Hatch from Fob & Kick Panel 3010>SCH_FBD set to: aktiv – werte=01 3010>SCH_TOEHKI set to: aktiv – werte=01 3010>TASTER_FBD set to: aktiv – werte=01 SM2 Move seat on exiting and after entering 3000>EINAUSSTIEGSHILFE set to: Modus_FA_SLV 3012 EAH - EAH_VERFAHRWEG_SLV_PHYS = Werte 00, 3C -> 00, 32 - "traverse" - distance that the seat moves away from the "memorised" position 3012 EAH - EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte 00, 64 -> 00, 3C "rear space protection" - limit of maximum travel backwards HU_CIC Removes disclaimer from PDC and Side View 3001 EBOX>MACRO_CAM_ LEGALDISCLAIMER set to: kein_id HU_NBT Removes disclaimer from PDC and Side View 3001>LEGAL_DISCLAIMER_TIME set to: kein_id Last edited by harry_fine; 01-30-2017 at 11:12 AM.. |
01-30-2017, 11:45 AM | #253 | |
119
Rep 512
Drives: 2020 Z4 M4Misano Blue
I don't actually have an X1 (X3 and M4), but I hadn't actually thought I could lock the car from the fob with the engine running in the first place. I guess I'll have to re-check this and see if it honks. I do know that on both of my cars the settings menu in iDrive includes a checkbox for sounding the horn on locking or unlocking. Isn't that also a menu option in iDrive? It is on my cars. I think you should only have one head-unit ECU. Don't you have NBT and not CIC?
2004 E85 Z4 3.0 Sport - Sold to brother | 2004 E83 X3 xDrive3.0i - Gone | 2011 E89 Z4 35is - Gone | 2011 F25 X3 xDrive35i - Gone | 2014 E89 Z4 E89 35is - Gone | 2014 F25 X3 xDrive 30i X3 - Gone | 2017 F83 M4 Cabriolet - Gone | 2017 F25 X3 xDrive30i - Gone
2020 G29 Z4 M40i Misanoblau | 2020 G01 M40i Phytonicblau Casa Suzana, vacation rental villa in Cozumel, Mexico |
01-30-2017, 12:30 PM | #254 | |
2374
Rep 8,364
IDrive configured is for alarm chirp when locking with engine off. VAM_HORN_AT_SECURE is for horn when locking with engine on. |
01-30-2017, 12:44 PM | #255 |
Rep 1
Hi guys,
does anyone have any instructions for High-beam assistant on by default? I just tried coding: 3000 HIGH_BEAM_ASSISTANT set to: aktiv werte=1 but not work. Thanks |
01-30-2017, 12:49 PM | #256 |
2374
Rep 8,364
01-30-2017, 02:24 PM | #257 | |
119
Rep 512
That raises the question of why anyone would ever do that.
01-30-2017, 03:05 PM | #258 | |
2374
Rep 8,364
Engine off --> lock vehicle --> lights flash & vehicle (with alarm) chirps, if configured in IDrive Engine off --> lock vehicle --> horn honks (not configured in IDrive) View post on imgur.com |
02-01-2017, 08:02 AM | #259 |
23
Rep 92
02-02-2017, 08:13 AM | #260 |
17
Rep 45
Dear all.
I want to code >> BDC_BODY 3040 Vamaster, 16 VAM_HORN_AT_SECURE On the comment said "If active, horn if lock/secure is triggered and no IDG inside while driving readiness" Would you please let me know what is the meaning for IDG? Thank you. |
02-02-2017, 09:19 AM | #261 |
126
Rep 243
I think it's just a fancy abbreviation for person. Almaretto I'm sure will chime in with the answer but that my 2 cents. Also just a heads up, this is so the horn won't beep when hitting lock when the car is on and running. Not just regular lock and unlock with the car off.
02-02-2017, 12:22 PM | #262 | |
2374
Rep 8,364
Acoustic_lock_confirm: if checked in idrive (& 302 alarm equipped), chirp when lock with engine off |
02-04-2017, 11:13 AM | #263 |
Rep 6
QUESTION ON MIRRORS
I have the following codes to close mirrors, and close immediately on locking. Close Mirrors/Windows/SunRoof from FOB or CA – set all to: aktiv 3056>KOMFORTSCHLIESSUNG_FB 3056>KOMFORTSCHLIESSUNG_PA 3110>ASP_BEIKLAPPEN 3110>ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN 3110>ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN Set Mirror Fold Delay Time to Instant upon locking 3056>KOMFORT_SCHLIESSEN set to: 00 And I see there is a code to unfold at 12 mph. But that doesn't make sense. Don't they have to unfold before I pull away from the curb so I can see traffic coming? Am I missing something? |
02-04-2017, 12:38 PM | #264 |
2374
Rep 8,364
Mine auto-unfold when I unlock vehicle. If you fold with interior button, then they do not. If not done already, they will auto-unfold when you reach certain distance and speed.
