DIY - Register new battery
03-21-2014, 08:36 AM | #111 |
13
Rep 390
Drives: BMW E90 33?i | 90 Integra B20
if you are replacing with same spec you can use tool32 to register a new battery.
|33?i e90|Platinum Silver black leather w aluminum trim|6spd|Sport|Premium|Mtec v3|Rockford Fosgate System| |2015 Lexus IS250 AWD|Pearl White w Tan int|Premium|Navi| |2000 integra DC4|Silver Gray int|5spd|B20 Motor| |
11-06-2014, 08:56 AM | #112 |
Rep 3
hi all
BMWhat supports battery registration and switching the battery type by a new in-App. tried it out yesterday, worked like a charm... and by the way, I saved a lot of time and money instead of going to my mechanic |
11-06-2014, 02:06 PM | #113 |
149
Rep 2,383
Great!!! just saw that too in the recent update. Good to hear it supports coding a different battery too!!!
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
11-12-2014, 10:33 AM | #115 |
BMW Enthusiast
35
Rep 79
Drives: 07 335i E92
Weird Issue
So after reading the forums and comparing notes, I figured I'd replace my dying OEM BMW battery with a similar one from Costco.
I was told by a service adviser that if replaced with a like for like battery, I wouldn't have to register it. Replaced the battery and it runs fine, except for the occasional discharge as I drive less than 10 kms daily. A month later now, I've finally began learning how to code and figured I'd look into registering the battery. The CAS module stated the car was coded to charge a 90AH AGM battery when the battery was lead acid (picture below). Should I recode the car to let it know that I've installed a lead-acid battery now? I'm using Kirkland Signature Auto Battery with fitment code H7. Any suggestions? |
11-12-2014, 10:23 PM | #116 | |
149
Rep 2,383
11-13-2014, 02:01 AM | #117 |
No 55mph
1622
Rep 8,476
My 09' came with the 90AH AGM battery
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
11-13-2014, 04:30 PM | #118 |
149
Rep 6,604
Drives: e92 335i
Can anybody register my new battery for me. I bought an Everstart maxx battery from Walmart H8 and need it register to my car. I am located in so. cal. If anybody can help me out that would be great.
11-13-2014, 05:09 PM | #119 | |
BMW Enthusiast
35
Rep 79
Drives: 07 335i E92
I wasn't too familiar with coding so I replaced a lead acid with a lead acid battery. I will take your advise and recode the car. Thanks for the input. |
04-09-2015, 12:18 AM | #120 |
532
Rep 2,084
Does the CCA of the battery matter? Seems like the coding that would need to be done for a new battery is only concerned with the capacity (Ah) of the battery and whether or not it is AGM.
It's impossible to find a non-OEM battery that has anywhere near the CCA of the OEM battery. Capacities can get pretty close though (Duralast makes a 92Ah AGM battery).
2013 135is DCT Carbon Black Metallic |
04-09-2015, 03:50 AM | #121 | |
Rep 64
04-09-2015, 10:00 AM | #122 | |
532
Rep 2,084
Updating the CAS module and VO only seem to inform the car of the CAPACITY and TYPE (AGM vs. regular) of the battery. There does not seem to be anywhere to tell the car what the CCA is (or any other information about the battery). Therefore, does it matter if the CCA is different than OEM?
04-09-2015, 10:18 AM | #123 | ||
Rep 64
04-09-2015, 10:24 AM | #124 |
187
Rep 1,677
BMWhat Battery Registration didn't work. :(
FYI - I took my car into my local BMW dealership yesterday to have the software updated (in an attempt to get it to take the AA tune it keeps rejecting. ). While my mechanic/friend did the flash ("under cover"), I asked him to check if the BMWhat app (after buying the add-on, of course) had properly registered the battery that I put in almost two months ago. It had NOT.
I contacted iVini/BMWhat and they sounded very disappointed and wanted me to try again but...it was too late. My friend had already done it for me at the shop. So...you might want to have your BMWhat battery registration double-checked.
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11) |
04-09-2015, 10:37 AM | #125 | |
Rep 64
04-09-2015, 11:06 AM | #126 | |
532
Rep 2,084
04-09-2015, 04:03 PM | #127 | |
255
Rep 2,547
04-10-2015, 10:47 AM | #128 |
Rep 4
Anyone in WI that can register a battery for me?
Hi, new to the forum and BMW's. I just bought an 08 e90 335i 6mt on Monday, and my battery died on Wednesday. Dang. I ordered the BT cable but it will likely be a week before I see it. Is there anyone in the madison area that can reset the computer for me if I get a like battery? If so what is your favorite beer? Thanks.
Jason |
05-13-2015, 11:29 PM | #129 |
Rep 13
I replaced my OEM 90ah 160RC 720CCA - H8-DLG 150RC 900CCA.
When registering the battery, the only input it asked for was "90ah". I thought I had to input CCA as well! I know many people have used this H8-DLG and the car seems to start easier. Only issue was resetting passenger window open/close after disrupting the battery connection. Working fine now thanks to this thread http://www.e90post.com/forums/showth...esn%27t+adjust Is inputing my new CCA a critical step I missed??? I did get the "registered battery complete" tho... Procedure to register new battery using INPA: Step 1: select BODY from the left hand pop-up menu Step 2: select POWER MODULE in the right hand list Step 3: select ACTIVATE from the next menu Step 4: Select ACTIVATE2 from the next menu Step 5: Then select F7 - Register battery replacement. Almost instantly you get the message: "Register battery replacement Activated properly."[/QUOTE] |
07-21-2015, 07:37 PM | #130 |
BMW Fan
Rep 7
I'm hoping I can get some help registering a new OEM battery. A friend has a 2008 328iT and bought a new battery at the dealer, which is identical to the old battery.
Using Tool32 I tried to register the battery using the MSV80 data file, but get the following error: ERROR_ECU_CONDITIONS_NOT_CORRECT_OR_REQUEST_SEQUEN CE_ERROR I'll admit that most of my diagnostic and programming experience is the older BMWs (E46, E39, E53, etc) and I have very little experience with the E90. So I'm hoping that someone is able to point me in the right direction so I can get his new battery registered. |
07-21-2015, 11:13 PM | #131 | |
524
Rep 1,527
