08-19-2020, 09:01 AM | #24 |
756
Rep 2,149
08-19-2020, 09:21 AM | #25 | |
259
Rep 699
Don't trust my math but I came up with about 24 inches. There are formulas out on the web in several places. Find out the rpm that the drone is loudest and plug that in to the formula. I had a really bad drone in my Gladiator at about 2100 rpms after I replaced the center 2 mufflers with a Magnaflow. A 32" J pipe absolutely killed it. |
08-23-2020, 02:51 AM | #26 |
293
Rep 644
Drives: 2018 6mt AW m2
I agree that my factory MPE sounded great, but that damn drone was awful. I replaced it with stock exhaust for quite cheap and the drone is gone. The magic of resonators.
08-23-2020, 12:01 PM | #27 | ||
2432
Rep 2,526
((1125) / (RPM * 6 * (1 / 60))) / 4 At 3000 RPM, that works out to 0.9375 feet, or 11.25 inches. 1125 = speed of sound in feet per second. 6 = number of pulses per revolution in a 6 cylinder engine 1/60 = convert from minutes to seconds 4 = quarter the wavelength to cancel out the resonance. This is actually an interesting idea, I'm just curious where in the exhaust you'd be able to put it. Perhaps right before the y pipe, and have it tuck back behind the exhaust can? Might be some room there. |
08-24-2020, 08:34 AM | #28 | |
259
Rep 699
08-24-2020, 08:45 AM | #29 | |
2432
Rep 2,526
So with that in mind, we're looking at a 22.5 inch pipe to cancel the resonance at 3000 RPM. |
09-08-2020, 09:19 AM | #30 |
354
Rep 1,681
For DCT owners with the Fabspeed sport cat and MPE, is the drone present even with the faps closed?
And how is it on the highway in sport +?
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 Last edited by Nicname; 09-08-2020 at 11:49 AM.. |
09-08-2020, 09:54 AM | #31 |
259
Rep 699
09-08-2020, 11:48 AM | #32 |
354
Rep 1,681
Sorry I meant for those with both of them installed. I'll update my post
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
11-17-2020, 05:47 AM | #33 |
201
Rep 425
Does the drone only exists when cruising in the rpm range like for freeway driving? How about when accelerating through the gears around the 3k rpm mark - is the drone evident then?
11-17-2020, 08:54 AM | #34 | |
2432
Rep 2,526
BMWF87Melb201.00 |
11-18-2020, 04:10 PM | #35 |
595
Rep 450
I have MPE and fabspeed. Drone is definitely there for both. As you cross through the 3000-3500 range during normal driving, you get that deep reverberation for a second or two. I drive mostly city and limited highway and it's never bothered me but I could see how those with long highway commutes would get tired of it.
11-18-2020, 04:17 PM | #36 | |
201
Rep 425
Not sure if you had the MPE first, but curious to know how much as a percentage the dp would contribute to the drone. |
11-18-2020, 09:14 PM | #37 |
595
Rep 450
I think it's mostly the MPE that drones but I'd imagine downpipe accentuates it. I did DP first with stock exhaust and there was pretty much zero drone with that combo.
BMWF87Melb201.00 |
11-18-2020, 09:20 PM | #38 | |
201
Rep 425
03-14-2024, 11:35 AM | #39 |
Rep 1
I have F87 M2 MT and was thinking of getting MPE .. do you enjoy the MPE / is it worth it? How bad is the drone at 60-80mph!?? How loud is it on cold start up? Worried about neighbours getting upset …
03-14-2024, 04:21 PM | #40 |
4485
Rep 877
Drives: ///M2
I would also NOT recommend the MPE due to drone.
I believe a dual exit exhaust from the downpipe back would be better with drone, as well as having an exhaust that completely channels through the muffler instead of the T like design on the MPE’s muffler. If you have a DCT you should avoid the drone on the highway with the lower rpms of the 7th gear but I would still recommend another exhaust personally.
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
03-21-2024, 03:31 PM | #42 |
17
Rep 47
So has anyone successfully dialed out the 3KRPM drone from the MPE with a resonator? I love the sound and appearance of the exhaust, but do wonder if that aspect could be fixed.
03-21-2024, 04:01 PM | #43 |
2332
Rep 4,183
I have an M235i with a full exhaust and MPE, plus a ***less downpipe. I don’t recall the drone being that terrible before, but it does sound a little annoying now.
You could do a vibrant resonator or a hemholtz one.
Mods: Yes.
03-21-2024, 06:24 PM | #44 |
4485
Rep 877
Drives: ///M2
I’ve gone through many different set ups between catless/HJS 300, m2 resonator + MPE, MPE w/o the res and nothing really worked. The res did not affect the highway drone but it did a little to help on the street.
The worst setup I had drone wise was the stock DP and MPE. The best I would say is the HJS+res+MPE, although I’m sure a stock exhaust would help even more. Catless and HJS didnt change the drone for me to any noticeable levels but it did get a little quieter. Nothing really helped. I think the issue is in the single pipe exhaust and the design of the MPE only makes it worse than the stock muffler with the drone.
