10-09-2024, 03:28 PM | #1 |
Rep 8
Can I tell if I have a real ceramic coating on my car?
Bought a new BMW 340i and had the dealership apply ceramic coating for $1300 with 7 years of exterior/interior warranty. Went back home and found that there is no mentioning of a ceramic coating in any of the documents. Instead there is only one that talks about the warranties. Called the dealer asking for either a refund or a proof that there is actual ceramic coating on the car and they won't provide either.
Am I screwed at this point? Is there any ways of confirming/disproving that I have an actual coating on there? |
10-09-2024, 04:08 PM | #2 |
6324
Rep 4,548
It's likely a spray on coating. Dealership ceramic add-ons are complete BS.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
10-09-2024, 04:23 PM | #3 |
1754
Rep 2,829
What does the exterior/interior warranty cover?
My guess is that you won't be able to do anything about it. Many years ago I worked at a dealership & we used "paint sealant" on every car that came off the truck, it was a good quality tech wax, they paid me roughly 5% of what they charged the customer, everyone was charged, if the person wouldn't pay they removed the charge. My guess is you got it but as to the quality of what you got, hard to tell. Case in point - $17.99 and it's a ceramic coating. - Technically I think this meets the requirements of what you purchased. Enjoy the new car and don't let it bother you too much. https://www.amazon.com/dp/B07XYPS3PS...344653e9d&th=1
2006 Z4M Coupe - ZHP knob, stubby antenna, clutch delay delete
10-09-2024, 04:49 PM | #4 | |
Rep 8
Exterior Protection * Environmental Paint Protection ** Warrantied protection of the treated exterior factory painted surfaces against: weather induced fading, weather induced chalking, weather induced loss of gloss, acid rain, bird waste, tree sap, insect damage (including love bugs), sun’s UV damage, hard water spots, de-icing agents/road salt, ocean spray, brake dust, rail dust, paint overspray, and fuel stains. * Headlight Lens Protection ** Warrantied Protection against: the sun’s harmful UV rays causing dulling, yellowing, or fading of the headlight lens(es). Repair Only. * Alloy Wheel Protection ** Warrantied Protection against: pitting or corrosion from road salt, ocean spray, weather-induced damage, and staining from brake dust that can not be easily removed. * Black Trim/Molding Protection ** Warrantied Protection against: fading & discoloring of the exterior black trim/molding/cladding caused by the sun’s harmful UV rays. Repair Only |
David701753.50 |
10-09-2024, 04:50 PM | #5 |
Rep 8
10-09-2024, 05:01 PM | #6 | |
6324
Rep 4,548
On the other hand, you can view this as you paid $1300 for a warranty on your paint (although I would read the fine print very closely...I can't imagine that they will rectify any issue (rail dust as example) for the next 7 years). They will probably say oh you didn't come in annually to have it "recoated" or that you used a car wash lol.
10-09-2024, 05:07 PM | #7 | |
1754
Rep 2,829
You tell the credit card company you can't tell if you got what you asked for or not? What's the dispute?
10-09-2024, 05:07 PM | #8 |
Rep 8
Ah, they did actually send me this link: https://www.ecpinc.net/ and called it the 'Diamond Ceramic Protection'. So I'm guessing ECP 'Diamond Ceramic with Graphene' is the product. Not sure what this is. The website looks fishy...
10-09-2024, 05:07 PM | #9 | |
1754
Rep 2,829
You tell the credit card company you can't tell if you got what you paid for or not? What's the dispute? Based on the evidence I'm on the dealership's side on this one, you paid them to do a job, they said they did it, you aren't sure. Pretty late in the game to be researching the ceramic coating.
tracer bullet3597.00 |
10-09-2024, 05:14 PM | #10 | |
Rep 8
I didn't plan to research it. Was at a local pro shop tinting the window and they were 'pretty confident' that it wasn't an actual coating, only a wax or spray. Oh well... |
10-09-2024, 06:06 PM | #11 |
145
Rep 259
Well it's really not bad if your car is not going to be garage kept. You will have hard water, bird droppings, etc. It's just a matter of time. When it does happen the dealership will have a 3rd party go out and try and take care of it. If they are unable to remove any defects they will have no choice but to respray. When my wife purchased her first new car back in 04. She was sold a "sealant" type of deal. Before her warranty was set to expire we called in to have all the defects removed. I knew they were not going to be able to remove them. Wet sanding, polishing did nothing. End of the day we ended up have the car resprayed at shop of our choice.
If you really want to know if they applied any protection simply spray it down with some water. If it beads or sheets then you have some type of protection. |
10-09-2024, 08:32 PM | #12 |
41
Rep 15
Drives: 2022 840i xDrive Gran Coupe
I’m sure they applied SOME TYPE of ceramic coating. The question is what quality, and how long will it really last.
The ceramic coating was most likely wiped on. I also purchased a dealer-based protection package for outside and inside of my BMW. If I was doing it again, I would have had ceramic coating applied by a auto tint/detailing shop. In my case, I assume I could have had a better quality and less expensive job from a third party. Definitely pour water over your front hood to see if the water rolls right off. |
David701753.50 |
10-10-2024, 07:11 AM | #13 | |
6994
Rep 5,109
Drives: 2022 Z4 M40i, 2021 228i GC
Burrcold6323.50 |
10-10-2024, 08:58 AM | #14 |
3597
Rep 4,172
I wouldn't stop there. Don't be on the offensive or anything but ask your contact at the dealer if you could learn some more about it. Tell them a story like you want to research how to take care of it and so you'd like to know what they applied. Fake a reason to stop in and while there ask to see what they do.
Or tell them a local shop suggested nothing was actually applied, and that you're pretty sure something was indeed applied... but you'd like to settle your doubts and have a look. Be positive about it. Be professional. Maybe be ready to ask for a partial refund if it only takes them a half hour to do the work for that much money, but go in and ask. There's even a small chance you'll walk away impressed or something. |
Westside Guy6994.00 |
10-11-2024, 08:39 PM | #16 |
178
Rep 365
Own and run a successful detail/automotive protection/tint shop.
Unfortunately, dealership ceramic coatings are normally a quick spray-on sealant or wax that will last anywhere from 1 week to 3 months and they call it "ceramic coating." Then make some insane warranty claims but not actually warranty anything. It is usually applied while you're in the finance department signing your paperwork. I can't tell you how much time we spend trying to educate our customers that it's crap. It sounds good because they drop the long lifespan, warranty, etc claims and you can just roll it into your loan or offer it to you when you're tired and just want to get out of the door. If you take a bottle of water and pour it on a panel and it doesn't just roll right off, or use a spray bottle and spray a panel and it doesn't bead up, you don't have a coating. Tell the dealership you plan to dispute the charge if they don't refund you or you'll be leaving them a poor review if they aren't playing ball. But, next time do a little research before buying some snake oil the stealership pitches you as an add-on.
10-16-2024, 02:19 PM | #17 |
664
Rep 1,367
Drives: X5M, M3 ZCP 6MT, MB E63 AMG
Look at the luster in my cars paint, it has been paint corrected, ceramic coated and partial PPF. Any liquids will roll of the ceramic coatings, tree sap, bird poop will wash right off the paint, even dirt and mud will spray right off.
Ceramic coatings take time to apply and cure, not some simply spray on/wipe off spray wax with hydrophobic chemicals in it. And some coatings last 5-6 yrs, may require additional coatings to keep the hydrophobic properties in the paint fresh. Oh, and I forgot to mention, the car goes thru a wash and decontamination process along with a clay bar, then another wash and enhancement polish before ceramic coating is applied. In my opinion, it is well worth the money I spent to have all this done.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
