ZPOST
  TireRack
      11-07-2010, 11:53 PM   #67
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
How do you get more OEM then where it's located when it became a standard feature. Also I don't have to have the ash try open to have my iPod connected.
Protip: Get a line out dock cable for the iPod, it helps it sound a little better.
Straightaways are for fast cars, Corners are for fast drivers.
      11-08-2010, 09:23 PM   #68
r4gs
Viper Driver
Singapore
36
Drives: F-16
^i use a car-charger for my phone, so the cigarette lighter needs to be accessible and i felt it was a neat setup with the ashtray aux input. granted, it serves the exact same purpose as the oem located aux input, and was a more expensive mod.
      11-21-2010, 05:50 PM   #69
r4gs
Viper Driver
Singapore
36
Drives: F-16
here's a photo of the oem ashtray aux input in case anyone's considering it and how it looks:
      11-21-2010, 06:34 PM   #70
tekmoe
tekmoe's Avatar
55
Drives: ///M
Did you get that from Bavauto or Tischer?
      11-21-2010, 06:40 PM   #71
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
looks good
      11-21-2010, 07:28 PM   #72
r4gs
Viper Driver
Singapore
36
Drives: F-16
tischer. i listed the part number in a previous post.
      11-22-2010, 01:11 PM   #73
BMW Maniac
22
Drives: Former Z4M coupe owner
I like the look of the OEM ashtray with Aux input.....I'll have to put it on my christmas list.
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet
      02-03-2011, 04:29 PM   #74
radhat
radhat's Avatar
Drives: 2003 BMW Z4 Red
I didn't find it under the part you listed.
I found it as PKAUXINPUT* at http://www.trademotion.com/partlocat...catalogid=4462
Hope this helps.
      02-21-2011, 03:55 PM   #75
03z4ct
Drives: Z4
I am assuming that with the aux in I could use more than an Ipod? Like my Droid phone? Will it work?
      02-21-2011, 04:18 PM   #76
r4gs
Viper Driver
Singapore
36
Drives: F-16
^absolutely. u can use any device with a 3.5mm audio output.
      02-21-2011, 04:32 PM   #77
03z4ct
Drives: Z4
Thanks I just ordered mine!
      02-24-2011, 07:42 PM   #78
03z4ct
Drives: Z4
Talking
Okay received the aux input from tishers. First thing no instructions on the instalation? Thank goodness for the forum. Not so easy to remove the vents. You really have to use force to wedge a credit card in there! Honestly kind of scary until you get frustrated and just shove it down between the vent and the dash trim. Once that's done you can access the radio easy as the two screws are right there.
The second part is removing the bottom trim to route the aux cable back up... Have to tell ya not easy as I couldn't get the back part to come lose. Finally after about 20 minutes I was able to route the cable around and underneath. never really got the back part with the heated seats button off?
Then just plug and play.
Overall for $68 bucks they really should include the cable and some decent installation instruction.
      02-24-2011, 08:21 PM   #79
r4gs
Viper Driver
Singapore
36
Drives: F-16
^glad u were able to work the diy installation without too much trouble. there really wasn't a need to remove the aircon vents to access the radio head unit itself, i simply removed the plastic panel right under the hvac controls and used my fingers to route the connector cable to the rear of the head unit itself. the aux connector is literally plug and play, so u just have to 'click' it into place. $68 is for an oem part and, of course, bmw would NEVER be expecting their customers to install accessories themselves....
      03-11-2011, 09:53 PM   #80
denial512
Drives: 2006 Z4 3.0si
Question installed, but not great signal
I just installed the E46 kit into my '06 Z4. Mine was the Business CD with no NAV.
My unit didn't have the connector at far left with black/brown wires. The slot was completely empty.
I ended up removing the the connector cover, but since I didn't have another connector to move the pins into, I ended up just using this 10 pin connector and plugging it into the 10 of the 12 pins.
AUX is always available, but when I have my HTC EVO hooked up, I have to crank the volume REALLY high to hear it. Clarity seems ok, except there seems to be much less bass response then normal. And when there are bass thumps, the stock speakers sound like they are maybe clipping (just not sounding right).
I don't believe that the E46 wires have resistor + 2 capacitors in it. Are these necessary for proper signal ?
*UPDATE* So it's my damn HTC Evo, putting out a sorry signal. I plugged in my 5 year old ipod shuffle, and the sound is solid.
Anyhow, total cost was $39+tax, and I installed it into the panel below the A/C.
      05-25-2011, 09:14 PM   #81
rkstar9
75
Drives: '10 X5 3.5D
Originally Posted by panicopticon View Post
After playing around with installing the Aux input for a little while I thought I'd contribute my experiences. I took some photos (but probably not enough) along the way, in the hopes that it helps.
BFest Z4 Aux Install Instructions
BFest Z4 Vent Removal Instructions
The method I used for removing the vents seemed to work pretty well. I cut two strips of credit card just a bit narrower than the openings for the vent clips. I inserted them at an upward angle, towards the front of the latch openings and wiggled them till they slipped over the top of the latches. A gentle tug and the assembly came out. The latch openings are only maybe .25-.5" back in the vents, really just behind where the slats end (see photos).
Following the directions from earlier posts there is a swing latch that connects the radio to the radio wiring harness, lift it up gently to release it. There is a press latch that attaches the antenna wire to the radio, its located on the right side of the antenna connector, you may need a small screw driver to depress it to get it to release.
I used the E46 cable (as recommended in an earlier post), which I got from eBay for $35 shipped. To use this cable you'll need to remove the gray plastic housing from the outside of the connector, there is a latch on one side of it, simple lift and the black plastic connector inside should release and slide out. Then remove the wires from the black plastic connector. You'll probably need a knife or paperclip to depress the latches for each pin.
You'll then need to remove the black connector from the radio wiring harness assembly (its the one on the lower left in the photos). Besides the position, it only has two wires going into it -- brown/black and black/gray as I recall. This connector is held into the wiring harness by a latch located at the rear. Depress the latch and pull and it should release. You'll notice that like the E46 harness, this is harness is also composed of two pieces. You want to remove the retainer housing of this harness. Slide the wires in to the connector in the locations described in the BFest link above.
Put the assembled cable back into the radio wiring harness, it should click into place snugly.
Rather than modify the ashtray, I slacked off and fed the aux wire down into the passenger wheel well near the map holder, using the time tested coat hanger method. I secured the wire in the dash under the ash try to insure that it doesn't place any stress on the radio wiring harness.
Hope this helps.
Thanks for these instructions my car needed to have some cables swaped around withing the 12 pin connector so This took care of it.
      06-11-2011, 10:30 AM   #82
Joshaj24
Drives: 2004 Z4 3.0i
I just installed the ashtray aux input from bavarian, but I am having an issue getting the supplied screw into the factory hole. It is the last step and everything looks great except for this. Any suggestions?
      06-13-2011, 04:35 PM   #83
E86Z
64
Drives: 3.0si
Mine from husker bmw (http://www.bmwmercedesparts.com) bought the e46 one and just removed the white clip and plugged in the pins.
edit: crap that looks nasty, its been cleaned lol i promise
      06-13-2011, 05:49 PM   #84
r4gs
Viper Driver
Singapore
36
Drives: F-16
the holes should align perfectly for the supplied screw. i'm presuming u've tried wiggling the ashtray (it should fit very snug anyways)? otherwise, the screw isn't essential to secure the ash tray.
      04-13-2012, 07:40 PM   #85
nmnicho
Drives: 2006 Z4 roadster
Aux install went well
Just wanted to say thanks- This info was really helpful. I ordered the Part from Bimmerspecialist.com : part #82 11 0 153 367 - GENUINE MINI - and the install took like 30 minutes from start to finish. It was really straightforward and splicing the pins into the existing adaptor was incredibly easy.
$40 bucks and a half hour did the trick- now have iphone tunes in the Z4 and can talk through the phone when it is connected to the aux.
The only thing I did different was I used a stiff rubber cooking pan scraper to gently pull out the center vents once i used two small flathead screwdrivers to pull down the tabs.
This is the kind of scraper I used: http://www.amazon.com/Progressive-In.../dp/B002BFHY4C
You probably have one in your kitchen.
thanks
      05-12-2012, 04:03 PM   #86
Jmanscotch
is a Texan
Jmanscotch's Avatar
49
Drives: '09 135i - 6MT SOLD
I took some pictures to help since the OPs pictures are no longer there. http://www.zpost.com/forums/showthread.php?t=610757
- Jake
      08-06-2015, 08:08 AM   #87
BonesXX
Drives: 03 Z4 3.0
This method to get to get me all of about 3 minutes to have my AUX working. Thanks all!!
      09-15-2015, 08:18 PM   #88
seattlescape
Drives: 2004 BMW Z4 3.0i
I got a 2004 Z4 a few days ago and my first DIY project was aux input. Went on Amazon and got a cable that seems to work great so far and cost only $11. Required a little more effort than the Mini Cooper OEM one, but also cost less. Definitely cheaper than the ashtray kit.
https://www.amazon.com/gp/aw/d/B00PL...?ie=UTF8&psc=1
I bought a coiled aux cable for $6 as well.
zpost
