BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Sunroof noise
      03-14-2021, 11:42 PM   #1
blakeusa
Drives: 2017 BMW X1 28I
Sunroof noise
Anybody have or had sunroof noise while driving. Was going to dig in a bit more this week and look at the seal and alignment.
Just wondering if anybody had issues and fixed it. It appears to be a slight wind noise from the front.
I can see in the tech manual you can adjust the front glass and or replace the front or entire seal.
2017 X1 pano roof.
      03-15-2021, 10:20 AM   #2
pcy
Drives: '18 X1 x28i
Hi,
If I were you, I'd look at the condition of the gasket surrounding the glass (part #3 in the diagram below).
      03-15-2021, 05:51 PM   #3
Xorbitman
47
Drives: 2018 BMW X1
Make sure you clean the rubber seals with silicone and then lubricate it with either a bit of white grease spray or even rub some white petroleum jelly over the seal with your finger...clean off excess. This should do it. Also clean and lube the track too. Let me know if this works.
      02-25-2024, 06:47 PM   #4
FluegelX1
Drives: 2019 X1
sunroof noise fix
I loosened both the front and back glasses and moved both forward as there was a gap in the front. This totally fixed my issue.
