F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 JB4 Shift Behavior
ARMA SPEED
      09-01-2016, 11:07 PM   #1
dead.pixel
103
Drives: 2021 BMW M2 Competition
Just finished installing the JB4. Power feels good, although turbo lag is more prominent. I noticed when shifting on power you can feel a loss of boost. It feels like the turbo is trying to build up again. In stock form it feels seamless. Is this expected?
Note: Still waiting for Bluetooth kit to get some logging.
      09-02-2016, 02:11 AM   #2
HitmanHearns
97
Drives: 14' Infiniti Q50 / 16' Audi A4
How many Miles have you driven on the jb4?
      09-02-2016, 07:34 AM   #3
stxf30
stxf30's Avatar
94
Drives: '13 F30 335i MSport
Did you buy it new or used? Make sure you are running the latest Firmware. I had a problem with mine. Ending up finding out that the previous owner had reduced peak boost to 8lbs in 3rd. So I'd take off like a banshee and then it would fall on it's face. Pretty embarrassing, got walked down by a chick in a 135.
Make sure your user adjustable settings are set to default.
Ref this: http://www.n54tech.com/forums/showthread.php?t=18588
2013 GSM 335i MSport
      09-02-2016, 09:35 AM   #4
Mike@N54Tuning.com
BimmerPost Supporting Vendor
4918
Drives: 2007 335i, 2015 M3
Shouldn't have any less torque than stock at any time so do some logs when you can to evaluate.
Mike
      09-02-2016, 10:13 AM   #5
dead.pixel
103
So far only a few miles. I'll have another 60 on it by tomorrow night.
      09-02-2016, 10:17 AM   #6
dead.pixel
103
I bought it new and updated firmware to version 3. I verified the user settings were default. You would think there would be a button to apply defaults. The windows app is pretty janky. Waiting on a Bluetooth adapter from extreme power house to use the iOS app.
      09-02-2016, 10:19 AM   #7
dead.pixel
103
Mike
There is more toque, it just doesn't come on as smooth. You put your foot down and it takes a second for it to spool up. Perhaps because of the increased psi it take longer to build.
      09-02-2016, 10:25 AM   #8
stxf30
stxf30's Avatar
94
Are you in Sport+ with DSC disabled? TC or DSC could be causing a drop in power to maintain traction. Something definitely isn't right if you feel like you are experiencing more lag. Also, what other mods do you have?
      09-02-2016, 12:36 PM   #9
dead.pixel
103
I almost always drive in Sport+ with manual paddle shifting. I just put another 40 miles on the tune and the lag seems to be better while in gear.
However, shifting near redline in 1st and 2nd is really rough. The power and boost feels like it cuts out and it is quite jerky.
I know logs would help, but the Bluetooth Connect Kit has been sitting at Extreme Power House for the last 5 day "awaiting pick-up". I emailed Mike, hopefully I'll have it soon.
Edit: I have no other mods
      09-02-2016, 11:35 PM   #10
Baldmonkey22
15
Drives: 2016 340i
Same here, it's like a hiccup when wot, and the trans shifts, turn jb4 off and it shifts smooth again.
I love the power but not the shifting, so I have it turned off
      09-03-2016, 12:01 AM   #11
dead.pixel
103
Have you talked to burger motorsports about it?
      09-03-2016, 10:19 AM   #12
JamRWS6
191
Drives: 2022 X3M Competition
I feel the exact same thing in Comfort mode. Enabling DSC (TRACTION button or Sport +) seems to cure this for me. I'm guessing it is the ECU dropping boost/ closing the throttle but I have not logged it. With DSC on the car also doesn't short shift which helps because this engine makes power all the way to recline.
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
      09-03-2016, 06:28 PM   #13
Baldmonkey22
15
Drives: 2016 340i
Yes I've made them aware...
      09-03-2016, 08:30 PM   #14
Mike@N54Tuning.com
4918
The B58 JB4 has timing control, maybe its set to pull too much timing at the shift for your fuel/conditions. For tuning advice you'd need to post a log of the problem to the n54tech support forum. BMS doesn't sponsor/read this forum.
Mike
      09-03-2016, 08:39 PM   #15
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Mike
Timing control??? Care to explain how?
Lemania 2320
      09-05-2016, 12:50 PM   #16
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
It's in beta for the B58, I wouldn't expect it to be perfect yet. Like others suggest do some logging and contact support. They are pretty smart cookies.
      09-15-2016, 12:57 AM   #17
HitmanHearns
97
Any updates? Mine does the same thing. It almost seems like at WOT near redline it stops for a second and it picks backup but you lose a lot of ground when that happens.
All I have is BMS intake and the jb4.
      09-15-2016, 09:53 AM   #18
//M
243
Drives: M2 Comp
Yeah that was a bit overoptimistic, it spoofs the IAT to lower timing but it's very crude and can't react fast as it would throw a fault. So basically JB4 tells your engine when it's on boost that IAT are roughly 140 so it pulls timing.
      09-15-2016, 11:07 AM   #19
HitmanHearns
97
I will do some data logs. My theory is it might be the BMS intake causing an issue or 91 crappy fuel.
2016 BMW 340i M Sport | BMS Intake | JB4| ER Catless DP |
2018 Audi A4 S-Line| Daily Driver | Very very slow & boring|
      01-30-2017, 08:45 AM   #20
mikeleeyh
mikeleeyh's Avatar
40
Drives: 2016 BMW 340i xDrive M Sport
Any updates regarding this? Did the shifting behavior fix itself as you kept driving it? Or did the new firmware update fix the shifting behavior?
Edit-- Update fixed it
2016 340ix M Sport /// Mineral Grey Metallic /// AWE Exhaust & Midpipe /// BMS Intake & OCC /// JB4
      02-01-2017, 11:45 PM   #21
B58M240i
13
Drives: M240i
I have this same issue with and without the jb4. The higher boost/extra power just makes it more noticeable. Turning traction control off helps but it still feels like I'm being held back by electronics and turbo lag. I still love my car but this kind of stuff makes me miss how raw my mustang was.
      02-02-2017, 07:13 AM   #22
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Have you tried a throttle body adaption reset - that may help
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
f30post
