BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Error after VO coding
      02-12-2019, 09:39 AM   #1
PurePulse64
52
Drives: 2017 BMW X1
Hey all I did a VO code to my F48 last night to do a test run when I take it in for Service - didn't want BMW to know I had coded the car. It reset my oil count - which is no big deal.
But now it's throwing an error on the Brake System. Has anybody had the same issue? The brakes are working fine and it didn't show before I coded.
      02-12-2019, 03:32 PM   #2
PurePulse64
52
Drives: 2017 BMW X1
I figured it out.
If anybody runs into the same issue, it's because I coded from the root level in E-Sys which coded the DME ECU — which is a no, no.
- Turn off car (no motor running)
- Connect
- Read FA
- Activate FA
- Read SVT (VCM)
- Left-Click on DME
- Click on "Detect CAF for SWE" (on the right hand side)
- Select the CAFD from latest I-Level
- Select OK
- Right-Click on DME (the ECU itself not the underlying CAFD)
- CODE
I then had to clear a DTC code in transmitter. But all is good now.
Hope that helps somebody else.
MJE60678.00
