04-30-2019, 05:34 PM | #45 | |
5939
Rep 10,314
04-30-2019, 09:07 PM | #46 | |
David
787
Rep 2,009
it's not that I can't afford it like many people think, it's that i want a functional car. Which KW is known for, just not designed properly for the f31 |
05-01-2019, 12:24 AM | #47 | |
David
787
Rep 2,009
There are many members with KW on the F31 that report it's pretty much slammed at max height in the rear, and shared their pictures Did you have pictures of yours Last edited by 328iX; 05-01-2019 at 12:38 AM.. |
05-01-2019, 02:43 PM | #48 |
21
Rep 81
328dX -
Thanks for the seller info. Searched his auctions and uncovered two different Eibach ProKits for the F31. One, ending ...14-22 has max loads of 965/front and 1285/rear while the second, ending ...15-22 has them at 1010/front and 1285/rear. |
05-01-2019, 02:44 PM | #49 |
David
787
Rep 2,009
I've got the first one. 14-22
05-02-2019, 12:53 AM | #50 |
1153
Rep 1,523
Pull out a tape measure and measure the middle of center cap to the top arch of the fenders. I am at 14" on all 4 corners with another .5" to go up if I wanted to.
05-02-2019, 12:55 AM | #51 |
David
787
Rep 2,009
05-02-2019, 12:57 AM | #52 | |
David
787
Rep 2,009
05-08-2019, 02:09 PM | #54 |
David
787
Rep 2,009
Yes. I have decided to go with Koni special active struts+ the Eibach springs listed above.
They are going in this weekend. Everything will be new so it will truly show how the springs sit.
05-08-2019, 08:39 PM | #57 |
70
Rep 339
Hope it fixes the problem. Any chance you have seen this thread?
https://f30.bimmerpost.com/forums/sh....php?t=1429989 Not sure if you have seen this spacer thing the euro people are using. I want to buy springs for my Adaptive suspension! This car is so wobbly compared to a M3/Mini Cooper!
2003 M3 Coupe LSB/Blk
2011 M3 Sedan AW/BLK 2017 330XI Wagon BLK/BLK 2022 X5 M50I DG/BLK |
05-08-2019, 08:57 PM | #58 | |
David
787
Rep 2,009
15, 30, and 50mm |
05-09-2019, 01:44 PM | #60 |
4041
Rep 3,548
Drives: 328d Wagon, M2 Comp, i4 eD35
I'd recommend the E10-20-031-15-22 kit over the E10-20-031-14-22. The E10-20-031-14-22 front spring is just about a half inch shorter (10-13mm). I didn't like how often I scraped with the E10-20-031-15-22 kit. Brand new dampers might give him a bit more ride height than broken in ones (Bilsteins definitely require some break in).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-11-2019, 12:06 PM | #61 |
1153
Rep 1,523
you should be replacement the nuts and bolts too. Most of them are 1 time use.
05-11-2019, 05:22 PM | #62 |
570
Rep 1,463
I have the H&R sport springs and they're not bouncy, but I do have the M adaptive shocks. The H&R super sport springs will lower the car more and most likely cause it to bounce.
05-12-2019, 01:34 AM | #63 |
David
787
Rep 2,009
Hey guys, here's an update. Install went fairly smooth, lets just say it's easy, but long and tiresome. Tackled the job with zcspec
The car sits great now, it appears to be near **level** with a possible slight front rake, which is what I was looking for. I've driven it about 100 miles so far and will remeasure tomorrow. Photos are right after install and after doing a 1 mile loop. The suspension combination with Koni Special Active/Eibach feels very, very good, this not the combination for those who want to be slammed. These are active struts meaning they react to road conditions. To summarize, normal cruising gives you a factory comfort ride, with any sudden jolts or movement, the struts stiffen up. (pot holes, rough roads, cornering, etc) What I've noticed: The car stays almost completely level on launches or when getting on the brakes, this is odd sensation coming from the normal huge nose dive. Handling is excellent, comfort is excellent. |
05-12-2019, 02:07 PM | #65 |
David
787
Rep 2,009
Took some more, hope this helps! This is after I filled up my tank too, so the rear did drop 3-5mm
05-14-2019, 12:38 AM | #66 |
214
Rep 456
I can't believe the amount of research you put into this project and am search many others will thank YOU for the dedication. I'm sorry the first go wasn't to your liking, but who in their right mind would accept the reverse rake look?
With the current setup, it's perfect and I wouldn't change a thing. The springs and your choice in upgraded shocks is spot on. On to the next project! |
328iX786.50 |
