03-23-2019, 08:53 AM | #595 |
52
Rep 105
You should see F48 in the list on the CAFD tool. You won't see 5DF on the F56 (mini)
03-28-2019, 01:19 PM | #596 |
28
Rep 109
Anyone had luck with the HUD turnsignals?
1- Code KOMBI / HUD_PIA_BLINKER = aktiv 2- Code KOMBI / BLINKER_HUD_ENABLE = aktiv 3- Code HU_NBT / HUD_TURNSIGNAL = aktiv And still not showing - this is on a Oct 2018 F48 with black instrument panel |
03-28-2019, 04:19 PM | #597 |
52
Rep 105
I have tried several different things to get that working. From my understanding you won't be able to get it. -- I believe it may be due to the HU
03-29-2019, 02:11 AM | #599 |
Rep 21
03-29-2019, 04:19 AM | #600 |
28
Rep 109
03-29-2019, 10:10 AM | #601 |
52
Rep 105
03-30-2019, 08:35 AM | #603 |
49
Rep 69
Hello!
Have you tried changing the default distance of ACC and easy entry of the power seat with the X1 (F48) / X2 (F39) manufactured in 2018? |
03-30-2019, 10:00 AM | #604 |
681
Rep 912
I do not havE power seats so have not tested the settings for F48
My cheat sheet shows Driver seat easy entry/access -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 64 -> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 00 Do search to find exact module location, think 3000 is in main HU, suspect other is seat module itself. If you play around with the werte hex values for seat travel and rear seat safety room you can get the front seat to travel back a considerable distance. I am obliged to mention on health and safety grounds for the “idiots” that remove too much rear seat safety room and you could cause crush injury to a rear passenger. Just saying, you know —> for those people that need “do not place live animals in this microwave” stickers otherwise pet bath time ends in tragedy. Last edited by MJE60; 03-30-2019 at 10:16 AM.. |
Takabo49.00 |
03-30-2019, 11:56 AM | #605 | |
49
Rep 69
Thank you for the your cheat sheet information. But... For some reason, I could not find the below on My F39. 3012 -> EAH_VERFAHRWEG_SLV_PHYS 3012 -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS In the EAH only have "EAH_0_42_255". Do you have any other ideas? P.S. I found "EINAUSSTIEEGSHILFE = Modus_FA_SLV". |
03-30-2019, 02:41 PM | #606 | |
2376
Rep 8,364
Takabo49.00 |
03-30-2019, 02:45 PM | #607 | |
681
Rep 912
These are the settings For changing ‘ Easy Entry": the -> shows changed values So for einaussteigshilfe change from nicht aktiv to modus_fa_slv SM2 IS THE MODULE LOCATION FOR HIS CHANGES. SM2 - 3000 - EINAUSSTIEGSHILFE = nicht_aktiv (default) -> Modus_FA_SLV (Easy Entry seats) SM2 - 3012 EAH - EAH_VERFAHRWEG_SLV_PHYS = Werte 00, 3C (60) -> 00, 32 (50) SM2 - 3012 EAH - EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte 00, 64 (100)-> 00, 3C (60) The arrow (->) indicates the value CliveL changed TO, from the original value. Please note, I do not have this option but if you cannot find module or codes, check you actually have electric memory seats otherwise coding will not help, hardware is also required. |
Takabo49.00 |
04-01-2019, 02:55 AM | #608 |
49
Rep 69
Hello!
Easy entry of the power seat was activated only with the following settings. BIMMERCODE ECUs → Seat Module Driver(CFAS_PLX_1)→ Expert Mode → EINAUSSTIEGSHILFE → Modus_FA_SLV(Default:nicht_aktiv) But... The seat position of my driving position is more behind (^ ^ ;; It seems that I do not need Easy Entry. https://youtu.be/vqNHXLkCT9Q Thank you for teaching me. Last edited by Takabo; 04-01-2019 at 03:13 AM.. |
04-01-2019, 03:19 AM | #609 |
681
Rep 912
Yes, einausstiegshilfe IS easy entry (the word is German for entry exit assistance). You have activated easy entry. Congratulations.
If you still want to adjust how much the seat moves back then other two settings can be adjusted. If you are struggling to find settings in E-sys then consider using Bimmercode. Last edited by MJE60; 04-03-2019 at 03:14 AM.. |
04-13-2019, 04:46 AM | #612 | |
681
Rep 912
I found NCD/CAFD tool does not well well for F48, the suggested parameter changes in many cases were wrong and out of date when I checked for change from 6UN to 6UP. Look at thread from PurePulse64 he posted more information on 5Df and also said tool was not totally helpful. Last edited by MJE60; 04-13-2019 at 05:20 AM.. |
04-13-2019, 11:07 PM | #613 |
49
Rep 69
iDrive Navi AutoZoom succeeded.
I have the following settings.
BIMMERCODE ECUs → Headunit (HU_NBT_EVO) → Expert Mode → NAVI_AUTOZOOM(Search) → aktiv (Default: nicht_aktiv) And if you set the destination in the navigation ... iDrive Navi AutoZoom succeeded. Are there any other successful people? P.S. AUTO_MAP_ZOOM has not changed the setting. Last edited by Takabo; 04-13-2019 at 11:27 PM.. |
04-14-2019, 11:06 AM | #614 | |
681
Rep 912
Takabo49.00 |
04-14-2019, 09:52 PM | #615 | |
49
Rep 69
My F39(October 2018 production) version of Navi is as the picture. All Japanese specifications of BMW F 39 & F 48 are this. When I checked the option at VIN, it was as follows. ——- 609 Navigation System Professional Navigationssystem Professional 610 Head Up Display Head-up Display ——- Are Japanese specifications different from other countries' navigation specifications? |
MJE60681.00 |
04-15-2019, 02:32 AM | #616 | |
681
Rep 912
Yes your car has different HU to most X1 in other countries. X1 (F48’s) in most countries have business navigation and Entrynav HU. You have an NBTevo HU with optio s609a professional navigation (also why you can zoom maps) which has much better graphics and quality navigation. This also means you are able to easily buy fsc codes from 3rd party sellers. If you do not have CarPlay as an example , you can install easily. |
Takabo49.00 |
