07-02-2015, 04:19 AM | #1 |
15
Rep 166
135 spare tyre
Can another confirm this part number for BMW space saver 17" fits over the front calipers of the 135i???
#36116750007 I no long want to have a full size spare in the boot as i need the space. Last edited by Prolifik; 07-02-2015 at 05:07 AM.. |
07-05-2015, 03:16 PM | #4 |
European Editor
10642
Rep 22,992
Any 17 inch wheel will be needed to clear the front brakes of a 135i. At first I used BMW's euro space saver spare tire. But the very first time I used one... (in the rain) it was quite scarry how much the rear end wiggled around just going straight down the autobahn at 80 to 100 kph. That's when I went with a full size spare - from an e46 330ci. So happy now.
Spare Tires? http://www.1addicts.com/forums/showp...3&postcount=27 Spare Tires? http://www.1addicts.com/forums/showp...1&postcount=63
06-26-2016, 09:03 AM | #6 | |
Disrupter
1566
Rep 2,484
My 135i has 18" wheels with Michelin PSS tires on them. I occasionally head out hiking with a friend in remote places that might be 30 or 40 miles off of paved roads, on well maintained dirt/gravel roads. A couple of these areas are relatively isolated, and getting an irreparable flat tire could be very very bad. I have a set of 17" Blizzaks on wheels that I use as winter tires. Unlike the PSS tires on the stock wheels, the winter set is square (front and rears the same). Could I simply take one of those Blizzaks with me in the car trunk while venturing out to one of these remote places, and use the Blizzak as a temporary spare in the case of a catastrophic flat? Thanks. Last edited by champignon; 06-26-2016 at 09:08 AM.. |
Dackelone10641.50 |
06-26-2016, 12:05 PM | #7 | |
European Editor
10642
Rep 22,992
Yes, a 17 inch wheel will fit over the front brake rotors and work well as a spare tire. You might want to buy the BMW jack kit... but carrying one of your winter tire/wheels as a spare is a good idea. :Thumbsup: Dackel
06-26-2016, 12:33 PM | #9 | |
Disrupter
1566
Rep 2,484
Is there a special part number for a BMW jack kit that is specific to the 1-Series? Thanks in advance |
06-26-2016, 01:02 PM | #10 | |
1031
Rep 1,972
I also carry the M Mobility kit, although I would have to be in a tough position in order to use it. I used to carry the space saver spare as well (never used), but I sold it to a local list member and just started bringing one of my square winter wheels. Yes, it eats up a bunch of trunk space, but I don't carry much in my 1er. |
06-27-2016, 04:08 AM | #11 | |
European Editor
10642
Rep 22,992
BMW jack kit: p/n 71 10 6 73 536 - 100 euros http://www.1addicts.com/forums/showp...3&postcount=27 My evolution of spare tires... http://www.1addicts.com/forums/showp...1&postcount=63 Dack
06-27-2016, 09:19 AM | #12 | |
Disrupter
1566
Rep 2,484
Checking Amazon, the part number you gave and the one given in the post above yours, produces the same search result. Thanks to both of you! |
06-27-2016, 01:14 PM | #13 | |
European Editor
10642
Rep 22,992
You can also order a mini spare from TireRack.com I also remember some forum members saying the Mitsubishi Galant mini spare fits on a 135i. Just make sure its a 17" wheel. My alloy mini spare(in that link I posted above) was a German only part. The reason is while BMW NA will sell you the alloy wheel, the tire has no DOT rating - so its not allowed to sell it in the USA. But you can order a spare tire "kit" for the old X5 or e60 5er.... and that mini spare tire would also work! I think the kit also comes with a jack. spare tire kit e60 550i bmw p/n 36110308889 $299 http://www.realoem.com/bmw/enUS/show...diagId=36_0916 steel mini spare wheel... 4BX17 ET:18 bmw p/n 36116758778 $66.00 Then order a mini tire from TireRack or a local tire dealer. http://www.realoem.com/bmw/enUS/show...diagId=36_0718
Petro135452.50 |
06-28-2016, 04:17 PM | #14 |
684
Rep 1,608
Dack, I cant tell from the pics, but is that spare strapped down any way on top of your trunk tray?
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 |
06-28-2016, 04:29 PM | #15 | |
European Editor
10642
Rep 22,992
This is the OEM cargo net I have.... http://www.realoem.com/bmw/enUS/show...diagId=03_0269 Here is a great DIY thread on how to install it... DIY: E82 Forward Cargo Hooks http://www.1addicts.com/forums/showthread.php?t=425060
07-01-2016, 08:11 AM | #16 |
213
Rep 893
Bav Auto sells spare tire kits and also a cover that straps the thing down
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
07-05-2016, 08:58 PM | #17 |
Former Opel GT Pilot
327
Rep 771
Perfect idea! This never occurred to me.
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
07-06-2016, 01:58 AM | #18 | ||
Rep 31
http://www.realoem.com/bmw/enUS/show...diagId=36_0513 That one is 3.5" X 17 et30 Bmw pn # 36116750007 |
07-06-2016, 03:33 AM | #19 | |
European Editor
10642
Rep 22,992
I think your wheel has the wrong offset(ET)... This is the alloy mini wheel I had... 3,5X17 ET:8 bmw p/n 36116788203 You can see the spare tire options IF you select an euro build car on the ETK... http://www.realoem.com/bmw/enUS/show...diagId=36_1274 You wil then need to order a DOT approved mini tire... 125/80R17 Dack PS: The smallest wheel a 135i can use is a 17 inch. 1M's need an 18 inch spare.
bobowar1353479.00 |
07-06-2016, 02:54 PM | #20 |
88
Rep 524
Dackelone: Do you have a TPMS in your spare? I'm figuring that would confuse the receivers in the car, but I also assume you'd get an error if you were to run with the spare since the flat one with TPMS would be in the trunk.
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 |
07-06-2016, 05:58 PM | #21 | |
European Editor
10642
Rep 22,992
Btw... I've never had to use my full size spare. But two years ago while in Italy with some BMW friends(Sella 1.0 trip) one of our guys experienced a little bit too much power on over steer... he broke his right rear tire and wheel. I lent him my full size spare. This is the real reason why I carry a full size spare. You don't want to be limited to "just" a 120 mile range(and only 45 mph) speed. Having a full size spare is the only way to travel with full peace of mind.
