04-27-2024, 03:22 PM | #1 |
374
Rep 557
128i - harness above engine, plastic clip mounts
Somehow, the three mounts that hold the wiring harness (above the motor) in place have broken, see pictures. What do I need to do to fix this? Plastic gets brittle w heat
04-27-2024, 06:33 PM | #2 |
510
Rep 325
I don't know for sure without seeing it in person or looking at my car and I'm a bit too lazy to do that rn.
I think you either need 12527532268 or 12527534161. I could be wrong, double check realoem diagrams (i found these under Engine Electrical System).
2011 BMW 128i 6MT M Sport - Alpine White on Terracotta w/ Glacier-Silver trim - Koni Yellows w/ H&R Sport Springs, M3 Control Arms, Euro Intake, BMW Performance Exhaust, 3.73 Diff w/ RacingDiffs LSD Conversion, Black Line Taillights, M Performance Grilles, lots-o-maintenance
cerealwars87.00 |
04-28-2024, 01:28 AM | #3 |
96
Rep 271
I think this might be the lower part of the cabin microfilter compartment, part #2 on this page: https://www.realoem.com/bmw/enUS/sho...diagId=64_1428
I also have the driver's side tabs broken off, and the center is not held up very solidly, either. A fragile part that isn't inexpensive. Good luck.
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
04-28-2024, 09:02 AM | #4 |
374
Rep 557
Thanks, I’ll do more research and report back
This could be a job for the all-powerful “zip tie” in matte black |
04-28-2024, 05:12 PM | #5 |
BMW Owner Since 1971
2276
Rep 1,422
Drives: 1964 700 Sport Cabriolet
I've been thinking maybe a drill and some push-pin rivets like the trunk linings use?
04-29-2024, 08:57 AM | #6 |
830
Rep 1,017
My cabin air filter cover tabs were very brittle and I snapped both front tabs off when I tightened them down one time. A replacement cover wasn't too expensive. As mkeiser said, you probably just need the perch which is only around $30. Considering you need to pull that harness almost any time you do something under the hood, I would fix it properly.
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
jdt10768373.50 |
04-29-2024, 09:19 AM | #7 | |
374
Rep 557
04-29-2024, 03:04 PM | #8 |
144
Rep 118
Don't they slide in here?
04-29-2024, 03:38 PM | #9 |
374
Rep 557
No, it looks like they should - but look about 3/4" to the right of your arrows and you'll see where they are supposed to slide/clip in to the little box shaped pieces (the left hand box is broken / bottom broken off)
05-01-2024, 11:24 AM | #10 | |
384
Rep 301
Drives: 2010 128i ZSP 6MT
(I have the same problem and it is in my saved items on FCP Euro for sometime when I have something approximating disposable income)
2010 128i ZSP 6MT Coupe
Deep Sea Blue (Tiefseeblau) Metallic Style 264 Wheels Lemon Boston Sport Interior Last edited by Donkeyshins; 05-01-2024 at 11:29 AM.. |
19Neil69.50 |
05-01-2024, 01:27 PM | #11 |
374
Rep 557
@Donkeyshins Yes, I ordered one yesterday from Dealership using CCA discount 85$ - painful, because I know I didn't break them
Donkeyshins384.00 |
05-03-2024, 11:16 AM | #12 |
384
Rep 301
Yeah, they just weren't designed to last more than 10 years given the heat soak from the engine. At least it is exponentially easier to replace than the partially-soy-based-insulated wiring in E46 LCI headlights, just spendy.
Deep Sea Blue (Tiefseeblau) Metallic Style 264 Wheels Lemon Boston Sport Interior |
jdt10768373.50 |
05-03-2024, 01:11 PM | #13 |
374
Rep 557
funny, the first piece ordered for me (by dealer) arrived: broken. they reordered and I hope to install this weekend
mkeiser510.00 Donkeyshins384.00 |
05-06-2024, 08:05 AM | #14 |
374
Rep 557
Fixed.
05-21-2024, 03:27 PM | #15 |
Rep 4
When I purchased my 128i the previous owner had ziptied them together. It was the bottom receiving clips that had snapped off. I ended up ordering a new one off Ebay. I have the Vanos recall at the stealership next month and I'll be shocked if they don't break them again. I'm also positive they'll deny it.
jdt10768373.50 |
05-22-2024, 10:31 AM | #16 | |
374
Rep 557
05-22-2024, 10:49 AM | #17 |
220
Rep 112
I just drilled a hole through from the top side and riveted the old cable holder into place, now when you remove the cowl you just open up the cable tray and leave the cables loose on top of the engine.
Really don’t need to keep the cable inside the tray when you remove the cowl. |
