BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Engine | Drivetrain | Exhaust
EXXEL Distributions
      07-09-2022, 06:22 PM   #1
deansbimmer
BimmerPost Supporting Vendor
deansbimmer's Avatar
3786
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
VANOS Cover Cups for S65, by Mporium
For several years our shop Mporium BMW Service has offered a permanent solution to the failure prone plastic VANOS spring covers. Until now these components have only been available internally for our own shop's engine work and in-house customer repairs. In light of the increasing interest in vanos repairs we have decided to make our humble product available to the world.
The original adjusters have a plastic cap which serves a simple function- to cover and retain the adjuster’s coil spring. This spring helps returns the cam position to its end point when oil pressure is absent so that it may lock in place for correct startup timing. It also serves to buffer and smooth cam movement when in operation and augment adjustment performance against cam drag in timing advancement. It is important to maintain this spring’s function.
As these engines age and the original VANOS adjuster plastic caps become brittle and fall apart, this causes several critical concerns. Most obvious is the debris from the original caps falling into the oil sump and causing blockage of the oil pump pickups. In the worst cases this can cause oil starvation and engine failure. With the cap covers missing from the VANOS adjusters, the springs are no longer retained properly against the adjuster body and risk “walking” forward on their locating pins and eventually coming free. This may not always result in faults or obvious running issues but has been proven to be the cause of broken internal VANOS rotors and spring contact with the engine timing case and valve cover which results in additional metal shavings being introduced into the engine. It is critical to maintain spring retention and unfortunately these plastic caps are not available separately from BMW.
Our design is simple but unique when compared to clip-on solutions in that the "cup" is held completely captive under the VANOS’ central bolt. Completely streamlined, it is impossible for it to come loose or break apart. There are no clips to ensure are installed correctly or which might come loose. For this application, a captive design is absolutely preferable for long term reliability as it leaves no chance that the spring cover can come loose, vibrate free, or fatigue and fail as has been observed multiple times with clip-on caps. More refined than oversize washer discs, our "cup" design fully encompasses the VANOS spring in a more OE fashion. We believe our solution is the best option available for this application and is ideally installed during engine assembly or top-end work such as camshaft replacement or valve cover service.
*Customized laser engraving is also available. This is often requested if you’re installing custom cams and want the specifications engraved.
Details:
  • Original design only from Mporium in Texas
  • CNC lathe cut from hardened Chromoly steel.
  • Replaces original plastic cover AND central bolt washer.
  • Does not interfere with factory internal parts or valve covers
  • Inherently prone to perfect balance due to precision center bore interface with central bolt.
  • Streamlined and low drag - does not leave spring parts exposed.
  • Customized laser engraving is available.
NOTE: This permanent fix requires releasing the VANOS central bolts with the cams locked while at #1 TDC. Timing must be checked after installation, and we recommend considering this job during renewal or replacement of the valve covers. Luckily, the S65 is one of the easiest BMW ///M engines in which to set cam timing.
The following OEM parts must be replaced during installation:
(4) 11367840998 Central Bolt
(4) 11367839292 Vanos O-Rings
(2) 11317507432 Crush washers (at tensioners)
(2) 11127838162 Access cover gaskets
We offer this upgrade in two ways:
VANOS cups only: Four (4) cups for $379 shipped (standard/ground). Worldwide FedEx express shipping is available.
VANOS cups with install kit: Four (4) cups, + required OEM parts (listed above) for $489
USA orders can be made on our site. Worldwide Priority shipping is $50. Please email us or send me a PM and we will forward an invoice.
Order on our site:
https://mporiumbmw.com/product/vanoscups/
TOOLS:
We also offer rental of the S65 timing tools for $99 per week (7 calendar days). We have several tool sets available on a first come first serve basis. $200 tool deposit is refunded with timely return. Tool rental not available for international orders. 7 day rental period starts on day of tool delivery as verified by tracking number. Return shipment of tool must be confirmed as in the possession of shipping service via tracking by end of next business day after day 7 to avoid assessment of additional rental period and/or forfeiture of tool deposit. Tool rental includes printed and laminated instructions for engine timing/checking from BMW’s TIS documents. We do not accept any liability for incorrect use of tooling or improper installation resulting in any property damage. We do not offer technical support for installation by unqualified individuals.
Appreciate 8
DRLane3997.50
BP709234.50
BOOF-M34451.50
DrFerry6734.50
wyatth3554.50
      12-03-2022, 08:55 AM   #2
deansbimmer
3786
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
Our cups are in stock ready to ship!
As a special option you can specify to add custom text to each cover. Great if you're a shop or want custom cams noted on the cover. As we have our laser on-site it doesn't add any lead-time.
Appreciate 2
DrFerry6734.50
wyatth3554.50
      12-04-2022, 07:14 AM   #3
Assimilator1
Assimilator1's Avatar
597
Drives: BMW M3 e92 08 & 330d e90 10
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Fantastic looking product, tempted to buy your cups myself, especially seeing as I'm leaving the Suzuki dealer soon to work at a BMW one! (they should have the special tools! ).
One question, you mention here (and on your eBay advert) - A captive design is preferable for long term reliability as it leaves no chance that it can come loose, vibrate free, or fatigue and fail as has been observed with clip-on caps
Are you referring just to the OEM plastic ones or the metal aftermarket ones too? If both, do you have any evidence of the metal ones failing? If so I'd like to see photos of that (as I'm considering the clip on ones to save time). If not, you ought to clarify your advert.
If this isn't the place to ask, please direct me to where, or create/ask me to create a new thread.
Cheers
Mark D. (a previous customer of yours).
      04-19-2023, 11:36 AM   #4
CHE///MIST3
CHE///MIST3's Avatar
372
Drives: E92 M3 6MT Space/Black
2009 BMW M3  [0.00]
2007 BMW 328i  [0.00]
Very nice solution ! They look robust, too.
GM
      04-22-2023, 07:35 AM   #5
deansbimmer
3786
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
It's well documented that the plastic ones fail and yes, there have apparently been a number of cases where the aftermarket metal clip-on covers have come loose- either by installation issues or other. Those cases were noted by owners on social media.
Appreciate 2
DrFerry6734.50
      04-24-2023, 03:33 PM   #6
charliev68
charliev68's Avatar
206
Drives: bmw m3
Have had experience with all 3 types. By far, Mporium is the best solution! The best peace of mind for never coming off and not too heavy and thick on the cam adjusters.
Appreciate 4
DrFerry6734.50
atopa2002204.00
wyatth3554.50
      08-07-2023, 12:06 PM   #7
Fooksdaddy
Fooksdaddy's Avatar
110
Drives: 2011 BMW M3 SSII
How much to have you guys install? And approximate turnaround?
E90 ///M3 Silverstone II '11 (current)
E90 ///M3 Silverstone II '08
E46 ///M3 Alpine White III
E36 ///M3 Arctic Silver
E46 ///M3 Carbon Schwartz
      08-07-2023, 02:09 PM   #8
charliev68
charliev68's Avatar
206
Drives: bmw m3
You can do it yourself. It’s pretty satisfying once you get the hang of it. You’re gonna need the cam lock tool. It can be done in about 2hrs.
DrFerry6734.50
      09-04-2023, 11:01 AM   #9
deansbimmer
3786
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
When we do these in our shop, they're almost always done in conjunction with new valve covers and seals. It takes advantage of the massive labor overlap. We only add 1hr labor to the overall job scope when done that way.
Appreciate 2
DrFerry6734.50
      09-05-2023, 03:30 PM   #10
Fooksdaddy
Fooksdaddy's Avatar
110
Appreciate the response, I literally just did the valve covers and the “other” vanos clip on retainers in the garage.
      11-21-2023, 03:37 PM   #11
MAE90M3
74
Drives: E90 M3
Do you no longer have the option to include the other parts(bolts, etc)? I don’t see it on your site.
      11-21-2023, 04:31 PM   #12
deansbimmer
3786
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
I don't have them on the site, I can send a Paypal invoice for them.
We're working on revamping the site with better e-commerce.
      11-27-2023, 07:18 AM   #13
pyhee
Taiwan
29
Drives: BMW E90 M3
Thank you for providing this option! I want to give this a try because I am going to to the valve stem seal replacement (to fix oil consumption) and the VANOS gears have to be removed anyway. This is a good timing to improve the cover, I believe.
A DIY lover who has done to his 2008 E90 M3:
-Heated steering wheel retrofit
-Top HiFi to Individual Audio retrofit
-HiFi to Logic 7 (Top HiFi) retrofit
-OEM backup camera retrofit -E9x M3 M-Drive retrofit
DrFerry6734.50
m3post
